errors trying to install
rotsblok
Got the following errors when trying to install the quiz mod:
1st. when uploading everything cannot acces board cos of the install folder (not big problem i think cos i can just go to the install/quiz_install.php)
2nd when running the installer i got the following errors:
Warning: main(./extension.inc): failed to open stream: No such file or directory in /home/***/domains/****/public_html/forum/install/quiz_install.php on line 26
Warning: main(): Failed opening './extension.inc' for inclusion (include_path='.:/usr/local/lib/php') in /home/****/domains/****/public_html/forum/install/quiz_install.php on line 26
Warning: main(./common.): failed to open stream: No such file or directory in /home/***/domains/****/public_html/forum/install/quiz_install.php on line 27
Warning: main(): Failed opening './common.' for inclusion (include_path='.:/usr/local/lib/php') in /home/****/domains/****/public_html/forum/install/quiz_install.php on line 27
Fatal error: Call to undefined function: session_pagestart() in /home/****/domains/*****/public_html/forum/install/quiz_install.php on line 29
how can i solve these problems?
Don't run it from the install folder. Run it from the root :)
The root is the same folder as viewtopic.php, viewonline.php etc :)
