plasmino
no other debug error, now is perfect for me
quahappy
Happy, not Quappy
Happy, not Quappy
So far so good. Just testing it with normal user permissions now. No debug errors either (although I have debug off).
Quick question: Where is UQM configuration settings in ACP? :)
quahappy wrote:So far so good. Just testing it with normal user permissions now. No debug errors either (although I have debug off).
ACP modules are on the to-do list for the next version. At the moment the configuration values can be adjusted manually in includes/quiz/quiz_configuration.php:
		$this->qc_config_value = array(
			'qc_minimum_questions'		=> 3,
			'qc_maximum_questions'		=> 5,
			'qc_maximum_choices'		=> 3, // maximum multiple choices
			'qc_show_answers'		=> 1, // show the answers after a quiz
			'qc_quiz_author_edit'		=> 1, // allow the author to edit their own quiz
			'qc_admin_submit_only'		=> 0, // only administrators are allowed to submit quizzes
			// Cash compatibility
			'qc_cash_enabled'		=> 0, // enable cash functionality
			'qc_cash_column'		=> 'user_points', // associated column in the users table
			'qc_cash_correct'		=> 20.54, // cash gained for a correct answer
			'qc_cash_incorrect'		=> 10, // cash REMOVED for an incorect answer
Edit: for the following values ('qc_show_answers', 'qc_quiz_author_edit', 'qc_admin_submit_only', 'qc_cash_enabled') 1 denotes "true" or "yes" while 0 denotes "false" or "no".
plasmino
quahappy wrote:Quick question: Where is UQM configuration settings in ACP? :)
nice question :D
for italian language
it.zip
(2.14 KiB) Downloaded 1109 times
Thank you for the Italian translation plasmino :)
I mentioned that the ACP module hadn't been written yet in the private message :D
The next version I hope to have:
- UMIL (instead of the quiz_installer.php file)
- ACP modules (at the moment I'm storing the configuration values in the quiz_configuration.php file)
- Categories (every quiz is going into one category right now)
- Input answer (only multiple choice/true+false are present in 2.1.0 because I realised if a user tried to use a number as input answer it could potentially give an error, because the text box names are a number relating to a particular answer... so I need to figure out a way to circumvent that)
- Perhaps time limits... I'm not sure yet.
plasmino
ops, I had not read the pm ^ _ ^
sorry
:lol:
quahappy
Happy, not Quappy
Happy, not Quappy
Thanks battye. Had overlooked that. :)
(I still had one remaining old UQM configurations file that appeared in ACP > General > Board Configuration > Board features. Threw me off track. Now removed).
After a little convincing ( :wink: ) I've decided to add a couple more features before the first public release (namely categories and ACP functionality). Of course, if anyone wants an advance copy of Alpha 1 to help with testing that is not a problem - just let me know and I will send you the files.
I've already implemented categories (I did that tonight), so I just need to get the ACP modules working now before I make the public release. Here are some screenshots of the categories:
Categories - selected when adding or editing a quiz
What categories look like on the index - please note that an individual category can be viewed by clicking the category name
While I am posting screenshots, here is what the cash implementation looks like:
Cash results (after a user plays a quiz)
Abera
Sorry... I should have posted here. Yes please send me the files.
Thanks
I've sent you a PM Abera :)
Thanks
Abera
battye wrote:I've sent you a PM Abera :)
Thanks
This is what I get going live, or local:
It here a query that I can do manually?
[phpBB Debug] PHP Notice: in file /quiz_installer.php on line 55: mysql_query() [function.mysql-query]: Access denied for user 'SYSTEM'@'localhost' (using password: NO)
[phpBB Debug] PHP Notice: in file /quiz_installer.php on line 55: mysql_query() [function.mysql-query]: A link to the server could not be established
There was an error creating table phpbb_quiz...
There was an error creating table phpbb_quiz_questions...
There was an error creating table phpbb_quiz_statistics...
Installation is finished with errors.
Most likely me. #-o
Thanks
quahappy
Happy, not Quappy
Happy, not Quappy
Abera wrote:Most likely me. #-o
Thanks
Nope - not you. Same happened to me and battye kindly pointed out what I needed to do (via PM):
battye wrote:Open quiz_installer.php and find if( !mysql_query($query) )
Replace with if( !$db->sql_query($query) )
As long as the tables don't already exist, that should work fine :)
The only reason I was using mysql_query was because $db->sql_query doesn't return errors in the way I wanted. Of course, mysql_query goes against the coding standard because it's database specific - but once I make a UMIL file that will no longer be a problem
As battye mentioned, installation issue won't be encountered when the UMIL file is created.
Hope that helps. :)
I've playtested as Administrator and User and can confirm I have not encountered any issues. However, if I play and Submit a quiz without answering one or more questions, the results page shows as:
Which home computer is the oldest?     Incorrect: You selected , the correct answer was Sinclair ZX81.
Can "No answer given" or similar be displayed or not show "You selected ." at all when no answer is given?
Also, I noticed one additional variable missing from Configuration settings: Can quiz author play own quizzes. Is this intentional? :)
Abera
Thanks
Hope that helps. :)
That did it. :wink:
Thank you
Abera
Off subject here, but quahappy... You have a Sinclair? My very first with all of the 4 meg and don't forget the burst mode. Then the Tandy. I don't remember the number on. Sold it in 1984. Then to the Vic 20, Commodore 64 and 128. I still have all of them and peripherals that go with them. Those were the days my friend. :)
The quiz is running fine for me.
Thanks
plasmino
great news
