Cable is back online now, I'll try and answer both of these posts tomorrow. Thanks for your patience
joschka, I guess you mean total correct answers? If so for both lines instead of:joschka wrote:many Thanks battye!! that was ist!
have you a any idea for this one??You want to show all results as numerics instead of percentage, yes? I can't help with this. Battye (UQM MOD developer) may be able to assist with this.
at least one value so that a winner can be determined
have a nice day
'PERCENTAGE' => (($row['quiz_incorrect']+$row['quiz_correct'])<1) ? 0 : number_format((100*$row['sum_correct'])/($row['sum_incorrect']+$row['sum_correct']), 0) . '%',
'PERCENTAGE' => $row['quiz_correct'],
arsalan, what do you mean by prediction MOD? Yes it can be used like that now to a certain degree, but it depends on what exactly you need. Can you elaborate? Thanks
arsalan: yes you are able to edit questions and answers after they are submitted in the Quiz CP (if I recall!)
IronDogg, the last 6 months have been very busy in real life! It's just a case of getting back to UQM whenever some time presents itself! I do have quite a few ideas, including some mentioned by members of the community, which I am keen to implement
This happened with foreign language characters . The problem I found was in quiz.phppcmander wrote:when i complete a quiz as a user, it shows this:
This quiz was neither saved nor submitted
$save_type = request_var('submit', '');
$save_type = utf8_normalize_nfc(request_var('submit', '', true));
$given_user_input = request_var('question' . $give_question_id, ''); // raw input
$given_user_input = utf8_normalize_nfc(request_var('question' . $give_question_id, '', true)); // raw input
Recently when I've found a bit of time I've worked away at rewriting UQM. The previous version was getting too large and unwieldy from a code perspective, so I'm trying to use a bit more object orientation this time around. I've got it all set up on another computer at the moment so these are the only screenshots I've got handy:
I'll post some more up soon with a bit more information about the new version CricketMX.com in 2022: Still the home of bat's, rat's and other farmyard animals!
Will do quahappy, thank you. Things are progressing quite nicely so I expect that I will be looking for help testing quite soon
Here are a few more screenshots:
Thanks quahappy, here is the latest screenshot. I spent quite a bit of time today finishing up the statistics modules. I know in the past "surveys" were a big feature request so I have included them on the stats page:
I realise you could ascertain the correct answers from looking at that page, so I have added a restriction that only administrators, the quiz author or anyone that has played the quiz can see the page. And in case anyone still thinks that is not restricted enough, it is pretty easy to disable any of the statistics modules
ok have install ALPHA 1
error debug in quiz page ^_^
[phpBB Debug] PHP Notice: in file /quiz.php on line 515: Undefined variable: auth_params
That's strange, I have debug mode on as well but I didn't get that error. Hopefully there are not any other undefined variables that went by unnoticed
Having said that I can see why the error is occurring. $auth_params is declared and initialised inside the while loop
Open quiz.php and FIND
In the third line, see $auth_params - replace that with $submit_auth_params
Before the $template->assign_vars line, put this code:
'L_STATS_UPPER' => strtoupper($user->lang['UQM_STATS_QUIZ']),
'L_SUBMIT_UPPER' => strtoupper($user->lang['UQM_SUBMIT_QUIZ']),
'U_UQM_SUBMIT' => ($quiz_configuration->auth('submit', $auth_params)) ? append_sid("{$phpbb_root_path}quiz.$phpEx", 'mode=submit') : '',
$submit_auth_params = array(
'administrator' => $auth->acl_get('a_'),
'submit_setting' => $quiz_configuration->value('qc_admin_submit_only'),
'return_value' => true,
perfect fix
Fantastic
Have you seen any other debug errors yet? I am hoping that the $auth_params error was the only one
