phpbb Displaying topics from external pages
I would try moving all of your HTML header info (which is at the top of your newsfeed.php file) into the newsfeed.html file. You may need to reinstate page_footer(); in the newsfeed.php come to think of it.
Ideally you want as little HTML as possible in your PHP file.
frozensun
alright, but how do I integrate the information that comes from newsfeed.php into newsfeed.html, and still format it to streamline with the page?
Have a look at this page:
http://wiki.phpbb.com/Tutorial.Template_syntax
So if you were inside a loop (and I saw a few foreach loops in your php page) you would use:
    $template->assign_block_vars('loopname', array(
        'EXAMPLE' => 'Some message or even a bit of HTML code here',
And then you can call that in your HTML file by including:
<!-- BEGIN loopname -->
Output: {loopname.EXAMPLE}
<!-- END loopname -->
If you want to add a templating variable that is NOT in a loop, see http://wiki.phpbb.com/Tutorial.Template ... #Variables - you simply call that in the HTML page with {FOO} {BAR} and {BAZ}
At the top and bottom of your HTML page include overall_header.html and overall_footer.html respectively
Once you have transferred all of your HTML code from the PHP file into the HTML file, then you can add back page_header() and page_footer() [as it won't give errors once the HTML is removed] to your PHP file and you will have retained your layout so it is consistent with the forum.
I'm don't know how familiar you are with PHP so I am happy to help you further and walk you through it if you want - I just quickly wrote this now to start you off on the right foot as you might want to play around with the code between now and tomorrow (when I will be online next).
Mary17
battye wrote:I still can't see any errors on http://www.7cr9.com/exp1.php. Can you tell me what the error is that you see on http://www.7cr9.com/exp1.php :?: :)
Hey there, so what's really going on is:
On the page there aren't errors from the code itself, but on 7cr9.com/exp1.php (which I manage through frontpage) I have other php codes as the one of cutenews, which doesn't appear, as well as many other stuff. The site should have this aspect: http://7cr9.com/Home.php but with the "last topics" thing on the same place as in 7cr9.com/exp1.php , do you understand?
The codes of these two pages are exatcly the same, the only difference is that in 7cr9.com/exp1.php it has the topics code which makes many other stuff just disappear...
I read somewhere that maybe I had to integrate this code into frontpage with css. ... Is it right? How is that done?
Thank you very much in advance,
Mary
Just in case I leave you here the full code of 7cr9.com/exp1.php:
<html xmlns:v="urn:schemas-microsoft-com:vml" xmlns:o="urn:schemas-microsoft-com:office:office" xmlns="http://www.w3.org/TR/REC-html40">
$phpbb_root_path = './forum/'; // Path to phpbb folder
// Start session management
$user->session_begin();
$auth->acl($user->data);
// Grab user preferences
$user->setup();
<head>
<meta http-equiv="Content-Type" content="text/html; charset=windows-1252">
<meta name="verify-v1" content="rIWTFpQLuOArySY8IOB8fkfbi9xD7kCgfKc43/tC2xE=" />
<title>7CR9, site fãs de Cristiano Ronaldo CR9 /7 (Cristiano Ronaldo fansite)</title>
<script language="JavaScript">
// --><script type="text/javascript" src="http://www.haloscan.com/load/mariamsr"> </script>
</script>
<style>
.ms-simple1-main { border-left-style: none; border-right-style: none;
border-top: 1.5pt solid green; border-bottom: 1.5pt solid green }
.ms-simple1-tl { border-left-style: none; border-right-style: none; border-top-style: none;
border-bottom: .75pt solid green }
.ms-simple1-left { border-style: none }
.ms-simple1-top { border-left-style: none; border-right-style: none; border-top-style: none;
.ms-simple1-even { border-style: none }
</style>
</head>
<meta name="verify-v1" content="eFju5IN4adFN1ySnXJW/xJuer91o13rkr2qn3VmL7wY=" />
<body>
<div style="border:3px double #000000; position: absolute; width: 943px; height: 23px; z-index: 4; left: 25px; top: 577px; visibility:visible; background-color:#000000" id="camada4">
<div style="position: absolute; width: 227px; height: 964px; z-index: 1; left: 782px; top: 94px; background-color:#FFFFFF; background-image:url('../7cr9/Coluna%20Direita.jpeg')" id="camada17">
<div style="position: absolute; width: 111px; height: 100px; z-index: 9; left: 129px; top: -72px" id="camada51">
<div style="position: absolute; width: 100px; height: 99px; z-index: 1; left: -126px; top: 1458px" id="camada52">
&nbsp;<?
/*** phpBB3 - Last Active Topics System ***/
//Show last x topics
define('TOPICS_LIMIT',10);
// Create arrays
$topics = array();
// Get forums that current user has read rights to.
$forums = array_unique(array_keys($auth->acl_getf('f_read', true)));
// Get active topics.
$sql="SELECT *
FROM " . TOPICS_TABLE . "
WHERE topic_approved = '1' AND " . $db->sql_in_set('forum_id', $forums) . "
ORDER BY topic_last_post_time DESC";
$result = $db->sql_query_limit($sql,TOPICS_LIMIT);
while ($r = $db->sql_fetchrow($result))
$topics[] = $r;
$db->sql_freeresult($result);
<div>
foreach($topics as $t)
// Get folder img, topic status/type related information
$topic_tracking_info = get_complete_topic_tracking($t['forum_id'], $t['topic_id']);
$unread_topic = (isset($topic_tracking_info[$t['topic_id']]) && $t['topic_last_post_time'] > $topic_tracking_info[$t['topic_id']]) ? true : false;
$folder_img = $folder_alt = $topic_type = '';
topic_status($t, $t['topic_replies'], $unread_topic, $folder_img, $folder_alt, $topic_type);
// output the link
<img style="vertical-align: text-bottom" src="<?=$user->img($folder_img, $folder_alt, false, '', 'src');?>" title="<?=$user->lang[$folder_alt];?>" alt="<?=$user->lang[$folder_alt];?>" />
<a href="<?=$phpbb_root_path . 'viewtopic.php?f=' . $t['forum_id'] . '&t=' . $t['topic_id'] . '&p=' . $t['topic_last_post_id'] . '#p' . $t['topic_last_post_id'];?>"><?=html_entity_decode($t['topic_title']);?></a><br />
</div></div>
<b><font color="#FF6600" face="Arial" size="2">Em reconstrução</font></b></div>
<p style="margin-top: 0; margin-bottom: 0">
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
<b><i>
<font face="Arial" size="2" color="#FFFFFF">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </font></i></b>
</p>
<div style="position: absolute; width: 197px; height: 259px; z-index: 1; left: 18px; top: 50px" id="camada34">
<b><span style="background-color: #000000"><i>
<font face="Arial" size="2" color="#FFFFFF">Vídeos </font></i></span>
<font face="Arial" color="#FFFFFF" size="2">
<span style="background-color: #000000">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
</span> </font></b></p>
<b><font face="Arial" color="#800000">- </font>
<font face="Arial" size="2">Making of anúncio BES "I Gotta Feeling" TVI</font></b></p>
<font face="Arial" size="2">Entrevista exclusiva TVI 9/4/10</font></b></p>
<font face="Arial" size="2">Novo anúncio BES 9/4/10</font></b></p>
<font face="Arial" size="2">Conf.imprensa 8/4/10</font></b></p>
<font size="2" face="Arial">Racing Santander vs CR</font></b></p>
<font face="Arial" size="2">CR vs Atlético Madrid</font></b></p>
<font face="Arial" size="2">Getafe vs CR</font></b></p>
<font face="Arial" size="2">CR vs Sporting Gijón</font></b></p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
<p>&nbsp;</div>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
<div style="position: absolute; width: 199px; height: 235px; z-index: 2; left: 16px; top: 277px" id="camada35">
<span style="background-color: #000000"><b><i>
<font face="Arial" size="2" color="#FFFFFF">Galeria&nbsp; </font></i>
</b></span><b><span style="background-color: #000000"><i>
<font face="Arial" size="2" color="#FFFFFF">&nbsp;</font></i></span><font face="Arial" color="#FFFFFF" size="2"><span style="background-color: #000000">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
&nbsp;&nbsp;&nbsp; </span></font></b></p>
<b><font face="Arial" size="2" color="#800000"><i>- </i></font>
<font face="Arial" size="2">Real Madrid 1-0 Lyon </font></b>
<font face="Arial" size="2">(jogos Real Madrid 09/10)</font></p>
<b><i><font face="Arial" size="2" color="#800000">- </font></i>
<font face="Arial" size="2">Treino 8, 9 e 12 Março </font></b>
<font face="Arial" size="2">(treinos Real Madrid 09/10)</font></p>
<font face="Arial" size="2">Conf.imprensa 8-3-10 </font></b>
<font face="Arial" size="2">(conf.imprensa)</font></p>
<font face="Arial" size="2">Apresentação Bilhetes Final Champions League
</font></b><font face="Arial" size="2">(variados)</font></p>
<font face="Arial" size="2">Portugal 2-0 China </font></b>
<font face="Arial" size="2">(jogos Selecção Nacional Qualificação
Mundial2010)</font></p>
<font face="Arial" size="2">Treino 2 Março (</font></b><font face="Arial" size="2">treinos
Selecção Nacional qualificação Mundial2010)</font></p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
</div>
<div style="position: absolute; width: 194px; height: 100px; z-index: 4; left: 22px; top: 548px" id="camada37">
<table border="1" width="98%" id="table3">
<tr>
<td width="65" align="center">&nbsp;</td>
<td width="20" align="center"><b>
<font face="Arial" size="2">J</font></b></td>
<td width="22" align="center"><b>
<font face="Arial" size="2">G</font></b></td>
<td align="center" width="22"><b>
<font face="Arial" size="2">A</font></b></td>
<td align="center"><b><font size="2" face="Arial">Total
G</font></b></td>
</tr>
<tr>
<td width="65" align="left"><b>
<font face="Arial" size="2">La Liga</font></b></td>
<td width="20" align="center"><b><font face="Arial" size="2">21</font></b></td>
<td width="22" align="center"><b><font face="Arial" size="2">18</font></b></td>
<td align="center" width="22"><b><font face="Arial" size="2">4</font></b></td>
<td align="center"><b><font face="Arial" size="2">18</font></b></td>
</tr>
<tr>
<td width="65" align="left"><b><font face="Arial" size="2">Champions
League</font></b></td>
<td width="20" align="center"><b><font face="Arial" size="2">6</font></b></td>
<td width="22" align="center"><b><font face="Arial" size="2">7</font></b></td>
<td align="center" width="22"><font face="Arial" size="2"><b>0</b></font></td>
<td align="center"><b><font face="Arial" size="2">7</font></b></td>
</tr>
<tr>
<b><font face="Arial" size="2">Copa del Rey</font></b></td>
<td width="20" align="center"><b>´0</b></td>
<td width="22" align="center"><b>0</b></td>
<td align="center" width="22"><b>0</b></td>
<td align="center"><b>0</b></td>
</tr>
<tr>
<font face="Arial" size="2">Portugal</font></b></td>
<td width="20" align="center"><b>4</b></td>
<td align="center" width="22"><b>2</b></td>
</tr>
<tr>
<font face="Arial" size="2">Pré-época RealMadrid</font></b></td>
<td width="20" align="center"><b><font face="Arial" size="2">9</font></b></td>
<td width="22" align="center"><b><font face="Arial" size="2">3</font></b></td>
<font face="Arial" size="2">0</font></b></td>
<td align="center"><b><font face="Arial" size="2">3</font></b></td>
</tr>
</table>
<p style="margin-top: 0; margin-bottom: 0">&nbsp;</p>
</div>
<p style="margin-top: 0; margin-bottom: 0"><b>
<font face="Arial" size="2" color="#FFFFFF">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
</font></b></p>
<div style="position: absolute; width: 197px; height: 100px; z-index: 3; left: 18px; top: 793px" id="camada36">
<table border="1" width="89%" id="table2">
<tr>
<td width="104" align="center">&nbsp;</td>
<td width="18" align="center"><b>
<td width="27" align="center"><b>
<font face="Arial" size="2">Pts</font></b></td>
</tr>
<tr>
<td width="104" align="left"><font face="Arial" size="2"><b>1.</b></font><b><font face="Arial" size="2">REALMADRID</font></b></td>
<td width="18" align="center"><font size="2"><b>29</b></font></td>
<td width="27" align="center"><b><font face="Arial" size="2">74</font></b></td>
</tr>
<tr>
<td width="104" align="left" height="22"><b><font face="Arial" size="2">
2.BarcelonaFC</font></b></td>
<td width="18" align="center" height="22">
<td width="27" align="center" height="22">
<font size="2"><b>74</b></font></td>
</tr>
<tr>
<td width="104" align="left"><b><font face="Arial" size="2">3. Valencia
CF</font></b></td>
<td width="27" align="center"><font size="2"><b>53</b></font></td>
</tr>
<tr>
<td width="104" align="left"><b><font face="Arial" size="2">4.
RCD Mallorca</font></b></td>
<td width="18" align="center"><b><font face="Arial" size="2">29</font></b></td>
<td width="27" align="center"><b><font face="Arial" size="2">47</font></b></td>
</tr>
</table>
</div>
</div>
<marquee bgcolor="#FFFFFF" style="font-family: Arial">Prox Jogo: 10 Abril Real Madrid vs Barcelona FC (21:00 hora Portugal) -- Racing Santander 0-2 Real Madrid (1 golo de Ronaldo!) ---Videos para download: Making of anúncio BES "I Gotta Feeling" TVI; Entrevista exclusiva TVI 9/4/10; Novo anúncio BES 9/4/10; Conf.imprensa 8/4/10; Racing Santander vs CR: Getafe vs CR</marquee></div>
<div style="border-style:outset; border-color:#C0C0C0; position: absolute; width: 230px; height: 408px; z-index: 9; left: 811px; top: 1641px" id="camada19">
<!-- BEGIN CBOX - www.cbox.ws - v001 -->
<div id="cboxdiv" style="text-align: center; line-height: 0">
<div><iframe frameborder="0" width="200" height="305" src="http://www6.cbox.ws/box/?boxid=403066&b ... t&sec=main" marginheight="2" marginwidth="2" scrolling="auto" allowtransparency="yes" name="cboxmain" style="border:#DBE2ED 1px solid;" id="cboxmain"></iframe></div>
<div><iframe frameborder="0" width="200" height="75" src="http://www6.cbox.ws/box/?boxid=403066&b ... t&sec=form" marginheight="2" marginwidth="2" scrolling="no" allowtransparency="yes" name="cboxform" style="border:#DBE2ED 1px solid;border-top:0px" id="cboxform"></iframe></div>
</div>
<!-- END CBOX --></div></div>
<p align="center">
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
</p>
<div style="position: absolute; width: 845px; height: 100px; z-index: 11; left: 95px; top: 18px" id="camada23">
<img border="0" src="../7cr9/Principal.jpeg" width="851" height="546"></div>
<div style="position: absolute; width: 203px; height: 1416px; z-index: 2; left: 2px; top: 674px; padding-left: 4px; padding-right: 4px; padding-top: 1px; padding-bottom: 1px; background-color: #FFFFFF; visibility:visible; background-image:url('../7cr9/Barra%20Esquerda.jpeg')" id="camada2">
<p style="margin-top: 0; margin-bottom: 0" align="center">
<i><u>
<font face="Arial">&nbsp;</font></u></i></p>
<div style="position: absolute; width: 608px; height: 12715px; z-index: 3; left: 191px; top: 1417px; border-left-style: solid; border-left-width: 1px; border-right-style: outset; border-right-width: 1px; border-bottom-style: outset; border-bottom-width: 1px; padding-left: 4px; padding-right: 4px; padding-top: 1px; padding-bottom: 1px" id="camada50">
&nbsp;</div>
<div style="position: absolute; width: 601px; height: 14129px; z-index: 4; left: 197px; top: -1px; visibility:visible" id="camada26">
<div style="position: absolute; width: 1085px; height: 58px; z-index: 2; left: -191px; top: -72px" id="camada27">
<a href="http://7cr9.com/Home.php">
<img border="0" src="../7cr9/Home%20menu.jpeg" width="128" height="66"></a><a href="Sobre%20ele.htm"><img border="0" src="../7cr9/Sobre%20Ele%20menu.jpeg" width="125" height="64"></a><a href="Noticias.htm"><img border="0" src="../7cr9/Noticias%20menu.jpeg" width="128" height="67"></a><a href="Videos.htm"><img border="0" src="../7cr9/Videos%20menu.jpeg" width="134" height="69"></a><a href="http://7cr9gallery.co.cc/Gallery/index.php"><img border="0" src="../7cr9/Galeria%20menu.jpeg" width="139" height="72"></a><a href="Chat.htm"><img border="0" src="../7cr9/Chat%20menu.jpeg" width="137" height="73"></a><a href="Sobreosite.htm"><img border="0" src="../7cr9/Sobre%20o%20site.jpeg" width="128" height="71"></a><a href="http://7cr9.com/forum/"><img border="0" src="../7cr9/Forum.menu.jpeg" width="123" height="69"></a></div>
<p align="center">
<img border="0" src="../7cr9/Ultimas%20Noticias.JPG" width="328" height="68"><p align="center">
<font face="Arial">&nbsp;<?PHP
$number=12;
$only_active=TRUE;
include("/home/crcom/public_html/cutenews/show_news.php");
?></font><div style="position: absolute; width: 522px; height: 100px; z-index: 3; left: 43px; top: 14163px" id="camada32" align="center">
<font face="Arial" size="2"><font color="#666666"><u>7</u></font><a href="http://www.7cr9.com"><font color="#666666">CristianoRonaldo9
- 7cr9.com</font></a><font color="#666666"> © 2009 - Webhost:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
- </font><a href="mailto:mary17.7cr9@gmail.com"><font color="#666666">
Contactar 7CR9</font></a></font><div style="position: absolute; width: 91px; height: 47px; z-index: 1; left: 310px; top: -15px" id="camada33">
&nbsp;</div>
<p align="center"><font face="Arial" size="2" color="#666666">7CR9 não é
o site oficial do Cristiano Ronaldo, e não tenho qualquer contacto com o
jogador, familiares ou amigos. </font> </div>
</div>
<font size="5" face="Pristina">
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </font>
</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
<font face="Pristina" size="2">&nbsp;</font></p>
<b>
<i><u>
<font face="Arial">XMaryX17X&nbsp;</font></u></i></b></p>
&nbsp;&nbsp; ______________________</p>
<font face="Arial" size="2"><b>&nbsp;&nbsp;&nbsp;&nbsp; </b> </font></p>
<div style="position: absolute; width: 101px; height: 23px; z-index: 12; left: 13px; top: 207px" id="camada49">
<b><font face="Arial" size="2">7CR9 promo!</font></b></div>
<div style="position: absolute; width: 100px; height: 100px; z-index: 5; left: 28px; top: 383px" id="camada38">
<object width="155" height="125"><param name="movie" value="http://www.youtube.com/v/v7hS3ryG4ak&hl ... ram><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/v7hS3ryG4ak&hl=pt-br&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="155" height="125"></embed></object>
</div>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
<font face="Arial" size="2">&nbsp;&nbsp; </font></p>
&nbsp;</p>
<div style="position: absolute; width: 101px; height: 23px; z-index: 12; left: 31px; top: 369px" id="camada47">
<b><font face="Arial" size="2">Everything</font></b></div>
<div style="position: absolute; width: 180px; height: 141px; z-index: 13; left: 5px; top: 223px" id="camada48">
<object width="183" height="145"><param name="movie" value="http://www.youtube.com/v/5-TjVYXfiRI&hl ... ram><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/5-TjVYXfiRI&hl=pt-br&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="183" height="145"></embed></object></div>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
<font face="Arial" size="2"><b>&nbsp;&nbsp;&nbsp;</b></font></p>
<div style="position: absolute; width: 140px; height: 113px; z-index: 5; left: 28px; top: 522px" id="camada39">
<object width="155" height="125"><param name="movie" value="http://www.youtube.com/v/9dbWcSxIPxA&hl ... ram><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/9dbWcSxIPxA&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="155" height="125"></embed></object>
</div>
<div style="position: absolute; width: 100px; height: 19px; z-index: 11; left: 30px; top: 508px" id="camada46">
<b><font face="Arial" size="2">Best of 2008</font></b></div>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
&nbsp;</p>
<p class="MsoNormal" style="margin-top: 3px; margin-bottom: 3px">
&nbsp;</p>
&nbsp;</p>
<p style="margin-top: 0; margin-bottom: 0" align="justify">
&nbsp;</p>
<span style="font-weight: 700" lang="en-gb">
<font face="Arial" size="2">&nbsp;&nbsp;&nbsp;&nbsp; </font>
</span></p>
<font face="Arial" color="#800000">&nbsp;&nbsp; </font></span></p>
<div style="position: absolute; width: 181px; height: 100px; z-index: 10; left: 14px; top: 676px" id="camada45">
<font face="Arial" color="#800000">-</font><font face="Arial" size="2"> </font>
<a href="mailto:mary17.7cristianoronaldo7@gmail.com">
<font face="Arial" size="2" color="#000000">mary17.7cr9@gmail.com</font></a></span></div>
&nbsp;</p>
&nbsp;</p>
&nbsp;&nbsp;&nbsp; </p>
<b><font face="Arial">&nbsp; </font></b></p>
<div style="position: absolute; width: 152px; height: 100px; z-index: 9; left: 16px; top: 765px" id="camada44">
<b><font face="Arial">&nbsp;</font></b><span style="font-weight: 700" lang="en-gb"><font face="Arial" color="#800000">- </font>
</span><b><font size="2" face="Arial">
<a href="http://7cristianoronaldo9.hi5.com"><font color="#000000">Hi5&nbsp;&nbsp;</font></a></font></b><font size="2">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
</font></p>
<font size="2">&nbsp;</font><span style="font-weight: 700" lang="en-gb"><font face="Arial" color="#800000">- </font>
</span><b>
<a href="http://www.facebook.com/home.php#/profi ... ef=profile">
<font size="2" color="#000000" face="Arial">Facebook</font></a></b></p>
<span style="font-weight: 700">
<font size="2" face="Arial">&nbsp;</font></span><span style="font-weight: 700" lang="en-gb"><font face="Arial" color="#800000">- </font>
</span><b><a href="http://twitter.com/7cronaldo9">
<font size="2" color="#000000" face="Arial">Twitter</font></a></b></p>
<p style="margin-top: 0; margin-bottom: 0" align="left">
</span><b>
<a href="http://www.orkut.com/Main#Profile.aspx? ... 4822680467">
<font size="2" color="#000000" face="Arial">Orkut</font></a></b></p>
</span><b><a href="http://www.myspace.com/492095675">
<font size="2" color="#000000" face="Arial">Myspace</font></a></b></p>
</span><b><a href="http://www.tagged.com/7cristianoronaldo9">
<font size="2" color="#000000" face="Arial">Tagged</font></a></b></p>
<p>&nbsp;</div>
&nbsp; </p>
&nbsp; </p>
<p style="margin-top: 0; margin-bottom: 0" align="justify">&nbsp;</p>
</p>
<div style="position: absolute; width: 176px; height: 100px; z-index: 8; left: 16px; top: 938px" id="camada43">
<p align="left" style="margin-top: 0px; margin-bottom: 0px">
</span><b><font face="Arial" size="2" color="#FFFFFF">
<a href="http://cristianoronaldo7-17.blogspot.com/"><font color="#000000">
Cristiano Ronaldo7-17 Blog</font></a></font></b></p>
<a href="http://www.xmaryx17cristianoronaldovideos.blogspot.com/">
<font color="#000000">XMaryX17 Vídeos</font></a></font></b></p>
</span><b><font color="#FFFFFF" size="2" face="Arial">
<a href="http://br.youtube.com/profile?user=XxXMaryX17XxX">
<font color="#000000">My channel on Youtube</font></a></font></b></p>
<b><font face="Arial" size="2">-
<a href="http://www.facebook.com/Cristiano?v=wall"><font color="#000000">
Facebook C.Ronaldo</font></a></font></b></p>
-</span></font><span lang="en-gb"> </span><b>
<a href="http://www.gestifute.com/gestifute/index_mundial.html">
<font color="#000000">Gestifute</font></a></font></b></p>
<a href="http://www.fpf.pt/portal/page/portal/PORTAL_FUTEBOL">
<font color="#000000">FPF</font></a></font></b></p>
</span><b><u>
<a href="http://www.realmadrid.com/cs/Satellite/es/Home.htm">
<font color="#000000">Real MadridFC Official Site</font></a></font></u></b></p>
<p>&nbsp;</div>
&nbsp;</p>
&nbsp;</p>
<p align="left" style="margin-top: 0; margin-bottom: 0">
<font color="#000000" face="Arial" size="2">&nbsp;&nbsp; </font></p>
<font face="Arial" color="#800000">&nbsp;&nbsp;</font></span></p>
<div style="position: absolute; width: 176px; height: 100px; z-index: 7; left: 13px; top: 1121px" id="camada42">
<font face="Arial" color="#800000">&nbsp;- </font>
</span><font face="Arial" size="2" color="#FFFFFF">
<b><a href="http://www.ronaldofan.com/"><font color="#000000">Ronaldo Você É Bonito</font></a></b></font></p>
<b>
<font color="#000000" size="2" face="Arial">&nbsp;</font><font color="#800000" face="Arial">- </font>
<a href="http://cristiano-ronaldo.us/"><font color="#000000">CristianoRonaldo.us</font></a></font></b></p>
<a href="http://www.cr9brasil.blogspot.com/">
<font color="#000000" size="2" face="Arial">CR9 Brasil</font><font color="#000000" face="Arial">&nbsp;</font></a></span></p>
<span style="font-weight: 700" lang="en-gb"><font face="Arial">
<font color="#800000">&nbsp;-</font> <font size="2">
<a href="http://everythingcr7.netne.net/"><font color="#000000">EverythingCR7</font></a></font></font></span></p>
</span><b><font face="Arial" color="#FFFFFF">
<u>
<a href="http://davidluiz-23.blogspot.com/"><font color="#000000" size="2">David
Luiz 23*</font></a></u></font></b></p>
<b>
<font color="#000000" size="2" face="Arial">&nbsp;</font></b><span style="font-weight: 700" lang="en-gb"><font face="Arial" color="#800000">- </font>
</span><b><font color="#FFFFFF" face="Arial">
<a href="http://lucascr7futebolmundial.blogspot.com/">
<font color="#000000" size="2">Futebol Mundial</font></a></font></b></p>
<p>&nbsp;</div>
&nbsp;</p>
&nbsp;<font color="#FFFFFF"><p align="left" style="margin-top: 0; margin-bottom: 0">
&nbsp;<p align="left" style="margin-top: 0; margin-bottom: 0">
&nbsp;<!-- INICIO DO CODIGO DO CONTADOR DE VISITAS 2W.COM.BR -->
<div style="position: absolute; width: 176px; height: 100px; z-index: 6; left: 9px; top: 1279px" id="camada41">
<div align=center>
<p style="margin-top: -4px; margin-bottom: -4px">
<a href="http://www.2w.com.br/contador-de-visita ... ratis.html">
<font color="#000000"><img src="http://contador.2w.com.br/imgcontador.php?p=ec637389" alt="" border=0></font></a></div>
<div align=center>
Obrigada pela visita!</font></div>
<p align="center" style="margin-top: -4px; margin-bottom: -4px"><!-- INICIO CONTADOR -->
<a href='http://cifradasweb.net/' id='lnolt_' target='_blank' style='font-family:Arial;font-size:11px;font-weight:bold;text-decoration:none;'>
<script language='JavaScript' src='http://blogutils.net/olct/online.php?si ... '></script>
</font></a>
<a href='http://www.blogutils.net/' target='_blank' style='font-family:Arial;font-size:11px;font-weight:bold;text-decoration:none;'>
<font color="#000000">online</font></a>
<!-- FIM CONTADOR -->
&nbsp;<p>&nbsp;</div>
<p align="left" style="margin-top: -3px; margin-bottom: -3px">&nbsp;<div align=center>
&nbsp;</div>
<p align="left">&nbsp;</div>
<script type="text/javascript">
var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www.");
document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E"));
</script>
var pageTracker = _gat._getTracker("UA-5774876-1");
pageTracker._trackPageview();
</script>
</font>
</body>
</html>
I'm still having a lot of trouble understanding what you want.
On http://7cr9.com/exp1.php is this the latest topics list:
And if so, are you trying to get it to display on http://7cr9.com/Home.php?
I suspect Frontpage is actually the cause of the problem here. Frontpage is notoriously bad at handling PHP code. I wouldn't normally recommend this because I think it is a "quick fix" and a bit messy, but seeing you use Frontpage you might be able to integrate it in a visually pleasing fashion... what I am alluding to is using an iframe. That is, putting the "last topics" code on a page by itself and then including that page in an iframe. Then you can separate the PHP from the html and it should stop the problems from happening.
Mary17
Thanks for the answer.
Yes, what I'm trying to do is to display what's on http://7cr9.com/exp1.php on http://7cr9.com/Home.php without errors, like you said.
About the iframes thing, I'm sorry but I dont know anything about it. If you say that it would delete the errors, the I wnat to try it ... Could you help step by step doing it?
Thanks again,
Mary
Mary17
Hey there,
I thought I'd publish here that I think I solved the problem. And used a different code form yours, but published here so that other people can see to. I found this on http://www.hawkee.com/snippet/5344/ here it is:
        // How Many Topics you want to display?
        $topicnumber = 5;
        // Change this to your phpBB path
        $urlPath = "/phpbb";
        // Database Configuration (Where your phpBB config.php file is located)
        include 'phpbb/config.php';
        $table_topics = $table_prefix. "topics";
        $table_forums = $table_prefix. "forums";
        $table_posts = $table_prefix. "posts";
        $table_users = $table_prefix. "users";
        $link = mysql_connect("$dbhost", "$dbuser", "$dbpasswd") or die("Could not connect");
        mysql_select_db("$dbname") or die("Could not select database");
        $query = "SELECT t.topic_id, t.topic_title, t.topic_last_post_id, t.forum_id, p.post_id, p.poster_id, p.post_time, u.user_id, u.username
        FROM $table_topics t, $table_forums f, $table_posts p, $table_users u
        WHERE t.topic_id = p.topic_id AND
        f.forum_id = t.forum_id AND
        t.forum_id != 4 AND
        t.topic_status <> 2 AND
        p.post_id = t.topic_last_post_id AND
        p.poster_id = u.user_id
        ORDER BY p.post_id DESC LIMIT $topicnumber";
        $result = mysql_query($query) or die("Query failed");
        print "<table cellpadding='3' cellSpacing='2' width='640'>";
        while ($row = mysql_fetch_array($result, MYSQL_ASSOC)) {
        echo  "<tr valign='top'><td><font face=\"Verdana, Arial, Helvetica, sans-serif\" size=\"1\"><font color=\"#FFCC00\"><b><a href=\"$urlPath/viewtopic.php?f=$row[forum_id]&t=$row[topic_id]&p=$row[post_id]#p$row[post_id]\" TARGET=\"_blank\">" .
        $row["topic_title"] .
        "</a></td></font></b><td><font face=\"Verdana, Arial, Helvetica, sans-serif\" size=\"1\"><font color=\"#C0C0C0\"> by: <a href=\"$urlPath/memberlist.php?mode=viewprofile&u=$row[user_id]\" TARGET=\"_blank\">" .
        $row["username"] .
        "</td><td><font face=\"Verdana, Arial, Helvetica, sans-serif\" size=\"1\"><font color=\"#C0C0C0\">" .
        date('F j, Y, g:i a', $row["post_time"]) .
        "</td></tr></font>";
        print "</table>";
        mysql_free_result($result);
        mysql_close($link);
I thought to share it with so many others who are looking for it. It's extremly useful to apply. I use frontpage, I just created a new layer and copied this code in there, and it worked. Some images didn't appear but it was just a matter of adjusting "it's adress" (like on my documents...).
I have a doubt, which is:
On the page http://7cr9.com/2.php there are shown the latest topics, authors, and the date it was published.
I wanted to show only the topic title, and not the author or date. Could you tell me which part of the code should I delete or change to do so?
Thanks,
Mary
