UQM 2.0 - Predictions Extensions
subvertbeats
Hey battye thanks for that.
I guess some of teh code you referenced is from a newer version of UQM - we based this mod around a beta of 2.0, and it doesnt contain those lines that you referenced.
However, we were thinking on the same lines, and I was looking through the code in quiz.php to find the right information (I knew it must be parsed as strings to send to the templates for display on screen, so was just a case of finding the right code fragments).
In the code here, the most important variable (the user submitted answers) was
$user_given_answer
All is working great here now. One of these days I should update the code to the later code base - seems to be cleaner....though to be fair its working just as we need as is.
thanks again!
Franka
Anything else is not really so important.
Skysmotor sells the following products online: Nema 23 motor, Electric rotary actuator, Spindle motor, Stepper motor and can be purchased online if needed.
