Thanks for that good mod.
Mod is coming 4 choice in "Multiple Choice Quiz"
I want to give to user (or admin) 5 choice
Thanks!
For 5-6 choice?
There is a limit of only 4. It would require a lot of modifications to add any more. Sorry
I'm afraid not
It will require a lot of modifications to the code and database.
Hello, battye. I do really like your mod, while I also encounter the same issue and I want to try do this myself. If so, could you pls tell the things I need to do from the high level perspective? Thanks a lot!battye wrote:I'm afraid not
Sure, stick around for a couple of minutes while I search through the code.
Welcome to the forum
Hmm, looks like you left us...
I didn't take that long to reply...
$quiz_multiple_choice = array();
$quiz_multiple_choice = explode("!*-.@.-*!", $quiz_data['quiz_alternates']);
"U_QUIZ_NAME" => $quiz_name,
"U_STATISTICS" => "<a href='" . append_sid("quiz_stats.$phpEx?" . POST_QUIZ_URL . "=$quiz_id") . "'>" . $lang['Quiz_stats'] . "</a>",
"F_FORM" => append_sid("quiz.$phpEx?mode=results"),
"F_ID" => $quiz_id,
"F_TYPE" => $quiz_type,
"F_TIME" => time(),
"L_MOD_LANGS" => $mod_langs,
"L_MULTIPLE_INFORMATION" => $lang['Quiz_multiple_information'],
"L_SUBMIT" => $lang['Submit_quiz']));
$template->assign_block_vars("quiz_row", array(
"U_QUESTION_ID" => $quiz_question_id,
"U_QUESTION" => $quiz_question,
"Q_ALTERNATE_ONE" => $quiz_multiple_choice[0],
"Q_ALTERNATE_TWO" => $quiz_multiple_choice[1],
"Q_ALTERNATE_THREE" => $quiz_multiple_choice[2],
"Q_ALTERNATE_FOUR" => $quiz_multiple_choice[3]));
In this area of the code of quiz.php, you will need to add more Q_ALTERNATE_* strings. Just keep incrementing the number in the brackets [4], [5] etc
<tr>
<td class="row1" rowspan="4" width="75%" align="center" valign="middle" height="100%">
<span class="forumlink">
{quiz_row.U_QUESTION}
</span>
</td>
In quiz_play_multiple_choice_body.tpl, you'll need to change that rowspan to however many multiple choices you want.
<tr>
<td class="row2" width="25%" align="left" valign="middle" height="100%">
<span class="gen">
<input type="radio" name="uqm{quiz_row.U_QUESTION_ID}" value="{quiz_row.Q_ALTERNATE_TWO}" /> {quiz_row.Q_ALTERNATE_TWO}
</span>
</td>
</tr>
You'll also need more of those blocks, changing the Q_ALTERNATE_* values each time.
Back in quiz.php, find this:
$question_sql = "INSERT INTO " . QUIZ_MULTIPLE_CHOICE_TABLE . "
(quiz_id, question_id, quiz_question, quiz_alternates, quiz_answer)
VALUES ( " . next_quiz_id() . ", " . ($i + 1) . ", '" . str_replace("\'", "''", bbencode_first_pass(htmlspecialchars($HTTP_POST_VARS["Question_$i"]), '')) . "',
'" . str_replace("\'", "''", htmlspecialchars($HTTP_POST_VARS["Alternate1_$i"])) . "!*-.@.-*!" . str_replace("\'", "''", htmlspecialchars($HTTP_POST_VARS["Alternate2_$i"])) . "!*-.@.-*!" . str_replace("\'", "''", htmlspecialchars($HTTP_POST_VARS["Alternate3_$i"])) . "!*-.@.-*!" . str_replace("\'", "''", htmlspecialchars($HTTP_POST_VARS["Alternate4_$i"])) . "',
'" . htmlspecialchars($answer[$i]) . "')";
You will need to add more of the _POST var values there. You'll also need to add more fields to the quiz_add_multiple_choice_body.tpl file, but that is reasonably straight forward so I won't go into that.
There may or may not be other things you have to do, but hopefully that gets you on the right track.
It seems that no database alterations need to be made after all, which is goodxzc wrote:Thanks for your so quick reply!!
So, it seems no need to change any part of the database or table structure, right? Good design!!
Thanks again, once I finished, I will report back to the forum.
