Azureus / Vuze
p2p-sharing-rules
Vuze 4.2.0.2 April 10, 2009
Changelog
BUGFIX: UI | Fix wrap on category buttons
BUGFIX: UI | Fix rare case when last sash position in My Torrents wasn't being obeyed
BUGFIX: UI | Remove device toolbar when device feature not avail
BUGFIX: Core | Fix hang on startup with some UPnP devices
BUGFIX: Plug | Force decode of HTTP headers to lowercase using ISO8859-1 charset to fix matching error in Turkish
Download links:
Azureus 4.2.0.2.jar
Vuze 4.2.0.2 windows.exe
Vuze 4.2.0.2 linux.tar.bz2
Vuze 4.2.0.2 linux-x86_64.tar.bz2
Vuze 4.2.0.2 macosx.dmg
Vuze 4.2.0.2 pluginapi.jar
Vuze 4.2.0.2 source.zip
p2p-sharing-rules
Vuze 4.2.0.4
Release date: July 8, 2009
changelog
FEATURE: Core | Subscription options for auto-starting auto-downloads
FEATURE: Core | Support for sharing .vuze files [Parg]
FEATURE: Core | Added support for adding categories to transcoded content
FEATURE: Core | Added default transcode dir option
FEATURE: Core | Support for keep-alive and more gzip on web contexts
FEATURE: Core | Added percentage complete and eta to content descriptor
FEATURE: UIvz | UI displays while core initializes
FEATURE: Plug | Plugin interface to the search functionality
CHANGE: Core | Added another non-standard RSS date format
CHANGE: Core | Allow HTTP seeding for simple torrents without knowledge of file name
CHANGE: Core | Keep log files open rather than continually opening and closing them
CHANGE: Core | Improved reporting of 'no disk space' errors for FAT32
CHANGE: Core | Improved logging performance
CHANGE: Core | Support for updated via installer as opposed to incremental updates
BUGFIX: Core | Work around for broken socket handling on freebsd7.x
BUGFIX: Core | Recover from borked transcode queue config
BUGFIX: Core | Fix xml stats export with undefined characters
BUGFIX: Core | Support >2GB resource downloads
BUGFIX: Core | Fixed HTTP seeding when switching content on a keep-alive connection
BUGFIX: Core | Fix tracker announcer to pay attention to user options correctly
BUGFIX: Core | Multi-file torrents were borked in content directory
BUGFIX: UI | Set speeds in bits/sec when bits/sec display is selected
Download links
Azureus 4.2.0.4.jar
Vuze 4.2.0.4 windows.exe
Vuze 4.2.0.4 linux.tar.bz2
Vuze 4.2.0.4 linux-x86_64.tar.bz2
Vuze 4.2.0.4 macosx.dmg
Vuze 4.2.0.4 pluginapi.jar
Vuze 4.2.0.4 source.zip
p2p-sharing-rules
4.2.0.8 - August 26, 2009
New Features:
* Core | Drive Detection for Devices for OSX (for PSP devices)
* Core | Factory option to allow switchable unchoke algorithms
Changes:
* UI | Less CPU usage for Seeding Rules
* Core | Only create the transcode directories when required
* Core | Allow OSX platform component to be updated properly
Corrected bugs:
* UI | Fixed Speedtest not working
* UI | OSX 10.6 support (opening torrent from file)
* Core | OSX 10.6 support (not getting data from connected peers)
* Core | Fixed deadlock during UI initialisation
4.2.0.6 - August 06, 2009
New Features:
* UI | Support delete key for deleting transcoded content
* UI | Added visual indication of buddy shares
* UI | Added toolbar enablers for deleting subscriptions and devices
* Core | Support for TiVo device
* Core | Support for PSP device
* Core | Added RSS feed generation for device's transcoded content
* Core | File-based RSS feeds
* Core | Added ability to set category for downloads from a subscription
Changes:
* UI | Moved Column Setup and column related menu items to right click of column header
* UI | Made Library/My Torrents filter more visible
* UI | Moved "Rename" context menu in Library to context menu of Name column only
* UI | Gray out non-active devices
* Core | Added more meta data for devices RSS Feed
* Plug | Added lifetime controls to DHT puts
Corrected bugs:
* Core | HTTP seeding was incorrectly handling byte range requests
* Core | Catch failed transcodes and prevent partial files from being produced
* Core | Fixed potential deadlock on startup with Device loading
* Core | Support UTF marker chars in RSS feeds
download links
Azureus 4.2.0.8.jar
Vuze 4.2.0.8a windows.exe
Vuze 4.2.0.8 linux.tar.bz2
Vuze 4.2.0.8 linux-x86_64.tar.bz2
Vuze 4.2.0.8a macosx.dmg
Vuze 4.2.0.8 pluginapi.jar
Vuze 4.2.0.8 source.zip
p2p-sharing-rules
Azureus/Vuze 4.3.0.0
Release date: Nov. 11 , 2009
Changelog
FEATURE: Core | Added support for UPnP based offline-downloader services
FEATURE: Core | Obfuscated lookups for the DHT to prevent leakage of key values during lookup stage
FEATURE: Core | Support copying of .mp3 and .wma files to PSP
FEATURE: Core | Implementation of a piece-reordering file manager
FEATURE: Core | DHT replication controls
FEATURE: Core | Initial pairing support
FEATURE: Core | Parse seed/leecher values from subscription text if found
FEATURE: Core | Added bloom-filter persistence
FEATURE: Core | Support ".utf-8" suffix for keys in .torrent files
FEATURE: Plug | Added download-flags to Download object
FEATURE: Plug | Plugin access to subscriptions
FEATURE: Plug | Added verified plugins
FEATURE: UIvz | Added "Reset Columns" ability to some views (in Column Setup)
FEATURE: UIvz | Client now opens to last used static view, or Library by default
FEATURE: UI | Support for switching between carbon and cocoa on OSX
FEATURE: UI | Generic filter support for our tables
FEATURE: UI | Support for showing real SI values rather than just changing units displayed
FEATURE: UI | Advanced menu option for editing http seeds
CHANGE: Core | Remove replicate-on-join from DHT as causing excessive key storage
CHANGE: Core | Roll up subscription warnings when not expanded
CHANGE: Core | Improved IPv6-handshaking and reconnects with other clients (see http://www.azureuswiki.com/index.php/IPv6_compatibility for supported systems)
CHANGE: Core | Switch back to k-select on OSX
CHANGE: Core | Reduce CPU used for node-id calculation via MRU cache
CHANGE: Core | Remove LAN transfer totals from data reported to tracker
CHANGE: Core | Implemented port restriction for DHT node id generation
CHANGE: Core | Reduce memory/CPU by disabling the largely unused Vivaldi V2 impl
CHANGE: Core | Reduce DHT load by removing network-position derived tracking targets
CHANGE: Core | Back off the initial DHT seeding
CHANGE: Core | Cache redirects for http seeds
CHANGE: Core | Use async keep-alive test to reduce thread creation on magnet download
CHANGE: Core | Change defaults for I2P and Tor networks to fase
CHANGE: Core | Support http seeds that don't support partial content
CHANGE: Core | Added option to disable TiVo support completely
CHANGE: Core | Support RSS feeds with incorrect 'summary' instead of 'description' entries
CHANGE: Core | Support trackers that returned gzipped torrents even when not asked to
CHANGE: Core | Migrate away from system-managed private keys
CHANGE: Core | Support meta-search incremental result injection
CHANGE: Core | Use cached scrape values on startup for DHT torrents to reduce thrashing
CHANGE: Core | Switch version check to use HTTP by default [Parg]
CHANGE: Core | Resource resources by grabbing piecemap once during piece pick operation
CHANGE: Core | Reduce cost of handling DHT store operations
CHANGE: Core | Remove 'force write' option from random access file access
CHANGE: Core | Move a few things to use the less costly stepped-monotime method
CHANGE: Core | Re-use http connections when messaging the platform
CHANGE: Core | Don't write diagnostic files to disk by default
CHANGE: Core | Reduce small scratch file creation on startup
CHANGE: Core | Don't write tables.config every start
CHANGE: Core | If we don't have hosted content, don't write the config file
CHANGE: Core | Potentially less Tracker Announces for those trackers not supplying "min interval"
CHANGE: Plug | Reduce frequency of UPnP device specification download attempts
CHANGE: UIvz | Removed Login and Friends, Content Networks menu
CHANGE: UI | Order files in file view by torrent index if piece numbers same
CHANGE: UI | Pulled out the RSS feed generation for devices and put into common location
CHANGE: UI | Allows addition of http seeds to decentralised torrents
CHANGE: UI | Make regex matching mode more obvious
CHANGE: UI | Better "Associated Application" icon logic
CHANGE: UI | (OSX) Switch to SWT for Cocoa Framework
BUGFIX: Core | Don't reset manually selected Vuze meta search templates on load
BUGFIX: Core | Removed 'watched' tag from torrents on import
BUGFIX: Core | index-out-of-bounds fix when global peer limit reached
BUGFIX: Core | Fix incorrect sync of scrape hashes
BUGFIX: Core | Prevent unwanted selection of in-error subscriptions
BUGFIX: Plug | Force UPnP operations not to use socks/http proxy when defined
BUGFIX: UI | Fixed case where Open Torrents Window might erase existing files
BUGFIX: UI | Fixed context menus sometimes hanging client on Windows 7
BUGFIX: UI | Fix missing icons for pause/resume in all-transfers bar
BUGFIX: UI | Fix invalid thread access in parameter change logic
BUGFIX: UI | Fix progress-dialog feedback for magnet downloads
BUGFIX: UI | Fix cases on OSX where a modal dialog box ended up under main window
Download links
Azureus 4.3.0.0.jar
Vuze 4.3.0.0 windows.exe
Vuze 4.3.0.0a macosx.dmg
Vuze 4.3.0.0 linux.tar.bz2
Vuze 4.3.0.0 linux-x86_64.tar.bz2
Vuze 4.3.0.0 source.zip
Vuze 4.3.0.0 pluginapi.jar
p2p-sharing-rules
Vuze 4.3.0.4
Release date: Nov. 20, 2009
Changelog
2009.11.20 | Vuze 4.3.0.4
BUGFIX: UI | Prevent main window from popping up when adding a torrent and "Add Torrent Silently" set
BUGFIX: UI | Ensure that the correct progress reports are passed to listeners
BUGFIX: UI | Fixed bug whereby the destruction of the torrent-open window was cancelling torrent download dialogs
BUGFIX: UI | (OSX) Fixed bug where scrollers on some mice would cause table to blank
BUGFIX: UIvz | Handle magnet links within internal browser
BUGFIX: Plug | Improved the fallback lookup service by passing the all params
BUGFIX: Plug | Verify that downloaded torrents are valid before passing to caller
2009.11.19 | Vuze 4.3.0.2
FEATURE: Core | Support per-url config for http seeds and max_speed setting
FEATURE: Plug | Start of a fallback magnet lookup service
FEATURE: UI | Clicking on dock icon always opens main window
CHANGE: Core | Parse hex-encoded magnet URIs too
CHANGE: Core | Immediate-close option for tracker socket connections
CHANGE: Core | Return IP address instead of DNS names for external seeds
CHANGE: Core | Support more non-conformant RSS feed dates
CHANGE: Core | Auto-speed bias towards min ping times rather than pure average
BUGFIX: Core | Reverted socket handling to initial 1.6 fix status to fix with network binding/stall problems [Parg]
BUGFIX: Core | Added option to disable all IPv6 support and defaulted to 'disable' on OSX as some users experiencing crash when enabled
BUGFIX: Plug | Don't cause all dht torrents to perform an 'announce' when 'pause-all' selected
BUGFIX: Plug | Webplugin config section override was using the wrong variable prefix
BUGFIX: UI | Fixed name column sort
BUGFIX: UI | (OSX) Fixed opening .vuze files when client isn't running
BUGFIX: UI | Fixed table view not loading (showing gray area) sometimes
BUGFIX: UI | (Windows) "Open Containing Folder" in default "folder association" app
BUGFIX: UI | (*nix) Fixed name column blanking
BUGFIX: UI | (OSX) Fixed Password option hanging UI
BUGFIX: UI | Fixed sidebar font sizes (mostly for *nix)
BUGFIX: UI | (OSX) Opening .torrent file when "Add Silently" is enable should no longer activate the main window
BUGFIX: UI | Fix losing cursor indication on Sashes (and other widgets)
BUGFIX: UI | Sidebar now accepts dropping torrents
Download links
Azureus 4.3.0.4.jar
Vuze 4.3.0.4 windows.exe
Vuze 4.3.0.4 macosx.dmg
Vuze 4.3.0.4 linux.tar.bz2
Vuze 4.3.0.4 linux-x86_64.tar.bz2
Vuze 4.3.0.4 source.zip
Vuze 4.3.0.4 pluginapi.jar
Vuze 4.3.0.4a Windows
Release date: Nov. 25, 2009
Download link
Vuze 4.3.0.4a_windows.exe
p2p-sharing-rules
Vuze 4.3.0.6
release date: Jan. 11, 2010
Changelog
BUGFIX: Core | Fixed bug where compact file types could lead to spurious 'file length too large' errors
Download links
Azureus 4.3.0.6 .jar
Vuze 4.3.0.6 windows.exe
Vuze 4.3.0.6 macosx.dmg
Vuze 4.3.0.6 linux.tar.bz2
Vuze 4.3.0.6 source.zip
Vuze 4.3.0.6 pluginapi.jar
p2p-sharing-rules
Azureus / Vuze 4.3.1.2
Release date: Feb. 2, 2010
Vuze Updates Their BitTorrent Client
4.3.1.2 Changelog
FEATURE: Core | Added .vuze file format to trigger a search operation
CHANGE: Core | Disable IPv6 under Windows by default, as it needs Java7 to work properly
CHANGE: Core | Added system property to disable instance manager
CHANGE: Core | Give user friendlier error message when offline-downloader disconnected
CHANGE: Core | Auto-dump threads if shutdown takes > 30 seconds
CHANGE: UI | Permit deletion of classicaly shared content from download/seeding views
BUGFIX: Core | Wait until sid registered before attempting pairing test
BUGFIX: Core | Various pairing HTTPS fixes
BUGFIX: Core | Fix missing 'logout' button when paired with no authentication
BUGFIX: UI | Windows - Vuze now pops up if closed to system tray and user launches exe
BUGFIX: UI | Fixup some Remote Pairing dialog edge case bugs
BUGFIX: UI | OSX - Fix sidebar animations sometimes not animating
BUGFIX: UI | OSX - Text in table views are now the correct color (white) when selected
BUGFIX: UI | Protect against case where Main Window's stored dimensions area invalid or stupidly small
BUGFIX: UI | Fix invalid thread access and NPE when closing pairing dialog
BUGFIX: UI | Fixed case where status bar was blank after deiconifying
4.3.1.0 Changelog
FEATURE: Core | Option to auto-start Vuze on login on Windows and OSX
FEATURE: Core | Option to close Vuze when downloads/seeding complete
FEATURE: Core | Sources details view and tracking enhancements
FEATURE: Core | Option to automatically set upload slots and connections limits based on measured line speed
FEATURE: Core | Added support for fast-allowed pieces
FEATURE: Core | Extract downloaded values if returned by tracker
FEATURE: Plug | Added auto-authorisation default to pairing enabled web plugins
FEATURE: Core | Windows - added JVM max/min memory configuration to the options
FEATURE: Core | Added support for webseeds in magnet links
FEATURE: Core | Added support for less-verbose auto-full-update
FEATURE: Core | Completed the 'pairing' feature
FEATURE: UI | Added Pairing dialog
CHANGE: Core | Added local network interfaces to pairing details
CHANGE: Core | Drop the half-open TCP socket limits for Vista SP2+ and Windows 7
CHANGE: Core | Modify connection timeouts if sufficient peers available
CHANGE: Core | Ignore HTTP seeds if we're seeding
CHANGE: Core | Vary min requests when starting up
CHANGE: Core | Changed metasearch default to auto=true
CHANGE: Core | Default save directory for new installs switched from 'Azureus Downloads' to 'Vuze Downloads'
CHANGE: Core | Auto-enable the 'connections per torrent when seeding' default and set to half the normal number of connections
CHANGE: Core | When force-closing Vuze delete any outstanding updates to prevent them being applied
CHANGE: Plug | Make WebPlugin configuration parameters amendable without requiring a Vuze restart
CHANGE: UI | Added arrows to swarm view and differentiate unchokes/fast requests
CHANGE: UI | Moved slideys that were System Notifications to statusbar
BUGFIX: Core | Fix remembering of auto-speed settings on restart
BUGFIX: Core | Fix initial storing of search engine rank bias
BUGFIX: Core | Fix LT Peer-Exchange bug
BUGFIX: Core | Remove HTTP seeds when stopping download
BUGFIX: UIvz | Fix list view modes (menu and button display) being grayed out when toolbar is in "No Text" mode
BUGFIX: UI | Remove cached peers from swarm view on data source change
BUGFIX: UI | When upgrading SWT, dialog box now shows correct platform (Cocoa, Carbon)
Download links
Azureus 4.3.1.2.jar
Vuze 4.3.1.2 windows.exe
Vuze 4.3.1.2 macosx.dmg
Vuze 4.3.1.2 linux.tar.bz2
Vuze 4.3.1.2 linux-x86_64.tar.bz2
Vuze 4.3.1.2 source.zip
Vuze 4.3.1.2 pluginapi.jar
p2p-sharing-rules
Azureus / Vuze 4.3.1.4
Release date: Feb. 10, 2010
Changelog
BUGFIX: Core | Fixed bug whereby HAVE_ALL messages were failing to set the last bit of the bit-flags
Download links
Azureus 4.3.1.4.jar
Vuze 4.3.1.4 windows.exe
Vuze 4.3.1.4 macosx.dmg
Vuze 4.3.1.4 linux.tar.bz2
Vuze 4.3.1.4 linux-x86_64.tar.bz2
Vuze 4.3.1.4 source.zip
Vuze 4.3.1.4 pluginapi.jar
Dammit. I finally had to ditch ABC cos I was getting too many refusals. Everyone was recommending Vuze so I installed it. I was appalled to see that some things never change. I quit using Azureus years ago because it installed in Polish tho I asked for English during the installation. Guess what? Yup, the same damn thing still happens and there still doesn't seem to be a way to switch back.
What is this based on? Keyboard layout? I guess so as my OS is English. Is there a fix for this?
p2p-sharing-rules
Vuze FAQ
How do I change the Language setting?
In case you changed to a different language by accident these are the necessary steps you have to take to pick another one. Named items are provided in english, positions are provided in brackets.
1. Open the Options tab
* Windows
- Go to the Advanced section of Vuze (View > Advanced)
- Press Ctrl + the comma key (,) or select [ Tools (4th menu) > Options (last item) ]
2 Double click on Interface (5th item)
3 Click on Language (1st subitem)
4 Select your Language
Thank you thank you thank you.
I didn't do it by accident. grr
p2p-sharing-rules
Vuze 4.4.0.0
Changelog
FEATURE: Core | Feature manager
FEATURE: Core | Added mechanism to add virtual devices
FEATURE: Core | On-demand media analysis
FEATURE: Core | Added a few hooks to ease third party use of code
FEATURE: Core | Added means to hook into content launch operations
FEATURE: Core | Allow devices to be specified as 'no xcode required'
FEATURE: Core | Added option to prevent IP filters being cleared on reload
FEATURE: Core | Re-attempt torrent download via magnet if possible
FEATURE: Plug | Added mechanism for a cache-plugin to reserve pieces for their cache-peer
FEATURE: Plug | Added mechanism for plugins to specify executable properties of installed files
FEATURE: Plug | Added method for testing if move-on-complete actions are active
FEATURE: UI | Toolbar support for selecting files in file-view
FEATURE: UI | Feature Manager UI
FEATURE: UI | Better Drag&Drop indication on sidebar
FEATURE: UI | Better pop-out/pop-up supression from Search Results pages
CHANGE: Core | Added ability to add xcodes in stopped state
CHANGE: Core | When there's only one transcode profile available, don't allow user to make a (non-existant) choice
CHANGE: Core | Added country-code to version server response
CHANGE: Core | Don't push direct file reads through the file cache
CHANGE: Plug | Allow plugins to force their columns to be visible
CHANGE: Core | Allow the removal of transcode jobs to be vetoed
CHANGE: Core | Take USB detection off init thread in case it hangs
CHANGE: Core | Added download property to allow force and direct deletion to be specified
CHANGE: Core | Enforce update action ordering
CHANGE: Plug | Added swt info to update check to allow different plugin versions for different swt
CHANGE: UI | Limit max torrent file size to prevent bad behaviour when large files dropped onto UI
CHANGE: UI | Truncation percentages shown for xcode to avoid useless ".0"
CHANGE: UI | Restructure Sidebar/Tab system into a common MDI structure
CHANGE: UI | Some dialogs now switch Ok/Cancel to Cancel/Ok on OSX
BUGFIX: Core | Fix 'no space' display for offline downloaders [Parg]
BUGFIX: Core | Fixed opening torrent from Finder bug under OSX 10.4
BUGFIX: Core | Magnet download of large torrent files speed up
BUGFIX: Core | Resource downloader was firing complete events twice sometimes
BUGFIX: Core | File channel support for 2GB+ files
BUGFIX: Core | Update pending files in xcode view when files deletes
BUGFIX: Core | Fix relayout bug in status bar
BUGFIX: Core | Fix various places where linked files were being ignored
BUGFIX: Core | Fix rare case where Donation window was popping up too often
BUGFIX: Plug | Ensure that reloaded plugin's message resources are loaded
BUGFIX: Plug | Ensure installation failures are reported
BUGFIX: UI | Extend cell refresh logic to include those with refresh listeners
BUGFIX: UI | Fix rare case where table sort order is incorrect after raid data updates
BUGFIX: UI | Patch case where Vuze prevents Windows 7 from shutting down
BUGFIX: UI | Fix buttons having ugly BG on Win7
BUGFIX: UI | Fix some columns not showing up in "All Torrents" views
BUGFIX: UI | Fix clipboard menu not working for some columns (Torrent Name Column)
Download links
Vuze 4.4.0.0 windows.exe
Vuze 4.4.0.0 macosx.dmg
Vuze 4.4.0.0 linux.tar.bz2
Vuze 4.4.0.0 linux-x86_64.tar.bz2
Vuze 4.4.0.0 source.zip
Vuze 4.4.0.0 pluginapi.jar
p2p-sharing-rules
Vuze 4.4.0.4
Release date: May 8, 2010
Changelog
BUGFIX: Core | Fix PEX bug
BUGFIX: Core | Fix "Error Running Veto Check" error
BUGFIX: Core | (*nix) Fix client not launching after launched once
BUGFIX: UI | Fix late-loading sidebar entries not auto-opening
Here's the changelog for Vuze 4.4.0.2 that I missed to post on here.
CHANGE: UI | (OSX) Prep client for SWT 3.6 (M7 and later)
CHANGE: UI | (OSX) Use Java calls for moveToTrash and showInFinder
CHANGE: UI | Double click in library view on incomplete downloads no longer invokes the launch manager for permission
CHANGE: Core | Added some new message types to help diagnose connection speed issues
CHANGE: Core | Removal of various useless debug generation
CHANGE: Core | Use UTF-8 for debug files
BUGFIX: Plug | If EMP is disabled fall back to default player
BUGFIX: Core | Fix deadlock condition in devices view
BUGFIX: Core | Prevent single key failure from exiting select result processing
BUGFIX: Core | Fix deadlock when download stopped while move-on-complete in progress
BUGFIX: Core | Various fixes to handle restarts with non-ascii user directory name
BUGFIX: Core | Ensure plugin verification works with internationalised plugin dir name
BUGFIX: UIvz | Fix bug where toolbar was hidden with no way of showing it
BUGFIX: UIvz | Fix bug where DVD Burn sidebar entry would reappear after removing it and restarting
BUGFIX: UIvz | When doubleclick in Library is set to show details, don't show AntiVirus warning
BUGFIX: UIvz | Fix OSX case where client could not be started due to old SWT version
BUGFIX: UIvz | Fix case where there was nothing downloading, but the download spinner in the sidebar was still present
Download links
Vuze 4.4.0.4 windows.exe
Vuze 4.4.0.4 macosx.dmg
Vuze 4.4.0.4 linux.tar.bz2
Vuze 4.4.0.4 linux-x86_64.tar.bz2
Vuze 4.4.0.4 source.zip
Vuze 4.4.0.4 pluginapi.jar
I have 4.4.0.4 and hadn't noticed any bugs until that version installed itself. Now I have 3 errors every time the program starts, and all of them seem to be associated with the program trying to install what appears to be a licence code (serial) and failing owing to some unspecified server error. Bleh.
p2p-sharing-rules
Vuze 4.4.0.6
Release date: June 4, 2010
BUGFIX: Core | Search edge case
Download links
Vuze 4.4.0.6 windows.exe
Vuze 4.4.0.6 macosx.dmg
Vuze 4.4.0.6 linux.tar.bz2
Vuze 4.4.0.6 linux-x86_64.tar.bz2
Vuze 4.4.0.6 source.zip
Vuze 4.4.0.6 pluginapi.jar
