2.0.13 Critical Update
All updates to the site will be posted here.
A critical update for phpBB has been released, so if you own a form, and use phpBB 2.0.12 or lower, it is strongly advised that you upgrade as soon as possible.
CricketMX.com has already been updated to 2.0.13.
phpBB 2.0.12 to phpBB 2.0.13 Code Changes
As mentioned in this topic at phpBB.com
These are the Changes from phpBB 2.0.12 to phpBB 2.0.13 summed up into a little Mod. This might be very helpful if you want to update your Board and have installed a bunch of Mods. Then it's normally easier to apply the Code Changes than to install all Mods again.
When you find a 'AFTER, ADD'-Statement, the Code have to be added after the last line quoted in the 'FIND'-Statement.
When you find a 'BEFORE, ADD'-Statement, the Code have to be added before the first line quoted in the 'FIND'-Statement.
When you find a 'REPLACE WITH'-Statement, the Code quoted in the 'FIND'-Statement have to be replaced completely with the quoted Code in the 'REPLACE WITH'-Statement.
When you find a 'DELETE'-Statement, the Code have to be deleted.
After you have finished this tutorial, you have to upload the update_to_latest.php file, execute it and then delete it from your webspace.
Ok, lets start:
  • includes/sessions.php
FIND
			if( $sessiondata['autologinid'] == $auto_login_key )
REPLACE WITH
			if( $sessiondata['autologinid'] === $auto_login_key )
  • viewtopic.php
FIND
			$message = str_replace('\"', '"', substr(preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "preg_replace('#\b(" . $highlight_match . ")\b#i', '<span style=\"color:#" . $theme['fontcolor3'] . "\"><b>\\\\1</b></span>', '\\0')", '>' . $message . '<'), 1, -1));
REPLACE WITH
			$message = str_replace('\"', '"', substr(@preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "@preg_replace('#\b(" . $highlight_match . ")\b#i', '<span style=\"color:#" . $theme['fontcolor3'] . "\"><b>\\\\1</b></span>', '\\0')", '>' . $message . '<'), 1, -1));
Once done, run the update_to_latest.php file which can be found in the Changed Files package, it can be obtained from here.
battye wrote:phpBB 2.0.12 to phpBB 2.0.13 Code Changes
These are the Changes from phpBB 2.0.11 to phpBB 2.0.12 summed up into a little Mod.
Eh? Is this 11 to 12 or 12 to 13?
2.0.12 -> 2.0.13 :)
chris
Then why did I register god damnit !
chris wrote:Then why did I register god damnit !
I assume you registered to be a part of this great community. If this isn't the rason then I am sure battye will gladly delete you from our database.
I tried replying to this, but I am lost for words..
I really don't think chris knows what this thread is about. He obviously thinks the change affects the end users. He thinks he's just joined M$ junior and will have to install security updates every second day. :lol:
Freggle
2.0.13 was released a few hours after 2.0.12
Let's hope there are no more hidden critical bugs in the code....
msn-problems.com is up to date ;)
