New WinMxGroup 3.0 DLL - Anti Fake Patch
Searcher
At last the problem of fake files is solved :)
Select what you require from the list there.
This patch works in conjunction with the WinmxWorld Blocklist and is able to be updated around the clock to keep the fake file flooders at bay.
No longer will you even see the fake listings.
I hope you all agree a stunning peice of work, pity it took so long to develope :)
No more need for a host file now peeps! 8)
* What's New in v3.0 *
*Remove fakes from your searches results!
*Still blocks the Cartels from flooding & attacking WinMX!
*Works on all operating systems
*Works on all WinMX versions.
*Works with IE7 beta 2.
*Install WinMX with patch or patch your existing WinMX.
*Patch third party software.
Thanks & a big :cheers: to KM , WinMXworld & WinMXgroup!!
Last edited by p2p-sharing-rules on Wed Jul 19, 2006 9:29 am, edited 1 time in total.
Thanks for the updates Searcher and P2P :)
Your welcome mate! :)
Searcher
Cheers mate, this one is the most popular patch ever and so far has dropped flooding by over 25% and climbing, cant get better than that :)
{MXC}michael
how does the patch work?
Well there is always http://winmx-help.no-ip.org :D
Searcher
Hi {MXC}michael.
From what I understand it checks the search results and looks for the originating IP this is not the same as the primary it may be passing through.
Once that is done it compares that IP to the blocklist and dumps the packet if its on the list, simple but effective.
Sorry for the delay in the reply :oops:
Here's the new address to download that latest version of the .dll patch: http://patch.winmxconex.com.
*edit The patch has a new installer now.
