phpBB3 - Displaying post on external pages
Postby crysis » Tue Feb 16, 2010 5:28 am
Hi all,
I was wondering if someone can help explain/solve a php related question.
I have followed this tutorial at http://blog.phpbb.com/2009/11/09/how-to ... nal-pages/ by battye
My site is made in html and css, as I dont know any php.
It took a while to work, But got it working perfectly UNTILL, I went to put a footer on the page in html under the php which I had to insert, and nothing displays below the last bit of php,
Which in this case is ..
page_footer();
And if I delete it, then the posts from the forum dont display.
Do you know what I mean?
How can I get around this?
Any help or a point in the right direction would make my day.
Thanks in advance.
crysis
Re: phpBB3 - Displaying post on external pages
Postby battye » Tue Feb 16, 2010 9:14 am
Hi,
I understand what you are saying.
Try this:
OPEN style/prosilver/templates/overall_footer.html (if you don't use prosilver, open the footer file of whichever template you use).
now FIND
<div>
   <a id="bottom" name="bottom" accesskey="z"></a>
   <!-- IF not S_IS_BOT -->{RUN_CRON_TASK}<!-- ENDIF -->
</div>
AFTER ADD
<!-- IF S_SHOW_CUSTOM_FOOTER -->enter your HTML/CSS code for your footer here<!-- ENDIF -->
Now, in whatever PHP file you add my tutorial code in before the page_footer() call (so the line before) add this:
   $template->assign_vars(array(
      'S_SHOW_CUSTOM_FOOTER'         => true,
Re-upload and purge the cache in the ACP.
Does that make it work correctly?
Postby crysis » Wed Feb 17, 2010 8:12 am
Thanks for that, But It's still not displaying, Should it look like this....
overall_footer.html
<div>
        <!-- IF S_SHOW_CUSTOM_FOOTER --><h1>Hi, this is testing the new php footer</h1><!-- ENDIF -->
</div>
And the page with your php tutorial done on...
page_footer();
crysis
Postby battye » Wed Feb 17, 2010 8:44 am
Hi,
Add the " <!-- IF S_SHOW_CUSTOM_FOOTER --><h1>Hi, this is testing the new php footer</h1><!-- ENDIF -->" after the </div>
And don't forget to go into the ACP index and press Purge Cache.
Postby crysis » Mon Feb 22, 2010 5:53 am
It's still not working :cry:
I must be doing something wrong, or haven't added something in, Can you think of what I've missed?
crysis
Postby battye » Mon Feb 22, 2010 5:56 am
What happens if after the </div> you add:
<h1>Show: {S_SHOW_CUSTOM_FOOTER}</h1>
If it is working, hopefully you will see Show: 1
Postby radiofranky » Sun Mar 07, 2010 6:59 am
the external pages display write up was nice. however, I was wondering if is possible to display "text" as the link to the topic itself.
For example, I would like the "last post text" to be truncated and become the like to the post link.
Also, i was wondering is possible to display "viewed number"
thanks
radiofranky
Postby crysis » Fri Dec 10, 2010 12:48 am
Hi battye,
I gave up on this problem and made do before.
Now im re-designing the site and I must get this solution working. Its doing my head in :lol:
I gone through all of your steps above carefully, and yet still its not working.
Can you think of anything it might be? I have no mods installed, its just a simple phpbb installation and the style is called 'static'.
Regards
Ps.
This works. It only displays at the bottom of the forum.
battye wrote:What happens if after the </div> you add:
crysis
Users browsing this forum: No registered users and 2 guests
