[Player] Winamp
- p2p-sharing-rules
- Moderator
Thanks Moon. I checked out those skin themes , I don't like 'em.
- p2p-sharing-rules
- Moderator
Newest Winamp v5.35
- p2p-sharing-rules
- Moderator
hehe your welcome
It's been quite a long time since I've used Winamp, I mainly use iTunes now.
Is it (v5.x) better or worse than Winamp 3? (yes, it has been that long )
I installed the latest version just a few days ago. Prior to that I hadn't been using it in a fair while cos I tend to use Creative's "Media Source Organizer" in windows and I use Amarok in linux. To answer battye's question - the answer, as far as I can tell, is that it hasn't changed much. It has a different default skin and uhh... that's probably all.
That's a shame. I thought the difference between Winamp 2 and 3 was amazing, infact, I wish they had continued work on the 3.x line. But if IIRC, AOL bought out Winamp and the creator (Justin something-or-other) quit, so I suppose it was the beginning of the end right there.Rat wrote:To answer battye's question - the answer, as far as I can tell, is that it hasn't changed much. It has a different default skin and uhh... that's probably all.
- p2p-sharing-rules
- Moderator
I'll still use it until AOL starts messing it up , it's better then using WMP.
When I 1st started using Winamp I only got it cos you need it to use WinMX amp plugins.I've been using it ever since then.
Last edited by p2p-sharing-rules on Sun Jun 24, 2007 3:12 pm, edited 1 time in total.
Well, nothing could be that badp2p-sharing-rules wrote:I'll still use it's until AOL starts messing it up , it better then using WMP.
- p2p-sharing-rules
- Moderator
Happy 10th Anniversary Winamp!
Click here to view the version history.Winamp 5.5: 10th Anniversary Edition Launches
2007-10-10
Packed with new features, the latest edition of Winamp is available now. Download Winamp 5.5: The 10th Anniversary Edition and take the all new leading multimedia player for a ride.
Here's a sampling of some of the great Winamp features:
* A completely redesigned interface, including Album Art
* Multiple device support, including Apple iPods
* Access and Share your Music and Videos with Winamp Remote
* Play and Playlist the Best Music on the Web with Media Monitor
* Enjoy Dynamic Song Recommendations
* Experience MP3 Surround Sound Support
* Access to Thousands of Online Radio Stations, Videos and More!
* 50 Free MP3 Music downloads compliments of eMusic's 2-week Trial
* Auto-Tagger provides automatic updates to file information
* Control Winamp from your browser with a the Winamp Toolbar
Download Winamp 5.5 and enjoy the ride.
- The Winamp Team
- p2p-sharing-rules
- Moderator
Your welcome!
- p2p-sharing-rules
- Moderator
Newest Winamp version is 5.51.
- p2p-sharing-rules
- Moderator
Winamp v5.52
What's New:
* Improved: Better Unicode filename support for enc_*.dll audio encoders
* Improved: [ml_transcode] Unicode filename support
* Improved: [in_mp3] APEv2 tag support
* Improved: [in_flac] Support for reading/writing BPM metadata
* Improved: [nde] Optimized for faster mldb query results
* Improved: [vis_milk2] Pixel shaders now work on onboard Intel graphics chips
* Fixed: Comment field character limitation in Basic Info tab of File Editor
* Fixed: Playback Thread Priority middle setting resets to Lowest
* Fixed: [in_mp3] Ultravox streaming metadata stack overflow
* Fixed: [in_mp4] Crash when attempting to play non-existent files
* Fixed: [in_vorbis] Crash when clearing existing metadata fields in File Info
* Fixed: [in_wave] Transcoding of floating point WAV files
* Fixed: [ml_transcode] Memory leaks
* Misc: More miscellaneous general tweaks and improvements
* Updated: Bento skin #118
http://www.winamp.com/player
What's New:
- p2p-sharing-rules
- Moderator
Winamp 5.54 Thursday, July 10, 2008
You can find download links here.
What's new:
* New: Chinese, Japanese & Korean installer translations and language packs
* New: [in_swf] Adobe Shockwave Flash (SWF, RTMP) playback support
* New: [gen_dropbox] Winamp DropBox alpha (use: Ctrl-Shift-D)
* New: [Online Services] AOL Radio featuring CBS Radio (requires in_flv)
* Improved: Background reading option for playlist metadata
* Improved: Classic songticker scrolling for Winamp Modern skin pledit winshade
* Improved: Vista elevation (fixes: installing skins, filetype reg, Pro reg)
* Improved: Zero padding option for playlist item numbers
* Improved: [in_flv] Better streaming support and other improvements
* Improved: [in_mp3] Added APEv2 tag options to configuration
* Improved: [in_mp3] Optional retention of existing APEv2 headers
* Improved: [ml_disc] Artwork support for Data CD Reader
* Improved: [ml_disc] Better detection of any copy operations in progress
* Improved: [ml_disc] Improved start times if ml_disc view is active
* Improved: [ml_local] Redesigned 'Show Info' panel
* Improved: [ml_nowplaying] Redesigned 'Now Playing' artist experience
* Improved: [ml_playlists] Right-click option to sort list of playlists alphabetically
* Improved: [pmp_usb] Connect/Disconnect/Blacklist config options
* Fixed: Alt+F4 closing Winamp instead of individual dialogs
* Fixed: Bento browser redirecting network drive url's to Winamp Search
* Fixed: Blank playlist when in docked toolbar mode and Winamp is minimized
* Fixed: Modern skin component windows appearing individually in Alt+Tab
* Fixed: Multi-flashing on startup when previously closed whilst minimized to systray
* Fixed: Pure Virtual Function Call runtime crash errors
* Fixed: Redraw issue when built-in classic vis is disabled
* Fixed: Various multi-monitor docking issues
* Fixed: Various other 5.53-specific keyboard accelerator issues
* Fixed: [Bento] Drag+Drop into Playlist from Open Files dialog
* Fixed: [burnlib] 'CD Drive locked by another Winamp process' on 2nd burn attempt
* Fixed: [burnlib] 'Burner releasing failed' error
* Fixed: [dsp_sps] Crash on close when config Help dialog is still open
* Fixed: [enc_flac] MD5 checksum generation
* Fixed: [gen_ff] Attached vis plugin crash on winshade to normal mode in Modern skin
* Fixed: [gen_hotkeys] Assigning Winkey with already used Ctrl combinations
* Fixed: [gen_ml] Enter/Shift+Enter broken for ML treeview items (5.53-specific)
* Fixed: [in_cdda] Composer/Conductor logic bug when saving CDDB data to database
* Fixed: [in_flac] Minor metadata writing bugs
* Fixed: [in_midi] Seeking with 'DM/MS Synth' device in Streamed playback mode
* Fixed: [in_mp3] Crash on files with invalid/corrupt gapless data
* Fixed: [in_mp3] Create new ID3v1/v2 tags configuration setting
* Fixed: [in_vorbis] Huge lag on files with large embedded cover art
* Fixed: [in_vorbis] Metadata & Format Info display for streams in View File Info
* Fixed: [in_vorbis] Potential unicode-related crash on open/close issue
* Fixed: [jpeg.w5s] Saving corrupt album art
* Fixed: [ml_autotag] Results dialog hidden under Winamp when AOT is enabled
* Fixed: [ml_disc] Small resource leak
* Fixed: [ml_playlists] Enter/Shift+Enter broken for selected ML Playlist items
* Fixed: [ml_playlists / ml_transcode] Sending playlists from ML tree to Transcoder
* Fixed: [ml_wire] 404/timeout with valid rss feeds on Vista
* Misc: Miscellaneous localization tweaks, fixes & updates
* Misc: More miscellaneous general tweaks, improvements, fixes and optimizations
* Misc: Setup fixes (Agent not always starting, WLZ filetype not registering, etc)
* Misc: Various other 'Winamp Modern' & 'Bento' skin updates
* Misc: [enc_flac] Now encodes using libFLAC instead of Flake
* Updated: Bento skin v1.2
* Updated: freetype 2.3.7
* Updated: libpng 1.2.28
* Updated: [enc_lame] LAME 3.98
What's new:
