Error after taking quiz
BathroomNinja
Everything apeared to install fine. I double checked that I copied everything over correctly. There was a red line when I installed the quiz (first time user), on the second line. I am able to create quizes and then play them. However, when I click 'submit quiz' (/quiz.php?mode=results in the url), I get the following:
Could not obtain the user id
An Error Occurred
DEBUG MODE
SQL Error : 1146 Table 'apdcadetsboards.apdphpbb_quiz_statistics' doesn't exist
SELECT stats_id FROM apdphpbb_quiz_statistics ORDER BY stats_id DESC LIMIT 1
Line : 31
File : functions_quiz.php
So, I went to take a look at line 31 in functions_quiz.php, but I can't figure it out. I am running on dreamhost, with PHP 5.1.2
I love the quiz software, great work! I'm sure I'm doing something wrong here, any help would be nice. Thank you in advance.
BathroomNinja
Hoorah! I fixed it!. Here is how I fixed my issue..
As I mentioned, I had a red line while installing. I should not have ignored that line. The line that was red was this one:
CREATE TABLE apdphpbb_quiz_statistics ( `stats_id` int(5) NOT NULL default '', `quiz_id` int(10) NOT NULL default '', `user_id` int(10) NOT NULL default '', `stats_correct` INT(5) NOT NULL default '0', `stats_incorrect` INT(5) NOT NULL default '0', `stats_percentage` INT(3) NOT NULL default '0');
So, I logged into my phpmyadmin for my domain and checked the tables. quiz_statistics was not there. hmmm. So, I tried to manually run the SQL commands. It shot back at me that the default for 'stats_id' was invalid. So, I changed '' to '0' and ran it again. This time, 'quiz_id' was invalid. Dur! so, I stuck in a 0 for the other ones that where only '' and ran it again. It looked like this:
CREATE TABLE apdphpbb_quiz_statistics ( `stats_id` int(5) NOT NULL default '0', `quiz_id` int(10) NOT NULL default '0', `user_id` int(10) NOT NULL default '0', `stats_correct` INT(5) NOT NULL default '0', `stats_incorrect` INT(5) NOT NULL default '0', `stats_percentage` INT(3) NOT NULL default '0');
This time, eveything went through fine. I re-submitted my quiz and Tada! everything works great.
Again, thanks for the great mod, you have no idea how much this is going to help us.
I'm glad you fixed it, and I'm glad you like the MOD :)
djnoyze
I have the same problem, but I'm unsure of how you fixed it... What do I need to modify? I saw the same error you saw and kept on truckin' like an idiot.
I've tried to just reinstall the mod, but that didn't work either...
Here's my error:
An Error Occurred
DEBUG MODE
SQL Error : 1146 Table 'djnoyze.forum_quiz_statistics' doesn't exist
SELECT stats_id FROM forum_quiz_statistics ORDER BY stats_id DESC LIMIT 1
Line : 31
Have you tried running this (make sure to edit the table prefix first) in phpMyAdmin, like the above poster?
