Great news!All seams to work (just testing) Greetings
Thanks for the translation Lugsciath
Good evening,
First of all forgive me for my broken English.
I download and install the MOD Ultimate Quiz MOD v2.0.0 (Beta 2 released Dec 29, 09), all works fine if I activate a part of the accounting issues or have this error message
If I remove the following code quiz.php it works
An option to empty the cache to detect cheating or after a few minutes or manually, via the ACP will Tella feasible?
In advance thank you for your future answers
On the other hand, on some quiz test I did I get this message and I do not know how to cancelErreur générale
SQL ERROR [ mysql4 ]
Unknown column 'user_points' in 'field list' [1054]
SQL
UPDATE phpbb_users SET user_points = user_points + -2 WHERE user_id = 2
BACKTRACE
FILE: includes/db/mysql.php
LINE: 174
CALL: dbal->sql_error()
FILE: quiz.php
LINE: 769
CALL: dbal_mysql->sql_query()
I have put on the Time Limits option to 0 but nothing changes there by cons as the image shows the quiz is marked as savedou are seeing this error because one of several events might have occurred: - A cheating attempt may have been detected. You cannot leave a quiz and later re-enter it without going through the save process. - You have tried to resubmit a quiz that you have exceeded the time limit on - You have already played this quiz, and the admin does not allow multiple attempts.
($row['quiz_time_used'] > 0 && $row['quiz_progress_stop_time'] == 0) In advance thank you for your future answers
Are you using a points system? If so, the only reason you get the SQL error is because you are using a column other than "user_points". Do you know which column you are using? If this doesn't make sense I can explain in further detail.
"Sauvegarde" or "saved" will appear on all saved quizzes. The cheating attempt will appear if you have quit a quiz without either saving it or submitting it.
No I do not use any other point system and install the forum is brand new.battye wrote:Are you using a points system? If so, the only reason you get the SQL error is because you are using a column other than "user_points". Do you know which column you are using? If this doesn't make sense I can explain in further detail.
It'll be the query to create this field, I can not find in phpbb-users?
Indeed I leave without a quiz to fill completely!battye wrote:"Sauvegarde" or "saved" will appear on all saved quizzes. The cheating attempt will appear if you have quit a quiz without either saving it or submitting it.
Have not you planned a system to reset it in the ACP?
Because even trying to retrace a quiz marked as saved I can not
I find how close the following error message
and replace
By cons I do not know where is the statistics of the points awarded?
We must open the file quiz.php searchErreur générale
SQL
BACKTRACE
LINE: 174
FILE: quiz.php
LINE: 769
$statistical_sql[] = "UPDATE " . USERS_TABLE . " SET $cash_field = $cash_field + $cash_gained_or_lost WHERE user_id = " . $user->data['user_id']; Code: Select all
if(isset($data['points']))
} Stef67 wrote:Indeed I leave without a quiz to fill completely!battye wrote:"Sauvegarde" or "saved" will appear on all saved quizzes. The cheating attempt will appear if you have quit a quiz without either saving it or submitting it.
- quahappy
- Happy, not Quappy
Do you have in ACP > UQM "Turn on points compatibility" set to YES? Change to NO and the error will no longer appear. You need to have a Cash/Points MOD installed for this feature to work.Stef67 wrote:I find how close the following error message
Erreur générale
SQL
BACKTRACE
LINE: 174
FILE: quiz.php
LINE: 769
Hope that helps.
Just a little bug remains hm found in acp in UQM section
ACP_QUIZ_INDEX_TITLE
Solution
Open
languages/en/common.php
(or any other language file eg. languages/de/common.php
seach
'QUIZ_EXPLAIN' => 'Ultimate Quiz MOD',
add before
'ACP_QUIZ_INDEX_TITLE' => 'Ultimate Quiz Mod'
Have fun.
Edit: Corresponding evt. with
? Double Var ?
Solution
Open
seach
add before
Have fun.
? Double Var ?
- quahappy
- Happy, not Quappy
If you have correct permissions, go to ACP > System > Module management > Administration Control Panel. Click on edit (green cog) for ACP_QUIZ_INDEX_TITLE. Change Module Language Name to: Ultimate Quiz MOD then click on Submit.
The file that contains ACP_QUIZ_INDEX_TITLE is in includes/acp/info/acp_quiz.php
FIND:
REPLACE WITH:
I'm not certain but I think altering the above file won't make any difference unless it's a clean install of UQM for "Ultimate Quiz MOD" to appear in ACP tab instead of ACP_QUIZ_INDEX_TITLE
FIND:
'index' => array('title' => 'ACP_QUIZ_INDEX_TITLE', 'auth' => 'acl_a_board', 'cat' => array('')),Code: Select all
'index' => array('title' => 'Ultimate Quiz MOD', 'auth' => 'acl_a_board', 'cat' => array('')),If you don't ask...
Lugsciath, I am aware of that, thanks. I will probably use your fix for beta 3, but mtrs suggested a complete re-structuring of the language files which would be more efficient so I will probably implement that in Beta 4.
quahappy, I think your code changes should work too. The only reason it isn't a good idea is because you shouldn't hard code language strings
- quahappy
- Happy, not Quappy
I originally suggested this some time ago here. It would certainly be a nice addition and possibly worth considering for a future release of UQM.Stef67 wrote:I have a suggestion for this MOD.
When one accepts the view of responses after a quiz, it'll be nice to have possibility to add supplementary information in addition by providing answers to more understanding of the question
Incorrect I have not seen since in fact I do not practice good English and I use an online translator to supplement my level is not very good.
Yes it will be even more for a larger version Proshian such as to offer a link or a complement to true or false in stating why the comment! !
subvertbeats
Hello battye,
First of all thanks to you and other contribs for all your hard work on this mod.
It looks like something that will fit the bill for a forum I run.
I just have one question, before I go ahead and download and try to install the beta.
Is it possible to run a competition and gather answers from users, and only later input the correct answers?
The use case I want to support is for users competing in predictions rather than standard type quizzes.
Thanks in advance
Thanks in advance
