BurianBB (name pending)
Ah, I think I might be firewalled from work. I'm still unable to connect here, but I can get to it remotely.
o ok. I thought I might have messed something up since I connect through my network to the site usually.nesman wrote:Ah, I think I might be firewalled from work. I'm still unable to connect here, but I can get to it remotely.
Ok Thanks. I am still adding functionality to some parts and trying to get the layout down. I will send you some files after I get it to a point where the layout is not going to keep changing.grinch2171 wrote:If you still need CSS help let me know. I don't have a ton of time to dedicate but will do what I can, just send me the files I need and a color scheme you would like and I'll try to make it happen.
It's looking good. I registered.
What does it do with 'website' in the profile? Is it just added to the users profile? Is it linked? It doesn't seem to be.
The profile editor seems to have two lines for 'avatar'.
I use CSS a little. If I can help, mail me.... I'll PM you an address.
Thanks for catching that avatar error. I don't know why I did that. As for the website, you just type in the address and it will display what you typed in as a link.Rat wrote:It's looking good. I registered.
Also I got your PM. I will send you some stuff once I get a simple layout down.
Would anyone mind just making a bunch of posts on the forum and tell me if anything gets messed up? I am trying to see if it tells you that there were posts made when you were not logged in.
I was looking for posted messages, but never the less thanks for finding that errormoongirl wrote:Burian without being logged in I got: No Topic or Forum Specified ,in Test Forum 1.
Is that what you wanted?
