The Crimson Room etc....
were you at ?Rat wrote:Tune.... if you've done Crimson, maybe you can help me with Viridian???? Pleeeeeeeeeaaaase????
So far I went into the dark room a few times something in there sounds like the devil
Anyway i got some beer, incense a lighter,and a pic. frame all of them will set on the book case with the bell. I lit an incense and rang the bell but don't see anything happen although it will burn away and you have to go back and light another one just hope I don't run out..
Battye careful were you click seems it only works if you are dead on the spots..
I don't think you can run out. But.... You also need the beer to be cold. You must have the correct picture in the frame and also a cd in it's box (open). When all those things are in place you can take the cover off the skeleton which reveals a combination lock - the sort used on bike security chains. I need the combination for the lock.
Is the combination the set of numbers from the URL?
What kinda game is this guys, i love games especially with Mrs. Alex
It's impossible
the red room was fairly easy
but the viridian has me puzzled
I have an Idea though I will be back
Okies but where do i find em??
Rat wrote:The Crimson Room,
The Viridian Room &
The Blue Chamber
These are 'escape' games in flash.
You must find and use the tools hidden in the rooms to make your escape.
I've escaped the Crimson Room but I'm stuck with the other two.
Have a go and let me know how you got on.
The URL is: http://www.fasco-csc.com/index_e.html
thx
Ok guys i escaped from the crimson room now.
GRRR! I have that other Ring, I just need the metal stick which I'm sure is near the pillow, I have got it before. GRR GRR GRR
