Another easy mod that i would want..
Leon
I got alittle help with a new script when i asked in an admin forum.
But there seemed to be a bug in it (atlest he said it was one)
he uploaded the script here (it works quite good)..
http://hem.mjoelkbar.net/ekonomi.php
Code can be seen here:
http://hem.mjoelkbar.net/ekonomi.phps
But ok, that was only alittle bit of what i was after.
So i then created an html demo of it here:
http://www.volunteerforum.se/economy.php
(does not work, only a html demo)
So, anyone know how to change that script
(or how to make a new one) to fit my demo ?
his script was so mixed with html/php/html/php
so its impossibly to use with phpBB, atlest for me to implant it =/
Also, im my demo this is seen as the admin see it, for other later the
EDIT/DELETE and SUBMIT box will be gone..
Perhaps with help of the code:
if( $userdata['user_level'] != ADMIN )
Volunteer Forum Community
Leon
Rootfile (php file)...
// standard hack prevent
$phpbb_root_path = './';
// standard session management
$userdata = session_pagestart($user_ip, PAGE_ECONOMY);
init_userprefs($userdata);
// set page title
$page_title = 'Economy';
// standard page header
include($phpbb_root_path . 'includes/page_header.'.$phpEx);
// assign template
        'body' => 'economy.tpl')
$template->pparse('body');
// standard page footer
include($phpbb_root_path . 'includes/page_tail.'.$phpEx);
standard tpl file
<HTML>
<BODY>
{TPL_HDR1}Economy{TPL_HDR2}<table width="100%" cellpadding="2" cellspacing="1" border="0" class="forumline">
<th nowrap="nowrap" colspan="2">
Economy
</th>
<tr>
<td class="row1" align="center">
{economy}
</tr>
</td>
</table>{TPL_FTR}
</BODY>
</HTML>
Then use of this for edit/delit and submit box
/* funktioner */
function mConnect($database,$user,$pass) {
    global $id;
    if (!($id=mysql_connect('localhost',$user,$pass))) {
        die('ingen anslutning till mysql');
    if (!mysql_select_db($database)) {
        die('databasen finns inte');
function mDisconnect() {
    global $id;
    mysql_close($id);
function mDo($query) {
    global $id;
    $result = mysql_query($query,$id);
    if ($result == false) {
        die('fel i frågan: ' . $query );
    return($result);
Put that directly before:
// set page title
Put
if (isset($_POST['summa'])) {
    $sql = sprintf("INSERT INTO rad (tillagd,beskrivning,summa) VALUES(NOW(),'%s','%f')",
                                    mysql_real_escape_string($_POST['besk']),
                                    $_POST['summa']
    #echo $sql;
    if (mDo($sql)) { // lite överflödig, men heey
        $msg = 'Kärleken flödade och ditt entry är tillagd i databasen.';
        header('Location: ekonomi.php?msg=' . $msg);
if (isset($_GET['del']) && is_numeric($_GET['del'])) {
    $sql = sprintf('UPDATE rad SET deleted = 1 WHERE id  = %d',$_GET['del']);
    mDo($sql);
after
Then type
After that, put:
<body>
<h1>Ekonomiscriptet som gud glömde</h1>
if (isset($msg)) {
    <h2><?=htmlentities($msg)?></h2>
<form method="post" action="">
<fieldset>
<legend>Lägg till rader</legend>
<p><span>Anledning</span> <input type="text" name="besk" /></p>
<p><span>Summa</span> <input type="text" name="summa" /></p>
<p><input type="submit" value="Lägg till" /></p>
</fieldset>
</form>
<table id="tabell">
<tr><th>Tillagd</th><th>Beskrivning</th><th>Radsumma</th><th>Summa</th><th>Ta bort</th></tr>
$offset = isset($_GET['o']) && is_numeric($_GET['o']) ? $_GET['o'] : 0;
$sql = sprintf('SELECT SQL_CALC_FOUND_ROWS id,tillagd,beskrivning,summa FROM rad WHERE deleted = 0 ORDER BY tillagd DESC LIMIT %d,%d',$offset*$raderPerSida,$raderPerSida);
#echo $sql;
$ekonomi_res = mDo($sql);
/* antalet rader totalt */
$sql = 'SELECT FOUND_ROWS() AS hittade_resultat';
$totalt_res = mDo($sql);
$antal_row = mysql_fetch_assoc($totalt_res);
$antal_rader = $antal_row['hittade_resultat'];
#echo $antal_rader;
/* kika igen och plocka fram äldsta datumet .. */
while ($rad = mysql_fetch_assoc($ekonomi_res)) {
    $lokalSumma += $rad['summa'];
    $aldstaDatum = $rad['tillagd'];
$sql = sprintf("SELECT SUM(summa) AS innansumma FROM rad WHERE deleted = 0 AND tillagd < '%s'",$aldstaDatum);
$saldo_res = mDo($sql);
$saldo = mysql_fetch_assoc($saldo_res);
$innanSumma = $saldo['innansumma'];
#echo $sql;
#echo $totsumma;
@mysql_data_seek($ekonomi_res,0);
    <tr><td><?=substr($rad['tillagd'],0,19)?></td><td><?=$rad['beskrivning']?></td><td><?=$rad['summa']?></td><td><?=$lokalSumma+$innanSumma?></td><td><a href="?del=<?=$rad['id']?>">Ta bort</a></td></tr>
    $lokalSumma+=$rad['summa']*-1;
</table>
<p>
for ($i=0;$i<=floor($antal_rader/$raderPerSida);$i++) {
    <a href="?o=<?=$i?>"><?=$i?></a>
I hope that does the trick.
Leon
And what about all the extra suff i made in the demo ?
The link/date etc ?
And how do i create the SQL ?
I will have a think about this for you as I'm very busy this weekend, and this sounds quite involved.
I will try and post some more code for you on Monday or Tuesday. :)
Leon
Perhaps it wasen't that easy as the totic said then =/
Thanks, i will wait until then, then... :)
Leon
Any success ?
To have the date appear, use
$box = '<input type="text" name="time" value="' . date('F d Y') . '" />';
Leon
Perhaps, but then it isen't changebly ?
Well, seems like this mod need to be rewriten
from start, thats for sure =(
Yes, it will need a fair bit of modification to work in your page.
Leon
Yes it will...
Well just put that to on the self for later then =(
Thanks anyway...
