HijackThis lists the contents of key areas of the registry and hard drive--areas that are used by both legitimate programmers and hijackers. The program is continually updated to detect and remove new hijacks. It is important to note that you can easily remove things with this program that are needed by your computer so caution is advised when using this program.
http://forums.cricketmx.com/posting.php ... topic&f=59
[hijack removal tool]HijackThis
This program is intended to be used by advanced users. So, as me here stated, use this with extreme caution. There is a forum where you can post the hijackthis results and a knowledgeable person will inform you of what you can and cannot delete but I cannot seem to find it.
- ADi@/\/TUM
- Flower Child
Grinch if you post "HiJackThis Results" in a search you will find some sites
Here are a few sites you can go to post your results of HijackThis to see what can be deleted and what should be left alone...
Tech Support Guy Forums -
http://forums.techguy.org/t270314.html
Tech Support Forum
http://www.techsupportforum.com/showthread. php?t=13807&goto=nextoldest - 52k -
Tech Support Forum
