SDf;ljkshgd;lafj;sgj;f ;lk;lasdlfa
sf
dfjasdfjd;seoifa'j klvjc'o89u [4095u9t0usj
fdg
3950u[4w9tu[g9jfdg
Yep keyboard works
BAHAHDVBAHSdBL!K#BL:KJFD;lksdjfldfj
I totally agree with you Bacon, you always know that your keyboard is working if you use that particular combination of letters and characters, for example:
That code above will verify if your keyboard is working, however:
Will not. It is very complicated when it comes to keyboard testing
sf
fdg
3950u[4w9tu[g9jfdg
sf
fdg
3950u[4w9tu[i9jfdg
test
test
- Red XIII
- Sultan Ruler Of The Poles!
look the same to mebattye wrote:I totally agree with you Bacon, you always know that your keyboard is working if you use that particular combination of letters and characters, for example:
That code above will verify if your keyboard is working, however:Code: Select all
SDf;ljkshgd;lafj;sgj;f ;lk;lasdlfa sf dfjasdfjd;seoifa'j klvjc'o89u [4095u9t0usj fdg 3950u[4w9tu[g9jfdg
Will not. It is very complicated when it comes to keyboard testingCode: Select all
SDf;ljkshgd;lafj;sgj;f ;lk;lasdlfa sf dfjasdfjd;seoifa'j klvjc'o89u [4095u9t0usj fdg 3950u[4w9tu[i9jfdg
