Azureus / Vuze
This is the place of which you speak I hope
http://sourceforge.net/project/showfile ... _id=279309
Just select you operating system and select a mirror site and thats all there is to it
Well spotted Grinch
Well spotted Grinch
- p2p-sharing-rules
- Moderator
*update* Azureus 2.4.0.2
What's new:
1.1 Faster Crash Recovery
By default Azureus will now only check parts of the file that were being actively downloaded the last time resume data was saved. The old behaviour of rechecking the whole file can be re-enabled via 'Files' configuration.
1.2 Bug fixes and performance improvements
Notable fixes:
Occassionally encrypted connections would send invalid data
Startup error 'no class found' fixed.
Data transfer to slow peers improved.
Note: New Windows launcher might require allowing "Azureus.exe" Internet access in your software firewall.
Full ChangeLog
Azureus Plugins
What's new:
Notable fixes:
Full ChangeLog
Azureus Plugins
Last edited by p2p-sharing-rules on Wed Jan 13, 2010 1:18 am, edited 2 times in total.
Reason: remove expired download links
- p2p-sharing-rules
- Moderator
Azurues v2.5.0.0 - August 21, 2006
1. What's new in Azureus 2.5.0.0
1.1 Send to Friend
A wizard to simplify sending a link to content to a friend or to embed in a web page (e.g. a blog).
1.2 Auto upload speed
This feature controls your upload speed based on the latency of your internet connection as gauged by pinging other members of the Distributed Database.
1.3 Other new features
* OSX: Open .torrent files into Azureus via Finder/Desktop/etc.
* 'Do not download' files handled more consistently with respect to download completion.
* Renaming of a download directories.
* Moving of data files on torrent removal from Azureus.
* Signed updates and plugins for improved security.
* Interface improvements - more information: date added, idle times, new info view, file piece view; more per-torrent options.
* Debug information generator.
* More in the changelog.
New remote control plugin - AzSMRC
1.4 Bug fixes and performance improvements
Notable fixes:
* LAN Peer Finder retains peers more effectively; explicit LAN peer identification.
* Reduced CPU usage when connected to large numbers of peers.
2. Full ChangeLog
Azurues Plugins List
Read a article on slyck's about the new Azurues v2.5.0.0.
1.1 Send to Friend
Notable fixes:
2. Full ChangeLog
Last edited by p2p-sharing-rules on Wed Jan 13, 2010 1:19 am, edited 2 times in total.
Reason: Remove expired download links.
- p2p-sharing-rules
- Moderator
- p2p-sharing-rules
- Moderator
I missed some updates on the v2.5.x.x releases.
The latest version is 2.5.0.4 that was released on Jan. 25 , 2007.
Windows Vista users, please get java (only the JRE) here.
windows v2.5.0.4a
Linux AMD64 v2.5.0.4
Linux 2.5.0.4
OSX 2.5.0.4
2.5.0.4 source.zip
AzureusPluginAPI.jar
Latest beta v3.0.0.8 March 19 2007
Download links:
v3.0.0.8.jar
v3.0.0.8 OSX.dmg
v3.0.0.8 Windows.exe
v3.0.0.8 source.zip
download links:What's new in 2.5.0.4
2.5.0.4 is a maintenance release to fix up a few minor, but relatively annoying problems with 2.5.0.2.
What's new in 2.5.0.2
1. What's new in Azureus 2.5.0.2
1.1 Less memory footprint
Most noteably, torrent piece information is now removed from memory when not used.
1.2 Minimum # of Simultaneous Active Downloads
The ability to always have at least x number of active downloads running.
1.3 New columns
* Custom user comment (My Torrents view)
* File extension (Files view)
1.4 Faster startup times on large lists
Startup times when Azureus has a large list of torrents is now faster (up to 400% faster in some cases).
Some plugins may negate this optimization if the plugin accesses every torrents information immediately at startup.
1.5 Other
* Various user interface improvements.
* Bug fixes.
* Less memory leaks.
1.6 Java 5.0 note
Java 5, Update 10 fixes a handle leak commonly seen in Azureus installations. It is highly recommended that you upgrade to this version or a later version. You can download the update at java.com.
2. Full ChangeLog
windows v2.5.0.4a
Linux 2.5.0.4
OSX 2.5.0.4
2.5.0.4 source.zip
Download links:
v3.0.0.8.jar
v3.0.0.8 OSX.dmg
v3.0.0.8 source.zip
- p2p-sharing-rules
- Moderator
Azureus 3.0.1.0 April 5 , 2007
Zudeo has been renamed to Vuze.
Here's the new url.
http://www.vuze.com/app
What's New:
Download links
Azureus_3.0.1.0_windows.exe 32-bit Windows
Azureus_3.0.1.0_macosx.dmg Mac OSX
Azureus3.0.1.0.jar
Azureus_3.0.1.0_source.zip
Here's the new url.
What's New:
FEATURE: Core | Option to clear stored tracker list used for creating torrents [amc1]
FEATURE: UI | Option to add full UPnP debug information to the log view [amc1]
BUGFIX: UI | Fixed issue where excessive file checks were being done when generating the torrent context menu [amc1]
FEATURE: Message boxes that are related to content now display a thumbnail
BUGFIX: "Currently Downloading" section of Home tab sometimes stopped drawing itself
BUGFIX: Password prompt (if option enabled) when restoring from system tray
BUGFIX: 2nd line of progress column no long displays "ETA" when non ETA info is shown
BUGFIX: Content in error state should be resumable now (once the user fixes the cause of the error)
Download links
Azureus3.0.1.0.jar
- p2p-sharing-rules
- Moderator
Azureus v3.0.1.2 April 17, 2007
What's New
Azureus v3.0.1.2 windows.exe
Azureus v3.0.1.2 macosx.dmg
Azureus v3.0.1.2.jar
Azureus v3.0.1.2 source.zip
What's New
Download LinksFEATURE: Core | Auto-speed: added control for forced-max network speed [Parg]
BUGFIX: Core | 100% CPU problem in network code under some conditions [Parg]
- p2p-sharing-rules
- Moderator
Hmm I missed a update the latest Azureus version is v3.0.1.4.
What's New:
Azureus3.0.1.4.jar
Azureus_3.0.1.4_macosx.dmg
Azureus_3.0.1.4_source.zip
Azureus_3.0.1.4_windows.exe
What's New:
Download links:2007.05.24 | Azureus 3.0.1.4
FEATURE: Core | Byte-level download control for Downloads [Parg]
FEATURE: Core | Speed tester wizard [ranul,Parg]
FEATURE: UI | Added "Transfers Bar" (similar to the "Download Bar") [amc1]
FEATURE: UI | Correctly identifies FoxTorrent and Blizzard Downloader peers [amc1]
FEATURE: UI | Determines version information for Bits On Wheels and Opera peers [amc1]
FEATURE: UI | Vivaldi view can use mouse wheel too zoom now (requires clicking on the view first) [TuxPaper]
FEATURE: UI | Date Completed column [TuxPaper]
FEATURE: UI | (Beta) Various Auto Speed algorithms [ranul]
FEATURE: UI | Auto-open MyShares if any shares [Parg]
CHANGE: Core | Handle 503s better with webseeds [Jochen Seifarth,Parg]
CHANGE: Core | Disable HTTP authentication dialog for webseeds [Parg]
CHANGE: Core | Reduce DHT registration counts for queued torrents [Parg]
CHANGE: UI | Running Azureus while azureus is already running now brings Azureus to front [TuxPaper]
CHANGE: UI | OSX: Make minimize to status bar icon hide the main window instead of putting it in the doc [TuxPaper]
BUGFIX: Core | Updater now works on Vista with security challenged users [TuxPaper]
BUGFIX: Core | Fixup "Get Right" webseed handling as per the spec [Jochen Seifarth]
BUGFIX: Core | Fixed bug which sometimes prevented corrupted torrents being removed properly [amc1]
BUGFIX: Core | Fix rare case where app dir on win32 could report wrong azureus dir on multi-az computers [TuxPaper]
BUGFIX: Core | Prevent upnp dispatcher queue from growing too large [Parg]
BUGFIX: Core | Limit UPnP write-request exec threads [Parg]
BUGFIX: UI | Fixed force starting a torrent via the Open Torrent Window options. [TuxPaper]
FEATURE: Speed Tester Wizard (Advanced UI)
FEATURE: Added Date Completed column to Library
FEATURE: Progressive download and streaming via UPnP Media Server
CHANGE: OSX: Make minimize to status bar icon hide the main window instead of putting it in the doc
BUGFIX: Updater now works on Vista with security challenged users
Azureus3.0.1.4.jar
- p2p-sharing-rules
- Moderator
New Azureus v3.0.1.6 June 21 , 2007
What's New
Azureus 3.0.1.6a windows.exe
Azureus 3.0.1.6 macosx.dmg
Azureus 3.0.1.6.jar
Azureus 3.0.1.6 source.zip
What's New
Download links:FEATURE: Core | IP Filter Autoloading. Supports DAT (eMule), P2P (PeerGardian, splist), and P2B v1,2,3 (Peer Gardian 2) formats. [TuxPaper]
FEATURE: UI | Option to display divider lines every 60 updates on the Statistics view [amc1]
FEATURE: Plug | Added helper class to make listening to download events across all downloads easier [amc1]
FEATURE: Core | Azureus AutoSpeed v2 Beta [ranul]
BUGFIX: Core | Plugin installation/updates using Vista [parg,tuxpaper]
Azureus 3.0.1.6.jar
It doesn't prompt you to use a certain language?Rat wrote:Why don't they do:CHANGE: Installer | NO buggering about with deciding which language you want to use without asking you
- p2p-sharing-rules
- Moderator
Azureus v3.0.2.0 Aug. 17 , 2007
What's New:
FEATURE: Core | Act on suspend/resume events on Windows [Parg]
FEATURE: Core | Added new AZ message to inform of bad pieces [Parg]
FEATURE: Core | Added new stacked HAVE message to reduce peer-peer overhead [Parg]
FEATURE: Core | IPv6 support - dht, version server, tracker and improved transport [Parg]
FEATURE: UI | New "Torrent" menu in the menu bar [amc1]
FEATURE: UI | New "Piece Distribution" subview in the pieces tab [The 8472]
FEATURE: UI | Auto-speed ping views in Tools->Statistics->Transfers when Auto Speed is enabled [Parg]
FEATURE: UI | "Clear Resume Data" menu option added [amc1]
FEATURE: UI | "Clear remembered save paths" option added (for the Open Torrent dialog) [amc1]
CHANGE: Core | Optimise memory usage for single-file downloads [Parg]
CHANGE: Core | Optimise memory usage for queued torrents (no need to keep resume data in memory) [Parg]
CHANGE: Core | Much better peer ID identification code added, many more clients now correctly identified [amc1]
CHANGE: Core | Changes made to identify some "fake" clients (or other clients which identify themselves in a problematic way) [amc1]
CHANGE: Core | Biased optimistic disconnect slightly against leechy peers [The 8472]
CHANGE: Core | Core changes in some places to allow "Default save path" to be used without requiring "Use default data dir" to be enabled [hasturkun]
CHANGE: Core | Reduce CPU usage when many (queued) torrents are present and in the the pieces view [The 8472]
CHANGE: Core | *nix: New startup script to detect Gecko/XULRunner and to allow better restarting [TuxPaper]
CHANGE: UI | UL/DL speed selection on right click of status bar changed from menu to scale widget. [TuxPaper]
Usage: (1) MouseDown+Drag+MouseUp (2) Click+Move+Click (3) Click+type number+Enter
CHANGE: UI | Open Torrent Window now asks to create directories if they don't exist yet, instead of evilly auto-creating them when you click the Browse button [The 8472]
CHANGE: UI | Added download status, distributed copies and completed piece count to the General torrent view [amc1, The 8472]
CHANGE: UI | User Comment field more useful in General torrent view - easy edit link, hyperlink formatting, auto-resizing [amc1]
CHANGE: UI | "Show Transfer Bar" menu option is now a checkbox menu item - so you can now hide the transfer bar using the menu item [amc1]
CHANGE: Plug | Added setVisible method for plugin menu items [amc1]
BUGFIX: Core | Fixed bug where renaming a download for a single file torrent would sometimes cause data to get out of sync and cause file errors [amc1]
BUGFIX: Core | Allow pipelined http seed requests to switch torrents [Parg]
BUGFIX: Core | Bootstrap DHT better when no contacts [Parg]
BUGFIX: Core | Fixed bug where renaming a download in some conditions would generate "Target is sub-directory" errors [amc1]
BUGFIX: UI | Fixed swarm view rendering bug where some incomplete peers were shown as full circles [The 8472]
BUGFIX: Plug | Fixed bug where previously removed child menu items would still be present when generating some menus [amc1]
Download links:
Azureus v3.0.2.0.exe
Azureus v3.0.2.0.dmg
Azureus v3.0.2.0 linux.tar.bz2
Azureus v3.0.2.0 linux-x86_64.tar.bz2
Azureus v3.0.2.0.jar
Azureus v3.0.2.0 source.zip
What's New:
Download links:
Thanks for the update P2P
- p2p-sharing-rules
- Moderator
Your welcome Battye.
