µTorrent
Postby p2p-sharing-rules » Sun Jan 28, 2007 4:41 am
Your welcome mate! 8) :)
Postby p2p-sharing-rules » Wed Feb 14, 2007 10:02 pm
Feb. 12 , 2007: µTorrent Version 1.6.1 (build 489)
What's New:
- Feature: Select upload/download speed for a torrent through the right click menu
- Feature: Added encryption box to speed guide
- Change: Don't check as many pieces at the same time.
- Change: Misc WebUI changes.
- Change: Switch to JSON for webinterface
- Fix: Problem with category list in the gui when updated from the webui
- Fix: WebUI not clearing state between requests.
- Fix: Redirect also index.html to guest.html
- Fix: Added On Now shows the time it's added, not loaded.
- Fix: JSON uses " instead of '
- Fix: (a) Upnp fix
- Fix: Show pause icon when checking is paused.
- Fix: Fixed problems with XML parser
- Fix: Don't allow two message boxes to be shown in the RSS window
- Fix: Changed some window titles
- Fix: Fix malformed .torrent exploit
- Fix: Boss key field is now larger
Last edited by p2p-sharing-rules on Sat Feb 02, 2008 5:57 am, edited 1 time in total.
Reason: removed download link
Postby p2p-sharing-rules » Sat Feb 24, 2007 10:32 pm
Feb. 13 2007
Version 1.6.1 (build 490)
- Fix: PECompact bug causing crashes
:oops: I just noticed today they updated µTorrent on Feb. 13 to built 490.
µTorrent v1.6.1-install.zip
µTorrent v1.6.1-install.exe in a zip archive.
(621.54 KiB) Downloaded 619 times
Last edited by p2p-sharing-rules on Sat Feb 02, 2008 6:01 am, edited 1 time in total.
Reason: removed download links I uploaded µTorrent v1.6.1-install.exe.zip as an attachement
Postby p2p-sharing-rules » Fri Jul 20, 2007 7:54 pm
The newest stable version is v1.7.1, it was released on July 13 , 2007.
v1.7.0 was a bad release it has been banned from 2 private torrent sites that I'm a member of.They recommended that people don't use v1.7.1 either and go back to using v1.6.1.
To view what's new click *link not available anymore* here , I think it's too long to post it on here.
Download link:
v1.7.1 *link not available anymore*
Postby battye » Sat Jul 21, 2007 4:26 am
Phew, glad I didn't upgrade when I was prompted :D
Thanks for the updates P2P :)
Postby p2p-sharing-rules » Mon Jul 23, 2007 3:35 am
µTorrent 1.7.2
--- 2007-07-21: Version 1.7.2 (build 3458)
- Fix: Disable Local Peer Discovery for private torrents
Postby p2p-sharing-rules » Fri Sep 07, 2007 1:19 am
µTorrent 1.7.4 Sept. 6 , 2007
What's New:
--- 2007-09-06: Version 1.7.4 (build 4482)
- Fix: crash bug in Mainline DHT compatability
--- 2007-09-06: Version 1.7.3 (build 4470)
- Change: Returned to listview for addtorrent dialog
- Change: Always activate other instances of uTorrent, even if they were started with /HIDE or /MINIMIZE
- Change: do not let missing or unwanted pieces prevent endgame
- Change: improve compatability with Mainline DHT
- Change: DHT port message implementation
- Fix: Tentative fix for "Proxy for peer-to-peer connections" functionality if disabled
- Fix: Divide-by-zero crash in statistics
- Fix: Smarter guessing of whether to replace run on startup registry key in case user wants to modify it
- Fix: Hang when deleting files
- Fix: sending in cookie with rss feed item requests
Download link:
Version 1.7.4 *link not available anymore*
Postby battye » Fri Sep 07, 2007 8:06 am
Do you think this one is worth upgrading to P2P?
Postby p2p-sharing-rules » Sat Sep 08, 2007 5:20 am
I not sure Battye I haven't updated to v1.7.4 yet.I'm still using v1.6.1 (build 490). I'm waiting to see if it gets banned or not from private trackers.
Postby p2p-sharing-rules » Thu Sep 13, 2007 8:32 am
µTorrent 1.7.5 Sept. 11 , 2007
--- 2007-09-11: Version 1.7.5 (build 4602)
- Fix: rare crash bug with malformed UPnP response
- Fix: downloads stalled in rare cases
Postby Happy Dude » Thu Sep 20, 2007 1:12 am
I'm keeping v1.6.1 - and so is the majority of people on a tracker I mod on. Are you aware: BitTorrent>bought uTorrent>BitTorrent has a partnership w/ the MPAA?
I rest my case
Lurking since 2004
Happy Dude
Postby moongirl » Thu Oct 11, 2007 3:24 am
Whenever I come into this topic (or anywhere I see it) I read utorrent (youtorrent).
I am wrong!! I have learnt something new...
µ is the Greek letter Mu, also the symbol for micro.
The English sound appears to be mu whereas the Modern Greek sound appears to be mi (me).
So want computer knowledge? Ask a Image
Ok... µving right along!! :wink:
....................................ImageImage ImageImage
Nanananana na.. I get to celebrate Christmas with a bunch of friends!! ;)
Click To Play Online-Scrabble
~~~In the year 2040...I'll have 100,000 posts!!~~~
Postby p2p-sharing-rules » Mon Oct 22, 2007 1:46 pm
I found out recently the µTorrent has 2 easter eggs.
1. Select About in Help menu.
2. Press 'T' on the Keyboard to play µTris.
3. Press 'P' on the keyboard to pause the game.
Also if you click the µTorrent Logo in about, music is played.
Last edited by p2p-sharing-rules on Tue Oct 23, 2007 7:30 pm, edited 1 time in total.
Postby battye » Tue Oct 23, 2007 8:58 am
That is awesome!
High score - 210 :P
Re: µTorrent
Postby battye » Fri Jan 11, 2008 4:03 am
Next time I use Windows I'll give it a crack. It will also give me a chance to download I Am Legend (of course I am referring to the 100 year old song which is out of copyright) :P
PreviousNext
Return to P2P File Sharing
Users browsing this forum: No registered users and 2 guests
