Energy Hogs & Bugs - Apps That Sap
Carat
Carat is a free app that tells you what is using up the battery of your mobile device, whether that's normal, and what you can do about it. After running Carat for about a week, you will start to receive personalized recommendations for improving your battery life. Carat is a research project based out of the AMP Lab in the EECS Department at UC Berkeley, collaborating with the University of Helsinki
http://carat.cs.berkeley.edu/
Just seeing if I can get rid of the bot's name, I've deleted the post but the name has remained for some reason.
I am hoping that this post will remove the bot name from the list :evil:
That worked, now out of curiosity, if I delete this post will the bot name return?
No it didn't :)
Kaliy
I’ve always loved active fun — and escape rooms are my favorite way to challenge the mind while staying on the move. 🧩🚪
If you’re into puzzles, adrenaline, and teamwork — you have to check https://i-have-broken-another-of-your-link.s.com
If you’re into puzzles, adrenaline, and teamwork — you have to check.....
Blah blah blah
Seriously.... do you just sit and think of ways to fit your crappy ads into posts here? This forum is like an old sweater and we love it. It doesn't get much traffic anymore but when it does, we hope it's something worth posting. Rest assured, sooner or later I will kill your links. (Probably later.)
Mirabelle
Thanks for your sharing,its a useful project for me.
Oyostepper vende los siguientes productos en línea: motor de engranaje helicoidal,servomotor integrado, motores de husillo y motores paso a paso, que se pueden comprar en línea si es necesario.
