http://emuleplus.info/
eMule Plus is a new generation eMule compatible client created to improve the original GUI and to bring you the best experience ever. Give it a try and feel the boogie eMule Plus doesn't contain any spyware, adware or the like. It's open source and free for life.
02.03.2006 NEW! eMule Plus 1.2 released!
FEATURE: republish a file on file rating change to update server statistics [Aw3]
FEATURE: show file rating received from the server in the search list [Aw3]
FEATURE: detect Ogg Vorbis in AVI info {Fuxie - DK} [Aw3]
FEATURE: increased the file reask time for LowID clients up to 32 min in order to give them a chance to connect first & save a traffic on callback request [Eklmn]
FEATURE: WebServer: added support for receiving the HTTP header "If-Modified-Since" [morphis]
FEATURE: WebServer: compare "If-Modified-Since" and "Last-Modified" if they are the same, send the HTTP message 304 Not Modified, reducing file reloading [morphis]
FEATURE: WebServer: added support for "Accept-Encoding", Gzip is now automatic [morphis]
FEATURE: WebServer: added detection of caps lock while logging in [DonGato]
CHANGE: faster switching between the Known and Shared Files lists in the shared files view [Aw3]
CHANGE: avoided rare double publishing of a just completed file {muleteer} [Aw3]
CHANGE: applied a couple of optimizations for proxy support (from original) [Aw3]
CHANGE: more space for data in the search lists (reduced column margins) [Aw3]
CHANGE: updated Georgian flag {wonder_al} [Aw3]
CHANGE: faster message preprocessing in the transfer window [Aw3]
CHANGE: avoid creating a link with sources for unshared files {Vladimir (SV)} [Aw3]
CHANGE: MobileMule: protocol update (from original) [Aw3]
CHANGE: file sharing mode to allow read-only access to a preview file [Aw3]
CHANGE: improve timeout processing for open chat sessions {muleteer/Fuxie - DK} [Aw3]
CHANGE: significantly improved downloading from MLdonkey clients [Aw3]
CHANGE: more compatibility with VC2005 [brengarne]
CHANGE: revised and updated Lithuanian [vwpassatgt]
CHANGE: WebServer: new HTML4.01 strict login pages carrying Gzip compression indicator [morphis]
CHANGE: WebServer: reduced the file sizes of a lot of the images [morphis]
CHANGE: WebServer: updated/corrected ed2k link generation in transfer/shared files lists [Aw3]
CHANGE: WebServer: reduced file I/O while loading templates [Aw3]
CHANGE: WebServer: optimized preparation of the tranfer page [Aw3]
CHANGE: WebServer: added forced word wrap to logs [DonGato]
CHANGE: WebServer: optimized processing of the requests for auxiliary files [Aw3]
CHANGE: WebServer: permanent javascripts were moved to .js files to reduce traffic [morphis]
BUGFIX: startup (mostly Win98) when some windows were not available {semental/morrismatto} [Aw3]
BUGFIX: date display for maximum connections reached statistics {Fuxie - DK} [DonGato]
BUGFIX: copying of completing file instead of moving for case sensitive paths {glaskrug} [Aw3]
BUGFIX: proxy SOCKS 5 authentication (from original) [Aw3]
BUGFIX: URL for the Internet version check was outdated [KuSh]
BUGFIX: some IP ranges couldn't be loaded from PeerGuardian database [Aw3]
BUGFIX: the whole shared files list resort when chunk hidden status was changed by double-click [Aw3]
BUGFIX: rating icon update when edit shortcut was pressed on selected chunk [Aw3]
BUGFIX: saving of some list data after failed start {semental/morrismatto} [Aw3]
BUGFIX: completed file deletion on Show File Details when temp and incoming folders're the same {quadesh} [Aw3]
BUGFIX: processing of the connected sources if file was stopped [Eklmn]
BUGFIX: file reask by LowID client was skipped if a client is on the same server [Eklmn]
BUGFIX: a warning about too many shared files when no server information available {Vladimir (SV)} [Aw3]
BUGFIX: clipped string in category edit dialog {Vladimir (SV)} [Aw3]
BUGFIX: WebServer: added appropriate response if a requested file is not found [Aw3]
BUGFIX: WebServer: the HTTP header "Last-Modified" is now the requested file's modification date and not the date of when the template was loaded [morphis]
BUGFIX: WebServer: corrected page refresh feature {Rick164} [DonGato]
BUGFIX: WebServer: corrected tooltips code in XP template and a minor HTML error {Fuxie - DK} [DonGato]
Operating System: All 32-bit MS Windows (95/98/NT/2000/XP)
License: GNU General Public License (GPL)
Sourceforge eMule Plus-1.2.Installer download page.
eMule Plus FAQ
eMule Plus
- p2p-sharing-rules
- Moderator
Updated Oct.13 2006 eMule Plus 1.2a.
What's new
FEATURE: Stand-alone FAQ version in PDF format (available as a separate download) [Vladimir (SV)/Aw3]
FEATURE: filename cleanup shortcut {Towelie} [Aw3]
FEATURE: server list update option was split into update from servers and clients {ElAguila} [Aw3]
FEATURE: configuration of default file permission {conman} [Aw3/DarkSoul]
FEATURE: show server UDP capabilities in the server list tooltips [Aw3]
FEATURE: large file size support (max file size 512 GB - 1 = 549,755,813,887) [Aw3]
FEATURE: Ukrainian localization [Punk/Aw3]
FEATURE: Complete Sources information in the file details [Aw3]
FEATURE: detect ADPCM audio stream in AVI info {Fuxie - DK} [Aw3]
FEATURE: show overall file rating provided by servers in the search list [Aw3]
FEATURE: option to send email notification messages in subject [KuSh]
FEATURE: shortcut for "Download from all A4AF sources (same category)" {Fuxie - DK} [Aw3]
FEATURE: Malay localization [xyes/Aw3]
FEATURE: support for previewing encrypted and solid RAR archives (adapted from original) [Aw3]
CHANGE: speeded up file parts info list processing to be suitable for large files [Aw3]
CHANGE: alternative file destination directory was moved to .part.settings {Fuxie - DK} [Aw3]
CHANGE: dropped configuration file migration from old versions (< v1h) [Aw3]
CHANGE: removed not working 'Automatic serverconnect without proxy' feature [Aw3]
CHANGE: use general user agent for HTTP requests [Aw3]
CHANGE: more efficient Rx file data caching to reduce disk access [Aw3]
CHANGE: faster plot statistics processing for WebServer and MobileMule [Aw3]
CHANGE: speeded up drawing of Part Traffic status bar [Aw3]
CHANGE: faster processing of remote part status packets [Aw3]
CHANGE: format of partperm.dat, smooth upgrade, settings loss on downgrade if there're file hidden parts [Aw3]
CHANGE: Jumpstart database format to support large files, smooth upgrade, downgrade with limitations [Aw3]
CHANGE: delayed file republishing on the server to post new rating or complete status [Aw3]
CHANGE: faster insertion to uploading when queue is empty [Aw3]
CHANGE: reduced timeout to purge inactive sources from 2:00h to 1:40h [Aw3]
CHANGE: drop without delay some kind of inactive remote LowID sources in upload queue [Aw3]
CHANGE: drop some buggy ed2k clients from upload queue as such remote LowID can't be contacted [Aw3]
CHANGE: don't send reask to a full source before file completion to save traffic [Aw3]
CHANGE: more accurate estimation of the required free disk space for archive preview [Aw3]
CHANGE: improved timeout processing on WinXP SP2 [Eklmn]
CHANGE: used lighter way to detect Internet connectivity [Aw3]
CHANGE: don't try to hash temporary files used by file completion {Fuxie - DK} [Aw3]
CHANGE: simplified email notifier code (adapted from original) [KuSh]
CHANGE: dropped import of old preferences (preceding eMule v0.21) [Aw3]
CHANGE: simplified obtaining of HTTP response values [Aw3]
CHANGE: limit minimum server connection timeout for connection though proxy (from original) [Aw3]
CHANGE: file sharing mode to allow read-only access to an archive preview files [Aw3]
CHANGE: show IRC Nickname list context menu even when no selection [Aw3]
CHANGE: don't send any cookie while checking for a new version [Aw3]
CHANGE: WebServer: order of friend and credit queues according to prefs and GUI {Fuxie - DK} [morphis/Aw3]
CHANGE: WebServer: faster preparation of the tranfer, search and shared files pages [Aw3]
BUGFIX: delete stray .part.met.bad on file completion and cancelation [Aw3]
BUGFIX: constant rehashing of files with some weird date {mamamia} [Aw3]
BUGFIX: toolbar button state while up/down customizing {DoubleT} [Aw3]
BUGFIX: new category ID allocation {rgreen83} [Aw3]
BUGFIX: corrected part file date check causing rehashing in some cases {muleteer} [Aw3/KuSh]
BUGFIX: don't republish a file on the server if only comment was changed [Aw3]
BUGFIX: default category color [Aw3]
BUGFIX: Info View header localization after language switch {mamamia} [Aw3]
BUGFIX: part file loading assigned to the not existing category [Aw3]
BUGFIX: stopping of a file paused due to lack of disk space {muleteer} [Aw3]
BUGFIX: completion for some particular file names {taltamir} [Aw3]
BUGFIX: corrected saving of statistics plot colors to preferences.ini [Aw3]
BUGFIX: exception on closure when no disk space for buffered file data [Aw3]
BUGFIX: corrected some memory deallocations {tHeWiZaRdOfDoS} [Aw3]
BUGFIX: complete transfer calculation for part traffic [Aw3]
BUGFIX: part traffic chunk statistics reset [Aw3]
BUGFIX: disappearance of the chat message pane after pressed Esc (from original) [Aw3]
BUGFIX: delete unused client objects when a file is stopped to free memory [Aw3]
BUGFIX: UDP reasks shouldn't have been sent to NNS [Aw3]
BUGFIX: focus issues for modal dialogs on the server window {Vladimir (SV)} [Aw3]
BUGFIX: corrected kick of banned source from upload queue [Aw3]
BUGFIX: chat session has to be disconnected on ban (from original) [Aw3]
BUGFIX: missed upload overhead for data packets [Aw3]
BUGFIX: cursor destruction {SlugFiller} [Aw3]
BUGFIX: don't add sources with mismatch part count to downloading [Aw3]
BUGFIX: display of Waited Time in remove queue for 'Another Server LowID' sources [Aw3]
BUGFIX: file Last Reception time for files complete on startup {Fuxie - DK} [Aw3]
BUGFIX: insertion to uploading -- too many socket connections blocked some even already connected sources [Aw3]
BUGFIX: source reasking when too many connections threshold reached [Aw3]
BUGFIX: don't hash and share part files without complete chunks on startup after improper closure [Aw3]
BUGFIX: disabled renaming of file completed while renaming in download list {Vladimir (SV)} [Aw3]
BUGFIX: displaying of the completed size for erroneous files on startup {Fuxie - DK} [Aw3]
BUGFIX: don't show Media Info tab for formats which can't be examined {Fuxie - DK} [Aw3]
BUGFIX: edit dialog and message box localizations {BouRock} [Aw3]
BUGFIX: log information about duplicate shared files {Vladimir (SV)} [Aw3]
BUGFIX: some remote LowID purged from the download queue weren't deleted from known client list [Aw3]
BUGFIX: position loss of some sources in our upload queue after file completion [Aw3]
BUGFIX: a rare remote queue position loss due to missed reask for downloading remote LowID [Aw3]
BUGFIX: rare creation of wrong .stats file in the destination directory {Fuxie - DK} [Aw3]
BUGFIX: download state change for remote LowID sources [Aw3]
BUGFIX: file compression gain and corruption loss in Info pane [Aw3]
BUGFIX: preview free disk space check {Vladimir (SV)} [Aw3]
BUGFIX: create temp. files for archive preview in corresponding temp. directory of part file [Aw3]
BUGFIX: sorting of erroneous files under 'Show paused and stopped files last' {Fuxie - DK} [Aw3]
BUGFIX: file hashing in case of file read error {Fuxie - DK} [Aw3]
BUGFIX: renaming through context menu (added sanity checks) {Prodoc} [Aw3]
BUGFIX: an issue with the scheduler handling of 0:00hs switch {guillep2k} [DonGato]
BUGFIX: Internet Connection Check stuck in some cases {DoubleT/xalbux} [Aw3]
BUGFIX: display of unknown video codec in AVI info {Fuxie - DK} [Aw3]
BUGFIX: search and download list redraw after color related settings change in preferences {Fuxie - DK} [Aw3]
BUGFIX: source sorting when more than one client with status "Queue Full" exists {Vladimir (SV)} [Eklmn]
BUGFIX: error log message while saving credit file {dbh} [Aw3]
BUGFIX: localization for new eMule Plus version auto-check {purgossu} [Aw3/DonGato]
BUGFIX: prevent data exchange unless hello-handshaking is finished [Eklmn]
BUGFIX: rare incorrect setting of NNS state by download [Eklmn]
BUGFIX: processing of incorrect data while recovering for archive preview {muleteer} [Aw3]
BUGFIX: archive preview recovery for some boundary conditions [Aw3]
BUGFIX: preview of ZIP archive containing a directory archive entry (from original) [Aw3]
BUGFIX: deletion of output file after failed archive preview recovery {muleteer} [Aw3]
BUGFIX: MobileMule: potential crash on socket closure {Xman1} [Aw3]
BUGFIX: IRC: socket connection request on every connect button click {Vladimir (SV)} [KuSh]
BUGFIX: WebServer: usage of <br /> tag [Aw3]
BUGFIX: WebServer: drop-down menu items, collapsing text {muleteer} [morphis]
BUGFIX: WebServer: login page incorrection to follow specification [DonGato]
BUGFIX: WebServer: browser image preloading {muleteer} [morphis]
eMule Plus v1.2a download links:
Installer
Binary
Source
v1.2a.FAQ.En.zip
What's new
Installer
Binary
Source
v1.2a.FAQ.En.zip
Last edited by p2p-sharing-rules on Fri Aug 07, 2009 6:12 pm, edited 4 times in total.
Reason: updated download links
- p2p-sharing-rules
- Moderator
eMule Plus 1.2b Feb. 07 2007
what's new
FEATURE: updated source exchange protocol to v3 (support of HighID x.x.x.0 IPs) [Eklmn/Aw3]
FEATURE: added flags of Serbia (RS), Montenegro (ME) and Aland Islands (AX) {AraldoL} [Aw3]
FEATURE: proper Vista detection {muleteer} [Aw3]
FEATURE: added .3g2, .3gp and .mp4 as Video file types; .djv as Document [Aw3]
FEATURE: crash dump upload page on the homepage site [DonGato]
FEATURE: Slovenian localization [krojc/Aw3]
CHANGE: make sure that a dropped source is always deleted after identification collision [Aw3]
CHANGE: improved client identification ("bad"-client detection, waiting time protected by SUI) [Eklmn]
CHANGE: removed unused Apply and Help buttons from client/file details dialogs [Aw3]
CHANGE: improved filtering of incoming connections (less traffic & CPU load) [Eklmn]
BUGFIX: crash on visual style change {theirix} [KuSh]
BUGFIX: proxy HTTP 1.1 error reporting {vgi2007} [Aw3]
BUGFIX: potential fix for a crash caused by delayed loading of IP2Country database {grzechu_l} [Aw3/KuSh]
BUGFIX: rare crash on known client list update {davide} [Aw3/KuSh]
BUGFIX: drawing of chunk bars in file details for large files {Fuxie - DK} [Aw3]
BUGFIX: client name change when download starts from remote client shared file list [Eklmn]
BUGFIX: connection loss after transfer of some specific data packet size (in some cases) [Aw3]
BUGFIX: ability to keep connection after cancel transfer reception [Aw3]
BUGFIX: source loss at the time of unexpected downloading disconnection {muleteer} [Aw3]
BUGFIX: A4AF switching for the clients in "Waiting request" state {Fuxie - DK} [Eklmn]
BUGFIX: corrected the output of the waiting time in client details [Eklmn]
BUGFIX: reset filename after A4AF swap to prevent user misinformation in case of delayed response [AraldoL]
BUGFIX: incorrect filtering out of some LowID sources [Aw3]
BUGFIX: exception on shared file list reload with LanCast enabled {NonChance} [KuSh]
Download links:
eMulePlus-1.2b.Binary.zip
eMulePlus-1.2b.Installer.exe
eMulePlus-1.2b.Source.zip
eMulePlus-1.2b.FAQ.En.zip
The eMulePlus-1.2b.FAQ are in .pdf format.
what's new
Download links:
- p2p-sharing-rules
- Moderator
eMule Plus 1.2c Sept.1, 2007
What's new
FEATURE: Serbian localization [DarkMan/Aw3]
FEATURE: provide file rating to other clients with the list of shared files [Aw3]
FEATURE: Source Exchange 2 support (adapted from original) [Aw3]
FEATURE: Source Exchange Protocol version 4 [Aw3]
FEATURE: middle mouse click closes tab (search, chat, etc.) (from original) {Towelie} [Aw3]
FEATURE: extended related search to send combined requests {lugdunummaster} [Aw3]
FEATURE: .ratDVD added to CD/DVD image type {Fuxie - DK} [Aw3]
FEATURE: Italian FAQ [KerneL/Aw3]
FEATURE: WebServer: added file type icon to the search list of the light template [Aw3]
FEATURE: WebServer: show overall file rating provided by servers in the search list [Aw3]
FEATURE: WebServer: file menu 'Swap all A4AF sources to other files' {Fuxie - DK} [Aw3]
CHANGE: get first chunk for reviewable archives to allow better recovery {muleteer} [Aw3]
CHANGE: get first chunk option for .rm files {muleteer} [Aw3]
CHANGE: improved calculation of available remote client parts [Aw3]
CHANGE: locale settings (e.g. date formatting) taken from user settings (not based on language anymore) [Aw3]
CHANGE: homepage update and site image optimization [Psy]
CHANGE: low priority is used for servers added to the list from other clients (original) [Aw3]
CHANGE: removed file name trimming (to 50 characters) for status.log [Aw3]
CHANGE: moved onlinesig.dat from config to installation folder {Vladimir (SV)/Lastwebpage} [Aw3]
CHANGE: made setting 'Remove dead server retries' compatible with original [Aw3]
CHANGE: upload limits for rare files and friends [Aw3]
CHANGE: faster upload data block preparation [Aw3]
CHANGE: optimized score calculation and higher score status detection [Aw3]
CHANGE: removed importing of v0.29a credit file format [Aw3]
CHANGE: removed port statistics [Eklmn]
CHANGE: default browsing dir for WebServer templates and while saving logs {muleteer} [Aw3]
CHANGE: removed score punishing of very old clients (older than 0.19) [Aw3]
BUGFIX: corrected backup overwrite message box confirmation [Aw3]
BUGFIX: don't backup corrupted (zero size) .part.met files [Aw3]
BUGFIX: incorrect userhash in case of file corruption [KuSh]
BUGFIX: corrected source selection for p2p source exchange [Aw3]
BUGFIX: static controls when used with themes {Vladimir (SV)} [KuSh]
BUGFIX: selection of not the best sources while creating a file link with source [Aw3]
BUGFIX: "day" string in representation of time duration {Fuxie - DK} [Aw3]
BUGFIX: time disappeared at midnight {Fuxie - DK} [KuSh]
BUGFIX: startup with file system corruption of the configuration file {fran} [Aw3]
BUGFIX: not all received over UDP server sources might be added under some rare conditions [Aw3]
BUGFIX: "Set manually added servers to High Priority" usage when added through a link {gnwd} [Aw3]
BUGFIX: active "Assign to category" menu for complete files {Vladimir (SV)} [Aw3]
BUGFIX: size and position of the mintray button [KuSh]
BUGFIX: memory leak when changing program localization [KuSh]
BUGFIX: multimonitor control positioning and mouse click handling [KuSh]
BUGFIX: corrected report in the log about archive preview recovery status {Fuxie - DK} [Aw3]
BUGFIX: potential fix for seldom crash on closure while archive preview still running {f.milione} [Aw3]
BUGFIX: rare crash while redrawing messages window and client was deleted [KuSh]
BUGFIX: upload client rate calculation in case of consecutive upload sessions {muleteer} [Aw3]
BUGFIX: crash while closing IRC channels on shutdown {a.faccio} [KuSh]
BUGFIX: hashing sometimes stopping on startup while having a lot of shared files [Aw3]
BUGFIX: incomplete version check message [KuSh]
BUGFIX: rare crash while processing client lists {ompz} [Aw3/KuSh]
BUGFIX: Shared Files List slow down while publishing a lot of files {lhay/Zom} [Aw3]
BUGFIX: potential crash while sending Lancast packet [Aw3]
BUGFIX: bigger amount of data sent by auxiliary compressed packets [Aw3]
BUGFIX: IRC: user selection in the list on status change [Aw3/KuSh]
Download links
eMulePlus-1.2c.Installer.exe
eMulePlus-1.2c.Binary.zip
eMulePlus-1.2c.Source.zip
What's new
Download links
- p2p-sharing-rules
- Moderator
eMule Plus 1.2d May 18, 2008
Notes:
* WARNING! WebServer & MobileMule passwords have to be reentered again
* WARNING! Changed log file format, previous logs're preserved with .ansi extension
* WARNING! Existing filter.dat has to be manually converted into Unicode if it's required there
What's New:
FEATURE: Unicode support [Eklmn/Aw3/KuSh]
FEATURE: show client properties on right click on tab in chat window [Eklmn]
FEATURE: Video Player parameters {glaskrug/Lastwebpage} [Aw3]
FEATURE: facility to update comment filter and file cleanup tags for current installation [Aw3]
FEATURE: WebServices link for IMDb movie info look-up [Aw3]
FEATURE: 'Keep search history' setting to preserve or not search history [Aw3]
FEATURE: WebServer: preserve list statuses between restarts [Aw3]
FEATURE: WebServer: preserve client queue statuses between restarts [Aw3]
CHANGE: simplified shared files hashing thread [KuSh]
CHANGE: extended statistics successful and failed download sessions to keep bigger values [Aw3]
CHANGE: consider auto and jumpstart attributes while sorting by priority [KuSh]
CHANGE: select current backup directory on backup directory browsing [Aw3]
CHANGE: increased compiler warning level to 4 [Aw3/KuSh]
CHANGE: proper share mode for open files [Aw3]
CHANGE: download comment rating clean-up after comment filter update {Efix} [Aw3]
CHANGE: better compatibility to run default system preview application (original) [Aw3]
CHANGE: increased upper range for 'File Buffer Size', setting was made compatible with original [Aw3]
CHANGE: transfer window sub-pane state was moved to preferenes.ini (gui.dat is not used anymore) sub-pane state will be set to default on the first start [Aw3]
CHANGE: more robust checks to load transfer window sub-pane state [Aw3]
CHANGE: robust case insensitive ed2k link parsing {Avi-3k} [Aw3]
CHANGE: removed 'Ignore eMule protocol messages' to enforce IRC anonimity {Bruno} [KuSh]
CHANGE: more robust IRC ident {KerneL} [Aw3]
CHANGE: speeded up some disk operations [Aw3]
CHANGE: localized proxy errors [Aw3]
CHANGE: restore window to exact previous position by 'Bring to front on link click' [Aw3]
CHANGE: WebServer: show download list source information similar to GUI {Vladimir (SV)} [Aw3]
CHANGE: WebServer: don't load/save preferences.ini on change of particular parameters [Aw3]
BUGFIX: memory leak while editing of the server properties [Eklmn]
BUGFIX: wrong statistics slide control positions on consequential preferences open [Aw3]
BUGFIX: applying of some preferences settings when several are altered at once {Vladimir (SV)} [Aw3]
BUGFIX: stuck credits control and about dialog when focus is lost while holding mouse [Aw3]
BUGFIX: reporting of corrupted part traffic data files {Vladimir (SV)} [Aw3]
BUGFIX: vulnerability in staticservers.dat processing [Aw3]
BUGFIX: HTTP download dialog localization [Aw3]
BUGFIX: incorrect large file size sent to some clients in shared file list packets [KuSh/Aw3]
BUGFIX: wrong corruption lost and saved by compression statistics values at installation time [Eklmn]
BUGFIX: Ban Request Interval configuration for locales with comma as decimal-point [Aw3]
BUGFIX: stuck splitter control in transfer/messages windows when focus is lost while holding mouse [Aw3]
BUGFIX: redraw statistics plots without delay after window restore or size change {Vladimir (SV)} [Aw3]
BUGFIX: loading of InfoView column splitter [Aw3]
BUGFIX: incorrect client.met.bak generation which didn't do it in the most cases {muleteer} [Aw3]
BUGFIX: crash caused by shared files list merging after file completion and outside renaming {DonGato} [Aw3]
BUGFIX: resources leak caused by deleting or merging part file in the shared files list [Aw3]
BUGFIX: modeless ed2k link registration and server list update message boxes {muleteer} [Aw3]
BUGFIX: missed percentage in the shared files statistics on the very first drawing {muleteer} [Aw3]
BUGFIX: wrong max search limit was sent to servers when more than 4GB was specified [Aw3]
BUGFIX: crash on moving items in list controls {JCRIADO/paolo} [KuSh/Aw3]
BUGFIX: download list file selection after collapsing by keyboard {glaskrug} [Aw3]
BUGFIX: crash on enabling last list column {AqUaRiUs} [KuSh/Aw3]
BUGFIX: sending double cancel requests in some rare cases [Aw3]
BUGFIX: corruption of .part.met files when disk is full [Aw3]
BUGFIX: authentication configuration for SOCK5 proxy [Aw3]
BUGFIX: missed stalled status for active files without a hashset [DoubleT/Aw3]
BUGFIX: messed waiting for hash and hashing file statuses in GUI and WebServer {Fuxie - DK} [Aw3]
BUGFIX: WebServer: application date format changed after WebServer usage {glaskrug} [Aw3]
BUGFIX: WebServer: localization of the socket connection setup error [Aw3]
BUGFIX: WebServer: sorting by size in the search list [Aw3]
Download links:
eMulePlus-1.2d.Installer.exe
eMulePlus-1.2d.Binary.zip
eMulePlus-1.2d.Source.zip
Notes:
What's New:
Download links:
- p2p-sharing-rules
- Moderator
eMule Plus 1.2e
Release date: April 18 2009
Sorry I'm late with this update. It's better late then never.
Changelog
FEATURE: identity thief countermeasures {Fuxie - DK/muleteer/Bro-DK} [Aw3]
FEATURE: IP filter optimization: faster loading while consuming less resources [Aw3]
FEATURE: multipacket encoding support [eklmn/Aw3]
FEATURE: search by file, hash, country and client software in source lists on transfer page [Aw3]
FEATURE: message box with CLI help [DoubleT/Aw3]
FEATURE: use file name as the 2nd criteria for shared files sorting by Priority and Folder [Aw3]
FEATURE: use file extension as the 2nd criteria while sorting by file type {muleteer} [Aw3]
FEATURE: IRC: added utf8 message encoding option [eklmn/Aw3]
FEATURE: IRC: strip user message colors {xalbux} [Aw3]
FEATURE: IRC: save state of the user list [Aw3]
FEATURE: IRC: enabled search in the lists [Aw3]
FEATURE: Italian stand-alone FAQ version (translated by KerneL) in PDF format [Aw3]
CHANGE: slightly simplified source code distribution for easier compilation {Vladimir (SV)} [Aw3]
CHANGE: more detailed debug information about received bad packets [Aw3]
CHANGE: increased max file comment length to 128 characters (from original) [Aw3]
CHANGE: removed special downloading improvement against old MLdonkey clients [Aw3]
CHANGE: more accurate download bandwidth calculation for compressed packets [Aw3]
CHANGE: classify .m4a, .m4b, .m4p, .m4r file extensions as audio type; .m4v as video [Aw3]
CHANGE: get preview chunk option for .mp4 files {muleteer} [Aw3]
CHANGE: optimized link identification and output to RichEdit controls (logs, chats, IRC) [Aw3]
CHANGE: simplified logging system implementation [Aw3]
CHANGE: extended processing to auto-resize list columns on the transfer window [Aw3]
CHANGE: don't autoconnect before loading ipfilter.dat [KuSh]
CHANGE: save A4AF sources for Save/Load Sources feature {muleteer} [Aw3]
CHANGE: new version check link (updates.emuleplus.info) for better flexibility [Aw3/DonGato]
CHANGE: web site and forum update and migration to better hosting [DonGato/Aw3]
CHANGE: updated country flag database [Aw3]
CHANGE: command-line commands don't start eMule Plus if it's not running [Aw3]
CHANGE: reworked notification window placement to overcome Wine issue {Vladimir (SV)} [Aw3]
CHANGE: revised software updated instructions in readme.txt {Efix} [Aw3]
CHANGE: better Italian translation for "Clear" from the download list {KerneL} [Aw3]
CHANGE: dropped conversion of old JumpStart database format (used before v1.2a) [Aw3]
CHANGE: IRC: simplified log message formatting [Aw3]
CHANGE: IRC: reorganized user list [Aw3]
CHANGE: WebServer: improved download progress bar representation for large files {DonGato} [Aw3]
BUGFIX: potential corruption of already received and veryfied data [Aw3]
BUGFIX: don't apply GUI "Prompt on exit" for "exit" CLI command {Vladimir (SV)} [Aw3]
BUGFIX: error message regarding saving to staticservers.dat [Aw3]
BUGFIX: corruption of server.met files when disk is full [Aw3]
BUGFIX: error message issued while saving part.met file [Aw3]
BUGFIX: garbled text on HTTP download status window for IE7 (from original) {muleteer} [Aw3]
BUGFIX: A4AF sources attached to complete file {DonGato/DopeFish/muleteer/Vladimir (SV)/glaskrug} [Aw3]
BUGFIX: A4AF source count display for paused files [Aw3]
BUGFIX: link highlighting in logs and chats (Unicode migration issue) [Aw3]
BUGFIX: link highlighting for long IRC links {Paola} [Aw3]
BUGFIX: logging vulnerability which could cause endless loop with 100% CPU utilization [Aw3]
BUGFIX: auto-resize for the first column of the shared files and search lists [Aw3]
BUGFIX: list drawing causing column resize and tooltip problems {Fuxie - DK/muleteer} [Aw3]
BUGFIX: update of preferences category list on / [Aw3]
BUGFIX: incorrect destructor for some allocated buffers [Aw3/KuSh]
BUGFIX: initialization of the average download time statistics [Aw3]
BUGFIX: restore CLI which couldn't restore minimized window (from the system taskbar) [Aw3]
BUGFIX: uninitialized session upload priority statistics [KuSh]
BUGFIX: crash caused by invalid pointers casting {Nestor} [KuSh/Aw3]
BUGFIX: loss of the IP filter when garbage is downloaded from the server {Fuxie - DK} [Aw3]
BUGFIX: memory leak caused by failed gzipped HTTP download (from original) [Aw3]
BUGFIX: wrong clipping and ellipsis in the label column of the info view pane [Aw3]
BUGFIX: icon alignment in the preferences page selection control {pixelgrease} [Aw3]
BUGFIX: potential memory corruption while displaying notification window [Aw3]
BUGFIX: text going beyond notification window [Aw3]
BUGFIX: occasional wrong line break for long words in the notification window {muleteer} [Aw3]
BUGFIX: static server priority change {Unknown} [Aw3]
BUGFIX: WebServer: "Don't scroll toolbar" feature for Firefox 3 {muleteer} [DonGato]
BUGFIX: WebServer: adding a server with high priority [Aw3]
BUGFIX: WebServer: last log message report for Servers and Shared Files [Aw3]
BUGFIX: WebServer: inserting several ed2k-links {L_ignorant} [Aw3]
Download links:
eMule Plus 1.2e.exe
eMulePlus-1.2e.Binary.zip
eMulePlus-1.2e.Source.zip
eMulePlus-1.2e.FAQ.En.zip
eMulePlus-1.2e.FAQ.Ita.zip
Changelog
Download links:
eMule Plus 1.2e.exe
