[quote="I wrote"]STAGE ONE: Setting styles
The first step is to create a new file on your server named switcher.php and paste the following code into it. (Line wraps are marked ». –Ed.)
setcookie ('sitestyle', $set, time()+31536000, »
'/', 'yourdomain.com', '0');
header("Location: $HTTP_REFERER");
When it’s queried, this file will write a cookie for the user detailing which site style to use. The cookie is set to expire in one year, and then the script sends the user back to the referring page. All of this happens behind the scenes, so the user will never really “seeâ€
HTML usergroup
So, I make the file then upload it?
Ok, I'll tell y'all what happens
You know what I'm like with mods
I'm uploading them now...
Reading through your how-to post earlier, I think what I've done isn't going to work... I'll need to spend a lot of time on it tomorrow. It's nearly midnight here
I need to add all the theme info, *.css file location etc. This isn't going to be easyswitcher.php wrote:Parse error: parse error in /home/battye/domains/battye.jmstacey.net/public_html/themes/switcher.php on line 3
To test it go here: http://www.battye.jmstacey.net/themes/index.htm
Yep, the thing is, that script you mentioned:
That won't work because there's nothing there to redirect it to the appropriate page or css file, we need to do everything you mentioned on page four.Grinch wrote:<?php
So the css files need to be uploaded so it has something to redirect to??? Doesn't sound difficult but I am not an expert on this. All the code that is needed on the homepage is there according to that tutorial. Hmmm, I am sure we can get it worked out.
- Boozybaz
- Alcoholic
are you sure that source code is right?? looks kinda odd 2 me, and im sure its not closed properly... i have just work up from a HEAVY night so i could be wrong..
- Boozybaz
- Alcoholic
thats all good and well, but who are you?? i've not seen many/any of your posts b4, and before i add you 2 the usergroup i wanna know abit more about you, so i suggest you make a few more posts in the other forums and join in our disscussionsJoShUa!@#\123 wrote:I have extensive Microsoft FrontPage Knowledge and am willing to design the homepage
The *.css files are automatically uploaded with every theme. So they are already on the server. If you need the address for it, PM megrinch2171 wrote:So the css files need to be uploaded so it has something to redirect to??? Doesn't sound difficult but I am not an expert on this. All the code that is needed on the homepage is there according to that tutorial. Hmmm, I am sure we can get it worked out.
Boozy, are you going to add me to the group? Or are you leaving me out
