Yeah! Now its more informative , waiting on the basic alpha ...Information
It appears you have tried to submit this quiz multiple times.
Greetings
Uwe
Great! Look forward to that.battye wrote:I have done the stats page. In fact, I am happy to release the pre-alpha version tomorrow (it's after midnight now, so I will package it in the morning).
* Ultimate Quiz MOD [English]
* @package language
* @version $Id: quiz.php, battye (c) 2004, 2005, 2008
* @copyright (c) 2008 battye, CricketMX.com
* @license http://opensource.org/licenses/gpl-license.php GNU Public License
* DO NOT CHANGE
if (!defined('IN_PHPBB'))
exit;
if (empty($lang) || !is_array($lang))
$lang = array();
// DEVELOPERS PLEASE NOTE
// All language files should use UTF-8 as their encoding and the files must not contain a BOM.
// Placeholders can now contain order information, e.g. instead of
// 'Page %s of %s' you can (and should) write 'Page %1$s of %2$s', this allows
// translators to re-order the output of data while ensuring it remains correct
// You do not need this where single placeholders are used, e.g. 'Message %d' is fine
// equally where a string contains only two placeholders which are used to wrap text
// in a url you again do not need to specify an order e.g., 'Click %sHERE%s' is fine
$lang = array_merge($lang, array(
'QUIZ' => 'Quiz',
// Functions
'SELECT_A_CATEGORY' => 'Wybierz kategorię',
'SELECT_A_CATEGORY_EXPLAIN' => 'Wybierz taką kategorię, do której najbardziej będzie pasował twój quiz.',
// Submit quiz
'SELECT_NUMBER' => 'Ilość pytań',
'SELECT_NUMBER_EXPLAIN' => 'Możesz wpisać od <strong>%1$s</strong> do <strong>%2$s</strong> pytań w tym quizie. Ile pytań chciałbyś dać?',
'SUBMIT_QUIZ' => 'Wyślij quiz',
'SELECT_QUIZ_NAME' => 'Wybierz nazwę dla tego quizu',
'SELECT_QUIZ_NAME_EXPLAIN' => 'Ta nazwa widoczna będzie na liście quizów. Wybierz nazwę krótką, ale taką, która pozwoli użytkownikom zorientować się, o czym jest ten quiz.',
'ENTER_QUESTION' => 'Wpisz swoje pytanie',
'IS_TRUE_FALSE' => 'Pytanie typu prawda czy fałsz',
'NOT_TRUE_FALSE' => 'Aby oddzielić od siebie opcje wielokrotnego wyboru, umieść każdą z nich w nowej linii. W przypadku pojedynczego wyboru wpisz tylko jedną linijkę tekstu.',
'SUBMIT_INFORMATION' => 'Wpisz pytania w każdym z %1$s pól widocznych poniżej. W przypadku pytań typu prawda czy fałsz, zaznacz opcję - nie trzeba wtedy wpisywać nic do znajdującego się wyżej pola. W przypadku pytania z pojedynczym wyborem po prostu wpisz odpowiedź do większego pola. W przypadku pytań z możliwością zaznaczenia kilku odpowiedzi musisz wpisać %2$s różnych odpowiedzi, umieszczając każdą z nich w nowej linijce. Po wysłaniu tej strony będziesz musiał zaznaczyć prawidłowe odpowiedzi w każdym z pytań.',
'VERIFY_SUBMIT_INFORMATION' => 'Przy pytaniach z możliwością zaznaczenia kilku odpowiedzi wybierz poprawną odpowiedź, klikając w pole znajdujące się po lewej stronie obok odpowiedzi. Przy pytaniach typu prawda czy fałsz musisz wybrać, czy odpowiedź jest fałszywa czy prawdziwa. Wpisane odpowiedzi nie muszą być weryfikowane, zostaną zapisane w takiej formie, w jakiej zostały podane.',
'TRUE_FALSE_TRUE' => 'Prawda',
'TRUE_FALSE_FALSE' => 'Fałsz',
'QUIZ_SUBMISSION_SUCCESSFUL' => 'Twój quiz został zapisany w bazie.<br /><br />%sWróć do strony głównej quizów.%s',
'OUTSIDE_QUESTION_PARAM' => 'Nie wybrałeś liczby spomiędzy <strong>%1$d</strong> a <strong>%2$d</strong>, wróć i spróbuj ponownie.',
'NUMBER_QUESTIONS_UNDEFINED' => 'Nie została podana ilość pytań w tym quizie, wróć do poprzedniej strony i popraw ten błąd.',
'TOO_MANY_CHOICES' => 'Wybrałeś <strong>więcej niż %s</strong> opcji! Wróć i popraw ten błąd, inaczej jedna z <strong>błędnych</strong> odpowiedzi zostanie losowo usunięta.<br /><br />',
'EMPTY_QUESTION' => 'Jedno lub więcej pytań nie zostało wypełnione! Naciśnij WSTECZ w swojej przeglądarce by powrócić do poprzedniej strony, i upewnij się że żadne z pól nie pozostało puste.',
'EMPTY_ANSWER' => 'Jedną lub więcej odpowiedzi pozostawiłeś pustą. Naciśnij WSTECZ w swojej przeglądarce by powrócić do poprzedniej strony, i upewnij się że żadne z pól nie pozostało puste.',
* Ultimate Quiz MOD [French]
* @package language
* DO NOT CHANGE
exit;
$lang = array();
'QUIZ' => 'Quiz',
// Functions
'SELECT_A_CATEGORY' => 'Selectionner une catégorie',
'SELECT_A_CATEGORY_EXPLAIN' => 'Sélectionner une catégorie qui correspond le mieux à votre genre de quiz.',
// Submit quiz
'SELECT_NUMBER' => 'Nombre de questions',
'SELECT_NUMBER_EXPLAIN' => 'Vous pouvez entrer entre <strong>%1$s</strong> et <strong>%2$s</strong> questions dans le quiz. Combien de question voulez vous inclure?',
'SUBMIT_STEP_1' => 'Etape 1 sur 3 - Entrer votre quiz!',
'SUBMIT_STEP_2' => 'Etape 2 sur 3 - Entrez les réponses!',
'SUBMIT_STEP_3' => 'Etape 3 sur 3 - Vérifiez si tout est correct!',
'SUBMIT_QUIZ' => 'Envoyer un quiz',
'SELECT_QUIZ_NAME' => 'Selectionner un titre a votre quiz',
'SELECT_QUIZ_NAME_EXPLAIN' => 'C\'est le nom qui apparaîtra dans la liste des quiz. Choisissez un nom qui est bref, mais qui aide le joueur a déterminer le genre du quiz.',
'ENTER_QUESTION' => 'Entrer votre question question',
'IS_TRUE_FALSE' => 'Vrai ou faux',
'MULTIPLE_CHOICE_QUESTION' => 'Multiple choix sur les questions',
'INPUT_ANSWER_QUESTION' => 'Répondre à la question',
'MULTIPLES_REVEAL' => 'Alternatives',
'NOT_TRUE_FALSE' => 'Séparez vos différent choix par l\'ajout de chaque option sur une nouvelle ligne. Pour une entrer uniquement, entrer une seule ligne de texte.',
'SUBMIT_INFORMATION' => 'Entrez les questions dans chacun des %1$s champs ci-dessous. Pour de vraies et fausses questions, cliquez sur la case à cocher pour le valider . Lors de la saisie des questions et leur réponse, il suffit de taper la réponse dans la grande case prévue à cette effet. Pour des choix multiples, vous devez fournir %2$s alternatives, en les mettant chacune sur une nouvelle ligne. Vous serez invité à sélectionner la bonne réponse pour chaque question, après l\'envoi de cette page.',
'VERIFY_SUBMIT_INFORMATION' => 'Pour les réponses à choix multiples, choisissez la réponse qui est correct en cliquant sur la case à gauche de la réponse. Pour de vrai et de fausses réponses, sélectionnez soit vrai ou faux.',
'FINAL_VERIFY_SUBMIT' => 'Vérifier toutes les donnée, si elles sont correctes, cliquez sur «Envoyer» ci-dessous.',
'TRUE_FALSE_TRUE' => 'Vrai',
'TRUE_FALSE_FALSE' => 'Faux',
'CORRECT_ANSWER' => 'Bonne réponse',
'QUIZ_SUBMISSION_SUCCESSFUL' => 'Votre quiz a été entré avec succès dans la base de données.<br /><br />%sRetour vers la page index du quiz.%s',
'OUTSIDE_QUESTION_PARAM' => 'Vous n\'avez pas choisi un nombre <strong>%1$d</strong> et <strong>%2$d</strong>, Revenez en arrière et essayez à nouveau.',
'NUMBER_QUESTIONS_UNDEFINED' => 'Le nombre de questions n\'a pas été défini, Retourner a votre page et corriger.',
'TOO_MANY_CHOICES' => 'Une ou plusieurs de vos questions à choix multiples à <strong>plus de %s</strong> choix! supprimer tout les excès de choix.<br /><br />',
'EMPTY_QUESTION' => 'Vous avez laissé un ou plusieurs champs vides! Cliquez sur le bouton retour de votre navigateur pour revenir à la page précédente, et assurer vous de modifier les champs laissés vides.',
'EMPTY_ANSWER' => 'Vous avez laissé un ou plusieurs champs de réponse vide. Cliquez sur le bouton retour de votre navigateur pour revenir à la page précédente, et assurer vous de modifier les champs laissés vides.',
'EMPTY_QUIZ_FIELDS' => 'Vous avez laissé des champs vides! Assurez-vous que chaque champ est rempli correctement.',
'EMPTY_RADIO_BOX' => 'Vous avais, sélectionnez une ou plusieurs possibilité, ce qui signifie que vous avez encore besoin de sélectionner un choix multiples et / ou vrai / faux, <strong>ou</strong> vous n\'avez pas encore rempli le questionnaire et la catégorie.',
// Index
'QUIZ_PASSWORD_PROTECTED_CAT' => 'Un mots de passe est demander pour l\'accés a cette catégorie',
'VIEW_QUIZ_CATEGORIES' => 'Selectionner une catégorie',
'NUMBER_OF_QUIZ_INDEX_SINGLE' => '%d quiz',
'NUMBER_OF_QUIZ_INDEX_PLURAL' => '%d quizzes',
'NUMBER_OF_QUIZ_VIEWS_SINGLE' => '%d affichage',
'NUMBER_OF_QUIZ_VIEWS_PLURAL' => '%d affichages',
'QUIZ_NAME' => 'Nom du Quiz',
'QUIZ_AUTHOR' => 'Auteur',
'QUIZ_DATE' => 'Date d\'envoie',
'QUIZ_VIEWS' => 'Affichages',
// Play quiz
'PLAY_QUIZ' => 'Jouer au Quiz',
'QUIZ_SAVE' => 'Sauvegarder le Quiz',
'QUIZ_TIME_REMAINING' => 'Temps restant (en secondes)',
'QUIZ_NO_TYPE_SUBMIT' => 'Ce questionnaire a été ni, soumis ni enregistrées',
// Answers page
'SHOW_RESULTS_INCORRECT' => 'You answered <strong>%s</strong><br />The correct answer was <strong>%s</strong>',
'SHOW_RESULTS_CORRECT' => 'You correctly answered <strong>%s</strong>',
'TIME_SUMMARY' => 'You completed the quiz in <strong>%d</strong> seconds',
'RESULTS_SUMMARY' => 'Correct answers: <strong>%d</strong><br />Incorrect answers: <strong>%d</strong>',
'QUIZ_RESULTS' => 'Quiz resultats',
'QUIZ_TIME_EXCEEDED' => 'You have exceeded the time limit permitted for this quiz. You took <strong>%d</strong> seconds. Your answers were not saved.',
'QUIZ_PROGRESS_SAVED' => 'This quiz has been saved. You may resume it at a later date',
'CHEATING_ATTEMPT' => 'You are seeing this error because one of several events might have occurred:<br /><br />- A cheating attempt may have been detected. You cannot leave a quiz and later re-enter it without going through the save process.<br />- You have tried to resubmit a quiz that you have exceeded the time limit on<br />- You have already played this quiz, and the admin does not allow multiple attempts.',
'MULTIPLE_SUBMISSION' => 'It appears you have tried to submit this quiz multiple times.',
// statistics
'QUIZ_STATISTICS' => 'Quiz statistiques',
'QUIZ_PLAYER' => 'Quiz joueur',
'QUIZ_CORRECT' => 'Correct',
'QUIZ_INCORRECT' => 'Incorrect',
'QUIZ_PERCENTAGE' => 'Pourcentage',
// statistic module names
'QUIZ_BEST_RESULTS_STATS' => 'Meilleurs resultats',
'QUIZ_MOST_PLAYED_STATS' => 'Les plus populaires',
'QUIZ_MOST_CORRECT_ANSWERS_STATS' => 'La plupart des réponses correctes',
// 'QUIZ_HIGH_PERCENT_ANSWERS_STATS' => 'Highest percentage of correct answers',
