Lunatic_UK1958 wrote:One other thing: Is it possible to log an ouka hosted room from within ouka and without having to use a 'bot'?
/login CoHost Pass Code
#usercmd inputpasscode CoHost Pass Code
/login Admin Pass Code
#usercmd inputpasscode Admin Pass Code
You will see these appear in your channel
22:29:39 <Admin> Passcode Accepted: JASON³666_13953 [CoHost]
22:30:06 <Admin> Passcode Accepted: JASON³666_13953 [Admin]
Admin Pass Code & CoHost Pass Code are actually the default settings for logins so be sure to change these by clicking onto the settings tab and were it says Admin Code and CoHost Code enter your own personal passwords here for both levels
PS. OK!. I Read this post again, did you mean?
Login? or simply log chat. . . think I got it right by your post saying "logging into" if I read it wrong to log chat from winmx 3.5x type /log <filename> and your logs will save to x:program\ files\winmx.
Hope that helps you or atleast clears things up
<Insert Abuse Here. . . >
