With the links, the code is no problem it is only the image that goes next to it. At the moment I have no image
I thought it was utf8_normalize_nfc() - that was what I was using in the ACP, yet it still doesn't work. I'm not sure why but I am investigating it.
maybe that it Battye ?
- icon_quiz.gif (917 Bytes) Viewed 12076 times
Yeah, something like that with a thicker border around it - about as thick asxpmen wrote:maybe that it Battye ?
the problem of accents in ACP was resolved
This is not me who find but my friend sjpphpbb
replace your file:
includes/acp/acp_quiz.php
We are still looking for the same problem in quiz.php
replace your file:
We must review the system of play, sometimes (but not always), I can play more in the same quiz: roll:
For example, if I responded to the questionnaire, then I go back a page back, I can play indefinitely.
should be invisible quizzes already answered by the member, and leave only those unanswered
or leave the link not active
there is still much work Battye, I will try to help with the little knowledge I have
excuse my very bad English, I use google translator
I know, I have already added a "quiz play once" for the next beta. I've also added points functions. You can see the points option in this screenshot, the quiz play once option is a few above that.xpmen wrote:We must review the system of play, sometimes (but not always), I can play more in the same quiz: roll:
I know there is still much work.
the problem of accents quiz.php is also set a thank you mtrs
With regards to the PHP Notices some people are getting, as an interim measure (something that will fix it until I release the repaired script)
OPEN quiz.php
FIND
AFTER ADD
If you aren't getting any errors don't worry about this, it's only for people who have a PHP setup that reports certain types of errors. It's not a serious problem, it just means there are a few bits of code where I haven't initialised some variables properly.
OPEN quiz.php
FIND
include($phpbb_root_path . 'includes/quiz_stats_class.' . $phpEx);Code: Select all
error_reporting(E_ERROR | E_WARNING | E_PARSE);CricketMX.com in 2022: Still the home of bat's, rat's and other farmyard animals!
I found another bug
If sending a quiz without selecting a category, He adds that many in the db !
xpmen wrote:I found another bug
joebart wrote:And 3 bugs :
1/ One of my members managed to post a quiz outside a category. So nobody can go into the quiz.
2/ One of my members managed to make a question with 4 answers but she has not selected the good reply. Se was able to submit the quiz.
3/ We are 4 to have been able to play three time the same quiz...
xpmen, that icon should be okay. It is fine for here at CMX, but for all prosilver forums it might need to be blue or grey.
I've added UTF8 support (sorry for the delays in that) and it is ready for the next beta. You can test it at http://forums.cricketmx.com/quiz.php - should be working fully. I even tested with accents myself
Here are the changes for beta 2 so far. Thanks to quahappy for finding the bugs
- BUG: division by zero in quiz_stats_class is fixed
- BUG: time limits feature refined
- BUG: acp will not accept strange min/max combinations
- BUG: being able to post outside of a category has been fixed
- FEATURE: delete categories
- FEATURE: cash/points function available with options of points per correct answer and points deducted per incorrect answer (admin option)
- FEATURE: users can only play a quiz once (admin option)
- FEATURE: the word "saved" appears next to all quizzes that have been saved for play at a later date
- NEW: UTF-8 support
