Can you please PM me a test username and password so I can have a look?
Thanks for the translation too
tags? :)Code: Select all
You see this error because one or more events have taken place: An attempt of cheating has been detected. - You can not stop a quiz, then return without going through the registration process. - You tried to resubmit a quiz that you have exceeded the time limit - You've played the quiz and the administrator does not allow multiple attempts.Code: Select all
Fatal error: Call to undefined function number_format_points() in /home/clenzono/public_html/shop.php on line 81Code: Select all
Fatal error: Call to undefined function number_format_points () in / home / clenzono / public_html / shop.php on line 81 [/ code]
where does the error please
thank youwhat's going wrong or what deed i wrong ?You haven't selected one or more radio boxes, meaning you still need to select a multiple choice and/or true/false answer, or you have not yet filled in the quiz name and category.
Submit quiz
Select a name for this quiz: adventures 1 maart
This is the name that will appear in the list of quizzes. Choose a name that is short but still gives readers an understanding of what the quiz is about.
Select a category adventures quizzes
Select a category which best matches the genre of the quiz.
For multiple choice answers, select the answer which is correct by clicking the box to the left of the correct answer. For true and false answers, select either true or false. Input answers do not need to be verified, they will be submitted as is.
