Speaking of iPhone chargers, in the mail today I got:
Just finished fully charging. I might post a review in the articles section about it once I've tested with the iPhone
And so this post gets picked up in Google searches, the device is called the 1000mAh USB Rechargeable Emergency Power Pack Battery for iPhone 3G.
To charge it, plug the USB cable that you use to Sync the iPod/iPhone into the end of the charger (upside down). When it's charging the blue lights will flash every second or so. There are 4 different levels to indicate how charged it is... if the bottom light is the only one flashing, it's (I assume) between 0-25% full, 2 bars is 25-50%, 3 bars is 5--75% and the arrow flashing should mean it is between 75-100%. Once all the lights have lit up and stop flashing it is fully charged.
The top arrow is a test button - haven't tried it yet, but I assume this can be used at any time (plugged in or not) to give a quick indication of how full the battery is. (just tried it, and can confirm this is what happens)
