hi
I installed the ultimate quiz mod but the correct answer is always the fourth.
what can I do to correct this ?
is it normal ?
is there a solution to random the answer placement ?
thanks for your help
i've no error and it seem to work without this problem
I've installed ultimate quiz mod + addon acp to make quiz from configuration panel.
I need help for quiz
Hi Kwal, are you using the latest version, 0.6.6?
It is most likely a conflict with one of your MOD's: gfportail-attachmod-quickreply-rank
actually there is no solution ?
i've tried to install it in a duplicate forum of mine without attach-mod
and it work well.
the answer change order one time and after stay at the same position even if I restart my login/logout
do you think it's possible to separate my forum and the quiz with only one database:
to have a root structure like
- my forum with gfportail
-:arrow: another portail with the same users sessions and a link for -->
-:arrow: the quizz pages
and it work well.
