Lunatic_UK1958 wrote:It seems to get more prevailant the longer that Ouka is running!!!!!
That suggests a problem such as over-use of processor resources or a memory leak. Hit Ctrl-Alt-Del to bring up the program manager. Click on the 'processes' tab. What percentage of the processor is in use? Which program is using the most memory? Does the situation get worse as you watch? This could be a bug.
Fast-007
i understand your problem becuse i have the same one with my server too, specially when some one redirect the server to your server i thougt ouka resolved that problem with server v1300 but he havent i have talk to him and he knows about the problem but he's not making moore servers for the moment he have other projects in mind and i respect that
..... big problems is always resolved with small solutions (japanese proverb)
this is what i smoke when im bored
JASON
Off topic here but for people who have read the complete post you'll have noticed that I wrote a plugin for MXChat called OkuruKuru well I updated it fixed a spelling error and added the RCMS limitation commands to the Advanced menu.
Credit goes to Ouka for the original KuruKuru source code.
OKuruKuru.200505181600
Got two more that Ive had for awhile that people may find of use, Credit goes to Nushi for the original source code.
Redirect Chat Text Plugin
Time Display Plugin
Type #Redirect Enable/#Redirect Disable in the channel you wish to have the text sent to from the other channels that your in.
<Insert Abuse Here. . . >
Thanks for keeping us updated Jason. :)
First update in quite a while and some nice new features too ^_^
First and most noticable is the totally new layout, which takes a little getting used to but I happen to prefer it now that I've adjusted to it.
New additions are a force username command and an allow rename command (for users who were renamed). These can both be found under the right click menu under set nickname. There is also an user stats function that can be accessed via print user level.
New commands are...
#usercmd /level <name>
#setnickname <name> #name <forced name>
#admincmd #renamepermission <name>
New things to stick in RCMSconfig.txt are...
$SetNickName$="Set NickName"
$SetNickNameNotify$=" was prohibited the change of name!"
$RenamePermission$="Rename Permission"
$RenamePermissionNotify$=" was permitted the change of name!"
$VoteOn$="Vote ON"
$VoteOnNotify$="Vote ON!"
$VoteOff$="Vote OFF"
$VoteOffNotify$="Vote OFF!"
voting is done with #admincmd toribiaon and #admincmd toribiaoff
Honestly I'm not exactly sure what it is. Here's what he said about it though...
The vote function is an experiment in conjunction with
OukaChatClient1.00c. When voting, it plays 001.wav if it's present in the folder.
I also tested redirecting a few times and didn't encounter any problems with it but that doesn't neccesarily mean anything. I guess we'll have to wait and see on that one.
ChatServerE_500a_2005_05_21_1300.zip
Ouka Chat Server 5.00a 5-21-2005 1300
(120.54 KiB) Downloaded 532 times
JASON
Wow he's been busy I like the new look to it, much friendlier to the eye now I must admit 8) , Thanks for the updated Protoman, I noticed my old auto-update file didnt pick this one up though :(
Fast-007
new ouka server .....new interface just talk to ouka and soon new relases are going to bring up, he give me the new ouka server so i can share it whit the people in this forum
something new -->
[UserInfo]
UserName="SERVER"
ShareNum="121" now the server simulate share ( not a freeloader lol )
[Setting]
PrimaryNode="8" from 1 to 12 primary nodes ( i give him that idea lol )
havent test it my self im waiting for my chat room to crash lol ( 20 days online )
(120.53 KiB) Downloaded 542 times
you might wanna scroll up a couple of posts lol ;)
JASON
Rollin Rollin Rollin.. Thanks Ouka :)
PS. Japanese version, change RCMSConf.txt, Server.ini and any other English files from the previous version to make the program English :)
ChatServer_500a_2005_05_22_0000.zip
(124.15 KiB) Downloaded 528 times
I'd translate it for you except that it's labeled as a test version on Nantonaku's forum. So there's probably going to be a new release sometime soon, which should have an english version.
See? New update now ^-^
Only thing different I see is the vote command is now #admincmd triviaon/off
I'm guessing other than that it's just bug fixes.
ChatServerE_500a_2005_05_24_1200.zip
(119.82 KiB) Downloaded 517 times
Blimey. That's serious development.
And more development. :shock: This sounds like it might be the last release for a bit though.
Yume-san wrote:The test of 5.00a ends with this version.
The configuration file of the automatic update was divided into a
Japanese version and an English version.
ChatServerE_500a_2005_05_26_0000.zip
(120.63 KiB) Downloaded 613 times
JASON
Fast-007 wrote: [Setting]
Is it just me but when you set this the server tends to become unstable and crash.. :?
Twice the server has actually crashed and one time it just sat there using 90%+ cpu, all three times Ive had the server <P=12/12>, Just trying it now back to normal with 8, even removed the line completely from the configuration file.. Shame too cause i liked that :cry:
Lunatic_UK1958
I was running fine with:
except for my ongoing probs!
Went over to:
and within 10 mins Ouka 'froze'
