I have another question that I figured I'd start up a new thread on...
I am unable to view the attachments that are on the "original posts" that the new page pulls from.
I'm sure it's just a matter of plugging functions in the code to the News.php page, but I've tried doing this by copying the viewtopic.php into News.php and either it errors with sql or just simply doesn't show. You can see the image listed on this page, " dead.png " and to view the actual topic within the forum not on the external page, just click on the title.
http://www.dotrf.net will forward you automatically to the News.php page in question.
And here's the code for the News.php page:
* News.php
* Description: News File for displaying News topics for guild.
* Created on: February 17, 2012
* @package phpBB3
* @version $Id$
* @copyright (c) 2005 phpBB Group
* @license http://opensource.org/licenses/gpl-license.php GNU Public License
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './';
include($phpbb_root_path . 'includes/bbcode.' . $phpEx);
// Start session management
$user->session_begin();
$auth->acl($user->data);
$user->setup('viewforum');
/* create_where_clauses( int[] gen_id, String type )
* This function outputs an SQL WHERE statement for use when grabbing
* posts and topics */
function create_where_clauses($gen_id, $type)
global $db, $auth;
$size_gen_id = sizeof($gen_id);
switch($type)
case 'forum':
$type = 'forum_id';
break;
case 'topic':
$type = 'topic_id';
break;
default:
trigger_error('No type defined');
// Set $out_where to nothing, this will be used of the gen_id
// size is empty, in other words "grab from anywhere" with
// no restrictions
$out_where = '';
if( $size_gen_id > 0 )
// Get a list of all forums the user has permissions to read
$auth_f_read = array_keys($auth->acl_getf('f_read', true));
if( $type == 'topic_id' )
$sql = 'SELECT topic_id FROM ' . TOPICS_TABLE . '
WHERE ' . $db->sql_in_set('topic_id', $gen_id) . '
AND ' . $db->sql_in_set('forum_id', $auth_f_read);
$result = $db->sql_query($sql);
while( $row = $db->sql_fetchrow($result) )
// Create an array with all acceptable topic ids
$topic_id_list[] = $row['topic_id'];
unset($gen_id);
$gen_id = $topic_id_list;
$j = 0;
for( $i = 0; $i < $size_gen_id; $i++ )
$id_check = (int) $gen_id[$i];
// If the type is topic, all checks have been made and the query can start to be built
$out_where .= ($j == 0) ? 'WHERE ' . $type . ' = ' . $id_check . ' ' : 'OR ' . $type . ' = ' . $id_check . ' ';
// If the type is forum, do the check to make sure the user has read permissions
else if( $type == 'forum_id' && $auth->acl_get('f_read', $id_check) )
$j++;
if( $out_where == '' && $size_gen_id > 0 )
trigger_error('A list of topics/forums has not been created');
return $out_where;
$search_limit = 5;
$forum_id = array(37);
$forum_id_where = create_where_clauses($forum_id, 'forum');
$topic_id = array(619);
$topic_id_where = create_where_clauses($topic_id, 'topic');
// Example 3: Display posts from specified topics
$posts_ary = array(
'SELECT' => 'p.*, t.*, u.username, u.user_colour',
'FROM' => array(
POSTS_TABLE => 'p',
'LEFT_JOIN' => array(
array(
'FROM' => array(USERS_TABLE => 'u'),
'ON' => 'u.user_id = p.poster_id'
array(
'FROM' => array(TOPICS_TABLE => 't'),
'ON' => 'p.topic_id = t.topic_id'
'WHERE' => str_replace( array('WHERE ', 'topic_id'), array('', 't.topic_id'), $topic_id_where) . '
AND t.topic_status <> ' . ITEM_MOVED . '
AND t.topic_approved = 1',
'ORDER_BY' => 'p.post_id DESC',
$posts = $db->sql_build_query('SELECT', $posts_ary);
$posts_result = $db->sql_query_limit($posts, $search_limit);
while( $posts_row = $db->sql_fetchrow($posts_result) )
$topic_title = $posts_row['topic_title'];
$post_author = get_username_string('full', $posts_row['poster_id'], $posts_row['username'], $posts_row['user_colour']);
$post_date = $user->format_date($posts_row['post_time']);
$post_link = append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . $posts_row['forum_id'] . '&t=' . $posts_row['topic_id'] . '&p=' . $posts_row['post_id']) . '#p' . $posts_row['post_id'];
$post_text = nl2br($posts_row['post_text']);
$bbcode = new bbcode(base64_encode($bbcode_bitfield));
$bbcode->bbcode_second_pass($post_text, $posts_row['bbcode_uid'], $posts_row['bbcode_bitfield']);
$post_text = smiley_text($post_text);
$template->assign_block_vars('announcements', array(
'TOPIC_TITLE' => censor_text($topic_title),
'POST_AUTHOR' => $post_author,
'POST_DATE' => $post_date,
'POST_LINK' => $post_link,
'POST_TEXT' => censor_text($post_text),
// Output the page - Footer and Conclusion
page_header($user->lang['TITLE_NEWS']);
'body' => 'news_body.html'
page_footer();
