Azureus / Vuze
Vuze 4.4.0.6a
Release date: June 24, 2010
Vuze 4.4.0.6a windows.exe
Vuze 4.4.0.6a macosx.dmg
Vuze 4.5
Release date: Aug. 5, 2010
Vuze 4.5 Brings Faster Downloads and Android Support
Changelog
FEATURE: Plug | Android Devices support
CHANGE: Core | Try alternative trackers when seeding and zero connected peers
BUGFIX: UI | Layout improvements in torrent Info view
BUGFIX: UI | Fixed occasional crash when twisting twistie on Windows 7
Download links
Vuze 4.5 windows.exe
Vuze 4.5 macosx.dmg
Vuze 4.5 linux.tar.bz2
Vuze 4.5 linux-x86_64.tar.bz2
Vuze 4.5.jar
Vuze 4.5 pluginapi.jar
Vuze 4.5 source.zip
Vuze 4.5.0.2
Release date: Aug. 6 ,2010
Vuze 4.5.0.2b
Release date: Mac Aug. 10, 2010, Win Aug. 13, 2010
Changelog
CHANGE: Core | Prevent device manager initialisation in classic UI
BUGFIX: UI | Setting files to 'delete' state corrupting internal view of a torrent's files
BUGFIX: UI | Added reworked progress column to library view by default in place of completion date to allow file manipulation from that view
BUGFIX: UI | Consistently show the file-expand twisty
Download links
Vuze 4.5.0.2b windows.exe
Vuze 4.5.0.2b macosx.dmg
Vuze 4.5.0.2 linux.tar.bz2
Vuze 4.5.0.2 linux-x86_64.tar.bz2
Vuze 4.5.0.2 jar
Vuze 4.5.0.2 pluginapi.jar
Vuze 4.5.0.2 source.zip
Vuze 4.5.0.4
Release date: Sept 1, 2010
Changelog
FEATURE: Core | Allow multiple primordial UDP handlers
FEATURE: UI | Ability to auto-send crash logs
FEATURE: UI | Members of the Beta Program now get a Sidebar entry which will one day have useful beta information
CHANGE: UI | Improved languages change detection so more of the text now shows in the new language (unfortunately not all)
CHANGE: UI | (Windows) Bigger click area around the "X" in the Library's filter box
CHANGE: UI | (Windows) Triple click in search box now selects all the text
CHANGE: UI | Replaced "Remove And.." menu tree from Library's content menu with "Remove..." entry that gives you the same options. Two related configs are in Options->Files->"File Deletion"
BUGFIX: Core | (Windows) Fix drive detection/removal when multiple drives get added/removed at once
BUGFIX: Core | (Windows) Fix drive with letters D: H: L: P: T: X: not being detected when plugged in while Vuze was running
BUGFIX: Core | Fixed some hard drives incorrectly being added as a Device and shown in the sidebar
BUGFIX: Core | (OSX) Add additional (new?) crash log directory to crash log generator (debug.zip)
BUGFIX: Core | (OSX) Fixed two cases where main window would not show after clicking the dock icon
BUGFIX: Core | Don't open files with write-access unless required
BUGFIX: Core | Ensure new profiles are picked up when xcode plugin reloads
BUGFIX: Core | Correctly sequence plugin events to ensure that listeners see the correct plugin state
BUGFIX: Core | Delete .vuze files when subscriptions are removed
BUGFIX: UI | (*nix) Fix table cells not getting click events (affected triggering the "New" column's state)
BUGFIX: UI | Fix case where scrolling right in a table view (Library) didn't draw the newly visible columns
BUGFIX: UI | Fixed some cases where column re-ordering was not being remembered
BUGFIX: UI | Fix Help->Check for Updates not notifying user there were no new updates found
BUGFIX: UI | Fixed visual problems with Tracker Status column when "Don't Scrape Stopped" is enabled
BUGFIX: UI | Fixed Queue and Stop not working on Torrent menu and right click of Sidebar's download's details item
BUGFIX: UI | (OSX) Fixed bug where a false double click was registered when Vuze did not have the focus and you single clicked on a row in the Library
BUGFIX: UI | Fixed subscription name and count on Sidebar not redrawing when either changes
Download links
Vuze 4.5.0.4 windows.exe
Vuze 4.5.0.4 macosx.dmg
Vuze 4.5.0.4 linux.tar.bz2
Vuze 4.5.0.4 linux-x86_64.tar.bz2
Vuze 4.5.0.4 jar
Vuze 4.5.0.4 pluginapi.jar
Vuze 4.5.0.4 source.zip
Vuze 4.5.1.0
Release Date: Oct. 5, 9 & 23 , 2010
Changelog
FEATURE: Core | Monitor available JVM memory and warn user if it is running out and auto increase (Windows only)
FEATURE: UI | Support opening .vuze files from URLs
FEATURE: UI | Allow setting of JVM direct memory max from UI (Windows only)
FEATURE: UI | Added 'protocol' column to peers view
FEATURE: UI | Expanded state of Sidebar entries are now remembered
FEATURE: UI | (Windows) Added Closeable Games sidebar entry
CHANGE: Core | Changed the trigger for upload rate bias when unlimited upload and inactive downloads
CHANGE: Core | Permit export of all search templates
CHANGE: Core | Reduce debug messages for connection-refused type tracker errors
CHANGE: Core | Reduce version-check timeouts to prevent version server errors from adversely affecting Vuze
CHANGE: Core | Be more tolerant of large PEX messages as clients are sending valid exchanges that exceeded our old limits
CHANGE: Core | Improve detection of devices
CHANGE: Core | Report better error messages for failed plugin installs
CHANGE: Core | Add alert details to alert log
CHANGE: Core | Log plugin load-at-start state to diagnostics
CHANGE: UI | Better handling in in-client browser for search engines and (blocking) pop-ups
CHANGE: UI | Device status column now reports when a file is being copied to the device
BUGFIX: Core | Fixes to superseeding mode
BUGFIX: Core | Fixed up disabling of UDP tracker protocol and added option to control UDP probing
BUGFIX: Core | Fixed bug involving switching search template from manual to auto mode
BUGFIX: Core | Immediately drop incoming connections for stopped downloads (they used to persist and timeout later)
BUGFIX: Core | Fixed bug whereby add-for-seeding torrents with reorder-piece file mode and move-to dirs resulted in download being marked as incomplete
BUGFIX: Core | OSX - handle UTF-8 BOM in plist
BUGFIX: UI | Sort column editor available table correctly
BUGFIX: UI | Fix case where sidebar doesn't display properly at startup
BUGFIX: UI | Changing name of Device should now be remembered
BUGFIX: * | Fix various Null Pointer Exceptions
Download links
Vuze 4.5.1.0a windows.exe
Vuze 4.5.1.0b windows.exe
Vuze 4.5.1.0a macosx.dmg
Vuze 4.5.1.0 linux.tar.bz2
Vuze 4.5.1.0 linux-x86_64.tar.bz2
Vuze 4.5.1.0 jar
Vuze 4.5.1.0 pluginapi.jar
Vuze 4.5.1.0 source.zip
Vuze 4.6
Release Date: Jan. 17, 2011
Next Stop: Instant Gratification
Wtf I am not sure when it happened, but there's a Vuze Plus version that features DVD burning, built-in anti-virus protection from BitDefender, Play Now (play downloads still in progress) and no ads. :roll: http://www.vuze.com/compare.php
Changelog
FEATURE: Core | UDP NAT Test tool
FEATURE: Core | Added device export/import feature
FEATURE: Plug | uTP support
FEATURE: Plug | Streaming playback
FEATURE: Plug | Added simple HTML view and explicit download option to device RSS feed
FEATURE: UI | Add menu link from sidebar entries to plugin options where applicable
FEATURE: UI | Option for what happens when pressing delete key or tb delete in My Torrents/Library
FEATURE: UI | Allow dropping torrent URLs onto sidebar (to add torrent)
CHANGE: Core | Prevent UDP scrape probes and DHT fallback scrape values from overriding more relevant values
CHANGE: Core | Added some more client type peer-id decodes
CHANGE: Core | Ensure piece picker file priorities take precedence over first/last piece
CHANGE: Core | Don't auto-xcode low noise torrents
CHANGE: Core | Propagate cookies across http->https redirects
CHANGE: Core | Various minor startup tweaks to increase startup performance
CHANGE: Plug | Bump up the DHT minimum supported version
CHANGE: Plug | Added option to force delayed restart on install
CHANGE: UI | Rate limit various update operations to improve performance
CHANGE: UI | Make tracker update button scrape torrents that are stopped
CHANGE: UI | Wire up play button to xcoded content
CHANGE: UI | Sidebar redesign
CHANGE: UI | Categories can now be shown in sidebar
CHANGE: UI | Filter text in Config view now gets highlighted
BUGFIX: Core | Fix poor perf with large peer connection count
BUGFIX: Core | Pickup changes in transcode file categories
BUGFIX: Core | Disable outbound UDP data connections if proxy set
BUGFIX: Core | Fix reading some rare .torrent files with only UTF-8 keys
BUGFIX: Core | Fix bug when loading multiple .torrent files at once when they have the same URL filename
BUGFIX: Plug | Fixup names displayed during plugin load/init
BUGFIX: UI | Prevent sources from being added multiple times
Download links:
Vuze 4.6 windows.exe
Vuze 4.6 macosx.dmg
Vuze 4.6 linux.tar.bz2
Vuze 4.6 linux-x86_64.tar.bz2
Vuze 4.6.jar
Vuze 4.6 pluginapi.jar
Vuze 4.6 source.zip
p2p-sharing-rules wrote:Wtf I am not sure when it happened, but there's a Vuze Plus version that features DVD burning, built-in anti-virus protection from BitDefender, Play Now (play downloads still in progress) and no ads. :roll: http://www.vuze.com/compare.php
Yes, there is, and I don't like it. If you sign up for a trial of this version, you'll get, amongst other things, a free DVD burn. After making a trial disc, the view was ok-ish on my laptop (with a black frame) but, when I put the disc in my dvd player, the tv showed a small picture with a very wide frame that I couldn't get rid of using either the tv or dvd controls. :( Given that I have dvd burners that work efficiently and reliable anti-virus, the other bits and pieces were insufficiently attractive to make me take the plunge. There are, for example, an awful lot of transcoders to convert your file into other formats.... but I couldn't find even one that I could make use of. Got a TiVo? Maybe it'll be good for you. Got an i-phone? Go right ahead.
It took a long time to work out how to get rid of the "plus" features from my Vuze when I decided not to pay for the premium version. I had error messages every time I loaded Vuze until I checked forums and found that lots of folks were having the same issues.
Moral: Test first. Pay (or not) later.
PS. The ads in Vuze cost good money to remove but are unobtrusive.... so I ignore them for free.
Vuze 4.6.0.2
Release date: Feb. 1, 2011
Changelog
FEATURE: Core | Relocate MOOV atoms to front of mp4 files for streaming
FEATURE: Core | Allow specification of IP address restriction for device content availability
FEATURE: Core | Grab <torrent> entities from RSS feed if present
FEATURE: Plug | Rate limit download speeds when play-now active to avoid disk contention
FEATURE: UI | Add 'Play Now' column for streaming
CHANGE: UI | Added visual indication to first level menu for auto-device xcode selection
CHANGE: UI | Support drag-n-drop onto classic share view
BUGFIX: Core | Fix rare case where torrent at top of queue doesn't start & one later in the queue continues to download
BUGFIX: Core | Fix case where certain non-ASCII chars were causing metasearch config bloat
BUGFIX: Core | Fix incorrect handling of reload of upnpav plugin resulting in xcodes disappearing until restart
BUGFIX: Plug | Restore AV 'scanning' spinner icon
BUGFIX: UI | Fix missing columns in "New" view
BUGFIX: UI | Fix drag indicator when prioritizing torrents in Library
BUGFIX: UI | Fix case where certain non-ASCII categories were causing azureus.config to bloat
BUGFIX: UI | Fix cases where Web Search wasn't opening results in external browser
BUGFIX: UI | Fix incorrect toolbar selection when in files view
BUGFIX: UI | Fix incorrect handing of devices set to 'never transcode'
Download links
Vuze 4.6.0.2 Windows.exe
Vuze 4.6.0.2 Macosx.dmg
Vuze 4.6.0.2 Linux.tar.bz2
Vuze 4.6.0.2 Linux.x86_64.tar.bz2
Vuze 4.6.0.2 Source.zip
Vuze 4.6.0.2 pluginapi.jar
Vuze 4.6.0.4
Release Date: March 10, 2011
Changelog
CHANGE: UIv3 | Better messaging for Plus users on license expiry
CHANGE: UI | 50% faster table redraw on Windows when cell value changes
BUGFIX: UI | Fixed some dialogs that could open larger than the screen size
Download links
Vuze 4.6.0.4 windows.exe
Vuze 4.6.0.4 macosx.dmg
Vuze 4.6.0.4 linux.tar.bz2
Vuze 4.6.0.4 linux-x86_64.tar.bz2
Vuze 4.6.0.4.jar
Vuze 4.6.0.4 pluginapi.jar
Vuze 4.6.0.4 source.zip
