[BETA 4] Calendar Alerts MOD v0.0.4
Thanks plasmino, I've updated the first post :D
pluto
Hello,
When I want to cancel a deletion warning, I get this error:
Général error
template->_tpl_load_file(): File ./styles/acidtech/template/.html does not exist or is empty
Thank you to you.
Marije
Hi, great mod!
Perfect for me, who always forgets everything haha
I have 2 questions
Is there a dutch translation?
And can i edit it somehow to make it only for the admin, not the other users?
Marije
Does anyone know these anwers?
Hi, sorry for the delay in replying. I don't think there is Dutch, every translation I know of is in this post: http://forums.cricketmx.com/viewtopic.php?f=63&t=4746
And when you say make it only for the admin, do you mean you want alerts to appear only to admins or you want both the "add alerts" page in the UCP and the alerts on the index to only appear to admins? Just let me know which it is - it is a fairly easy change to implement and I will tell you which code you will need to edit :)
Thanks for registering at CMX Marije, welcome to the forum :)
Marije
Thanx for the reply
I want it to be only for admin, both the page in UCP to add an alert, and to see the alert.
pluto
pluto wrote:Hello,
Général error
Thank you to you.
Hello,
Person for the solution ?
Thank you very much.
Hi pluto, have you uploaded ucp_alerts.html to styles/acidtech/template/ :?:
pluto
Yes, this file "ucp_alerts.html" is indeed in: styles/acidtech/template/
Thank you.
What about confirm_body.html?
pluto
confirm_body.html is OK also, It's just the cancellation :|
Otherwise the mod to work perfectly 8)
Edit: I did a test on your forum and when I delete an alert and click cancel I get a blank page.
Try this:
open ucp_alerts.php and find:
			if (confirm_box(true))
				$sql = "DELETE FROM " . ALERTS_TABLE . "
						WHERE alert_id = " . request_var('delete', 0) . "
						AND user_id = " . (int) $user->data['user_id'];
				$db->sql_query($sql);
				// Clear the cache
				$cache->destroy('sql', ALERTS_TABLE);
				trigger_error( sprintf($user->lang['UCP_ALERTS_DELETE_SUCCESS'], "<a href='" . append_sid($this->u_action) . "'>", "</a>") );
After add:
 trigger_error('Test');
Now try it, you should get the message 'Test' (if this works then I will give you the redirect code :))
pluto
Indeed, when I click the little X to delete the word "test" appears :)
Thank you.
Now replace the line:
With
redirect(append_sid("{$phpbb_root_path}ucp.$phpEx", "i=alerts&mode=alerts"));
Does that fix it? :)
pluto
No sorry, nothing happens, this has no effect :|
Note: I do not have the phrase "Are you sure you want to delete this alert?"
