New BitComet Version Released
BitComet v0.77 Nov. 18 , 2006.
What's new
GUI Improved: add recycle bin to place tasks deleted temporarily
GUI Improved: add toolbar button, task list context menu item and Delete hot-key to delete task to recycle bin
GUI Improved: add the function to to capture http/ftp file download in IE
GUI Improved: add a setting to specify the file types to be captured when IE downloads file in in preferences dialog
GUI Improved: add "Download Videos using BitComet" command in IE context menu as a option
GUI Improved: adjust postion of splitters automatically when resizeing main window to keep optimal layout
GUI Improved: display translated text in status-bar in the language of user chosen when mouse hover in the toolabr
GUI Improved: dislpay the number of imported urls in the selection dialog of download all links in webpage
GUI Improved: new toolkit: FlvPlayer
GUI Bugfix: fix the bug that the task list is cleared and not displayed after switch UI language
Core Improved: add the function of searching mirror site automatically for HTTP download task
Core Improved: add the function of download video files in webpage
Core Bugfix: fix the bug that the program may crash when only download partial files in a BT task
Download links:
BitComet v0.77.exe
BitComet v0.77.zip
BitComet v0.79 Nov. 30 , 2006
Download links:
BitComet_0.79_setup.exe
BitComet_0.79.zip
Release Notes
BitComet v0.80 Dec. 15 , 2006
What's New
GUI Improved: new designed HTTP properties dialog layout
GUI Improved: start preview video file while http downloaing from toolbar button or task context menu
GUI Improved: support display URL with non-English UTF-8 characters correctly in English version Windows
GUI Improved: display "Minimize to tray" in task-bar context menu of BitComet if enabled
GUI Improved: new setting of "Optimize download strategy for preview" in Task setting page of preferences dialog
GUI Improved: add move file to desktop and to My Document function in task context menu
GUI Improved: after downloaded torrent file using BitComet, the torrent task properties dialog is displayed immediately
GUI Improved: toolkit FlvPlayer support running under Windows 2003 now
GUI Improved: toolkit FlvPlayer is able to seek while playing for most flv files now
GUI Bugfix: fix the bug that the description info in HTTP properties dialog not been saved after user modified
GUI Bugfix: fix the bug that the number of selected urls in url selection dialog not refreshed after applied filter
GUI Bugfix: fix the bug that BitComet not able to launch FlvPlayer to play downloaded flv file in whose path has space character
Core Improved: HTTP download task support video file preview, etc. play video file during downloading
Core Improved: support to download URL with non-English UTF-8 characters in English version Windows
Core Improved: able to change HTTP connection number during task running
Core Bugfix: fix the bug that the program will lose response when decrease max downloading task number while any task running
Download links:
BitComet v0.80 Setup
BitComet v0.80.zip
BitComet v0.81 Dec. 27, 2006
What's New:
GUI Improved: new floating window to display running status, supporting drag&drop of links in webpage and files to start download
GUI Improved: add new function of auto query file size and server resume-supported ability when add new HTTP task, which can be configured in preferences dialog
GUI Improved: the task number of a task queue is displayed in the favorites list
GUI Improved: new icons for HTTP task states in task list
GUI Improved: link count is displayed in add HTTP task group dialog
GUI Bugfix: fix the bug that URL can not be opened from BitComet if FireFox is set to be default browser
Core Improved: new function of auto recycle memory, which can be configured in preferences dialog
Core Improved: compatible to Windows Vista, able to download HTTP links from IE7
Download links:
BitComet 0.81_setup.exe
BitComet 0.81.zip
BitComet v0.82 Jan. 19 2007
What's New:
GUI Improved: add sound prompt when task download finish, which can be configured in preferences dialog
GUI Improved: improve the context menu of floating window and system tray icon
GUI Improved: processing progress dialog will be displayed when add http task group
GUI Bugfix: fix the bug that the task start order is not correct if reduce task queue length while the queue is not empty
GUI Bugfix: fix the bug of version 0.81 that program can not run under win98/me
Core Improved: the NAT port mapping and Windows Firewall operation is moved to a separated toolkit program, therefor the CPU usage of main program decrease
Core Bugfix: fix the bug that the preview window will lose response if click stop button while preview video file of BT task
Download:
BitComet v0.82.exe
BitComet v0.82.zip
BitComet v0.83 Feb. 4 2007
GUI Improved: add option in HTTP task properties dialog to enable P2P http download
GUI Improved: add hot key Ctrl+R in add HTTP task group dialog, to replace selected text in url to wildcard "(*)"
GUI Improved: refer page url is filled to new http task when drag URL from IE to floating window
GUI Improved: new network rate graph of the floating window in large size
GUI Improved: improve the IE context menu for BitComet, add sub menu to download particular objects in the webpage
GUI Improved: add comment and preview/play column in task list
GUI Improved: WAN IP and network connection status is displayed in status bar of the main window, showing if the listen port is reachable to public domain peers
GUI Improved: enhance the RSS list display function
GUI Improved: add options in perferences dialog to enable network connection status auto check
GUI Improved: add options in perferences dialog to enable task statistical info submitting
GUI Bugfix: fix the bug that "save torrent as" in task context menu will save other task's torrent file if catogory is selected in fav list
GUI Bugfix: fix the bug of the sort operation in task list
GUI Bugfix: fix the bug that the URL link name is not displayed in the selection dialog of downloading all links
GUI Bugfix: fix the display bug of floating window in Windows Vista
GUI Bugfix: fix the bug that the task list is not refreshed after cancel the operation of add HTTP task group
GUI Bugfix: fix the display bug of the HTTP task info window when switching selected task
Core Improved: add P2P download function to HTTP task, able to search more peers to speed up downloading
Core Improved: reconstruction NAT Traversal via UDP using encription connections
Core Improved: improve the robustness of video file preview. the crash of video codec will not terminate BitComet main program
Core Bugfix: fix the bug that HTTP download resume will fail if the web server is rebooted
download:
BitComet v0.83.exe
BitComet v0.83.zip
BitComet v0.84 Feb. 08 , 2007
Release Notes
GUI Improved: new task piece graph for both BT and HTTP, displaying detail file piece downloading state
GUI Improved: enhanced video codec version detection for preview. the extra video codec check wizard is removed.
GUI Improved: add clipboard monitor, which can be enabled in floating window context menu
GUI Bugfix: fix the bug that fail to open torrent file during preview
GUI Bugfix: fix the bug that the UPNP opeartion results are not displayed in statistics view
GUI Bugfix: fix the bug that the floating window is not hide when hit boss key
Core Bugfix: fix the bug that the uplading rate is too low in some situation
Core Bugfix: fix the bug in the decode of GZIP data returned from HTTP server
Download links:
BitComet v0.84 .exe
BitComet v0.84.zip
New BitComet v0.85 March 19 2007
Release Notes:
GUI Improved: new option in torrent maker dialog to enable large file(>1MB) align to piece boundary
GUI Improved: new option in torrent maker dialog to allow user search for HTTP/FTP resources when BT downloading
GUI Improved: new option in BT task properties dialog to enable search for HTTP/FTP resources for BT task files
GUI Improved: new history task filter in fav list, in which tasks displayed in the order of download finish date
GUI Improved: improve task delete dialog, able to remove downloaded files while keep task record in recycle bin
GUI Improved: new option in preferences dialog to enable BT task access P2PCache server (need ISP support)
GUI Improved: task created date and finish date are displayed in task summary
GUI Improved: improve task piece graph, support page down using mouse wheel
GUI Improved: new recomment side-bar which can be toggled in view menu
GUI Improved: BitComet main window minimize to windows taskbar, and system tray icon always displays
GUI Improved: if the task name/publisher name in task list is too long to display, it will be displayed in tooltip
GUI Improved: new search toolbar in the top of BitComet passport view
GUI Improved: improve the clipboard monitor, only capture url links of specific files type
GUI Improved: add support for Maxthon browser
GUI Improved: unhide the option of browse url in BitComet
GUI Improved: downloaded file will be selected when open task save folder
GUI Bugfix: fix the bug that some HTTP download fail due to missing cookie info
GUI Bugfix: fix the bug that hash check of multi BT tasks not running in queue
GUI Bugfix: fix the bug that move to other location command in task context menu does not work
GUI Bugfix: fix the bug that some particular language can not be input to IE edit control when BHO loaded
Core Improved: add P2SP download function to BT task, able to search for HTTP/FTP resources to accelerate download
Core Improved: add large file(>1MB) align to piece boundary function to torrent maker and BT download module
Core Bugfix: fix the bug that may lead to crash when download HTTP task using P2P connection
Core Bugfix: fix the bug that may lead to crash when an error UDP packet received
Core Bugfix: fix the bug that downloaded file may save fail if unsupported characte in current code-page occurred in torrent file
Core Bugfix: fix the bug about GZIP decode in HTTP 1.0
Core Bugfix: fix the bug that the task created from BCTP link is not properly saved if torrent had not downloaded.
Core Bugfix: fix the bug that unable to connect to some FTP server
Download links:
BitComet v0.85.exe
BitComet v0.85.zip
BitComet 0.86 April 03, 2007.
What's new:
GUI Improved: new torrent share function: click my sheard or peer shared in fav list to manage shared torrents
GUI Improved: add option to calculate ED2K link for each file in torrent make dialog
GUI Improved: add preset button to choose preset save folder in BT task properties dialog
GUI Improved: add option to download from the mirror when the source url can't be connected in HTTP task properties dialog
GUI Improved: remove movie info related staffs from torrent make dialog and BT task properties dialog
GUI Improved: add mark highlight button and filter popup menu to download all links dialog
GUI Improved: add server mode option to preferences dialog, which support more connections but can't set precise rate
GUI Improved: improve search box in toolbar of main window
GUI Improved: if choose to open URL inside BitComet, new web window will open, without effect to main window
GUI Improved: after a torrent file downloaded by http task, the BT download will start automatically
GUI Improved: HTTP/FTP resources number for BT task is displayed in file list
GUI Improved: add hotkey PageUp/PageDown, Ctrl+Left/Right and Alt+Left/Right for preview window to seek 10 sec, 30 sec and 120 sec
GUI Improved: bufferred time length is display in status bar when preview
GUI Improved: when close BT/HTTP task properties dialog, save folder and filename is verified to be valid
GUI Bugfix: ban IP menu in peer list of BT task do not work sometimes
GUI Bugfix: avoid system entering suspend/sleeping mode do not work in Windows Vista
GUI Bugfix: left time in task list is not correct if task size is too largr or download rate is too low
Core Improved: new torrent share function, to download torrent files from peers
Core Improved: support HTTPS download
Core Improved: support download FTP resource for BT task
Core Improved: improve SHA1 algorithm, decrease CPU usage
Core Improved: improve NAT Traversal via UDP component, decrease CPU usage
Core Bugfix: upnp.exe launch fail in Windows 2000
v0.85 2007.03.19
Download links:
BitComet 0.86.exe
BitComet 0.86.zip
New BitComet v0.87 May 08, 2007
Release Notes:
GUI Improved: add an option in BT task properties dialog to add this torrent file to my shared torrent list
GUI Improved: add "view task" command to the context menu of my shared torren list
GUI Improved: add a filter in the toolbar of peer shared torrent list
GUI Improved: display peer shared torrent file number in peer shared node of fav list
GUI Improved: add an option to enable BT task search for HTTP/FTP download source in perferences dialog
GUI Improved: add commands to import/export task list and global settings under file menu
GUI Improved: add "rename task" function in context menu of task list
GUI Improved: detail error information will be displayed in tooltip when mouse cursor hover on the red-cross icon of a task which encounter error like disk full
GUI Improved: task rating information will be displayed in tooltip when mouse cursor hover on comment region of the task list
GUI Improved: add hotkey Ctrl+Home/End to move selected tasks to the top/bottom of task list
GUI Improved: support scroll information in all panes on which the mouse cursor is hovering by rolling mouse wheel
GUI Improved: add an options in perferences dialog to enable submit video file snapshot after task download finish
GUI Improved: add an options in perferences dialog to enable protection against ARP cheating attack from LAN
GUI Improved: new designed BitComet resource browser to accelerate open web page from BitComet
GUI Improved: improve displayed information layout in task summary pane
GUI Improved: add "minimize to system tray" to system menu of BitComet button in windows taskbar
GUI Improved: delete file check box in task delete dialog is displayed in red color
GUI Bugfix: View/download list/Columns menu does not work after switch UI language
GUI Bugfix: all tasks will be displayed as in queue if enabled auto-start task when download rate below specified value
GUI Bugfix: all tasks displayed in task list will be removed if launch clear recycle bin in recycle bin context menu even they are not in recycle bin
Core Bugfix: fix a bug sometimes lead to memory leakage
Core Bugfix: handle some BT task with zero-size file incorrectly
Download Links:
BitComet v0.87 setup.exe
BitComet v0.87.zip
New BitComet v0.88 , May 24, 2007
GUI Improved: add an option to verify login password at program startup in perferences dialog
GUI Improved: add default task related info pane option in perferences dialog
GUI Improved: add an option to set Bitcomet as default IE download tool in perferences dialog
GUI Improved: add an option to enable torrent share in perferences dialog
GUI Improved: open BCTP link dialog replaced by open BC link dialog, which can create HTTP/FTP/BT task from BC link
GUI Improved: add "copy BC link to clipboard" command to task list context menu, with hotkey Ctrl+C
GUI Improved: add snapshot number column in task list
GUI Improved: add tooltip to display detail task status info when mouse hover on task icon in task list
GUI Improved: add tooltip to display upload rate, left time, health when mouse hover on download rate, progress, seed number
GUI Improved: upload rate, left time, health will not display in task list by default (can be shown in View menu)
GUI Improved: when task stopped, task can be renamed even if task is not completed
GUI Improved: double click to download torrent file in peer shared torrent list
GUI Improved: add popular column in peer shared torrent list
GUI Improved: new icon and tooltip to designate whether the torrent has been downloaded or shared by me in peer shared torrent list
GUI Improved: add auto-refresh checkbox in toolbar of peer shared torrent list
GUI Improved: add share-all checkbox in toolbar of my shared torrent list
GUI Improved: improve statistic pane display effect
GUI Improved: add save file already exist check when open torrent file to create new BT task
GUI Improved: able to save files to UNC path of shared folder in network during HTTP/BT downloading
GUI Improved: add warning prompt if save file large than 4GB to non-NTFS volume when create HTTP/BT task
GUI Improved: add balloon prompt on disk full error during HTTP/BT downloading
GUI Improved: add prompt dialog to close program and send error report when program is not responding
GUI Improved: add context menu to WAN IP detect light in status bar of main window
GUI Improved: remove some infrequent options in perferences dialog
GUI Improved: floating window remember its postion and size automatically
GUI Bugfix: unfinished tasks will not auto-start at program startup if BitComet is not closed normally before shut down computer
GUI Bugfix: average download rate in task summary pane is cleared after BT task stopped
GUI Bugfix: comment number and snapshot number in shared torrent list is not refreshed in time
GUI Bugfix: operation to torrent will be misplaced after sort shared torrent list
GUI Bugfix: text in toolbar of shared torrent list and passport pane is displayed incorrectly after switch display resolution
GUI Bugfix: refresh of peer shared torrents list lead to high CPU usage
Core Bugfix: program crash in some condition
Download links:
BitComet v0.88 setup.exe
BitComet v0.88.zip
Download via BitTorrent Network
BitComet 0.89 Jun 01, 2007
What's New:
GUI Improved: add "Hide this" to context menu of peer shared torrent list, no longer display the selected torrent files
GUI Improved: add "copy title" to context menu of peer shared torrent list, copy the title of selected torrent file to clipboard
GUI Improved: double click downloaded torrent file in peer shared torrent list to view corresponding task in task list
GUI Improved: new icon in my shared torrent file list to show the shared, but not downloaded torrent file
GUI Improved: peer shared torrent list will only refresh once when typing continuously in the filter edit box
GUI Improved: items in peer shared torrent list will keep selected when auto-refresh
GUI Improved: no torrent file will be displayed in shared torrent list in torrent file sha
re disabled in perferences dialog
GUI Improved: the default number to show in the shared torrent list is set to "unlimit"
GUI Improved: new option of socket start interval(ms) in perferences dialog
GUI Bugfix: upload rate displays text error in task list if max upload rate of task is set
GUI Bugfix: operation to torrent will be misplaced after set filter to peer shared torrent list
GUI Bugfix: task number in history task list is not refreshed upon 0 clock at midnight
GUI Bugfix: "Open BC link" in file menu does not work if task summary pane is current active window
Core Bugfix: Share ratio of BT task is always 0 if only uploading without any downloading
Download links:
v0.89 setup.exe
v0.89.zip
.torrent
New BitComet v0.90 Jun 19, 2007
What's New
GUI Improved: add search for eDonkey download source option in BT task properties dialog
GUI Improved: add ED download plugin configuration page in perferences dialog
GUI Improved: display download rate from HTTP/FTP sources and ED sources in BT task summary pane
GUI Improved: shotsnap info for each item in task list and torrent sharelist changed to a clickable icon
GUI Improved: tasks remain selected after sort task list
GUI Improved: new context menu for my shared torrent and peer shared torrent in fav list
GUI Improved: decrease CPU usage for shared torrent list refresh
GUI Improved: new search icon for each item in shared torrent list
GUI Improved: prompt infomation will be displayed when shared torrent list is empty
GUI Improved: add "copy BC link" to context menu of shared torrent list, with hotkey Ctrl+C
GUI Improved: add "clear all" to context menu of peer shared torrent list
GUI Improved: new option in View menu to show search box in toolbar
GUI Improved: shutdown computer after download finish works for HTTP task now
GUI Improved: text in info bar and status bar of review window change to multi-language string
GUI Improved: the last task will be selected when BitComet startup
GUI Improved: minimize to system tray by close button or minimize button can be configured in preferences dialog
GUI Improved: a prompt window will popup if BitComet detected that the TCP half-open limit of windows is too small at startup
GUI Improved: new state of "detecting" for WAN/LAN ip detector in status bar
GUI Improved: HTTP task connection list move to the up of task log
GUI Improved: the auto-start order for queued task keeps the same to display order of sorted task list
GUI Bugfix: preview window fail to refresh when swtich UI language
GUI Bugfix: "pause all active task" in context menu of floating window does not work
GUI Bugfix: program exit confirm when task running do not count up uploading tasks
GUI Bugfix: unable to click task comment, snapshot and voting for items of 10001th and below in shared torrent list
GUI Bugfix: redownload HTTP task will lose task list sort order
Core Improved: BT task support downloading from eDonkey network (ED plugin for BitComet is required)
Core Improved: BT task support uploading to eDonkey network
Core Improved: add eDonkey network listen port to Windows Firewall and UPNP NAT device when program startup
Core Improved: disable NAT Traversal via UDP automatically for WAN IP user, to improve TCP transfer efficiency
Core Bugfix: auto stop running BT task using a invalid condition dismatch to user settings
Core Bugfix: program will lose respond for a while to flush disk cache when downloading huge HTTP/FTP file under Win2003 64bit
Download links:
BitComet v0.90 setup.exe
BitComet v0.90.zip
Last edited by p2p-sharing-rules on Thu Jul 19, 2007 11:00 pm, edited 1 time in total.
BitComet 0.91 July 19, 2007
What's New:
GUI Improved: double click un-downloaded torrent file in my shared torrent list to start download it
GUI Improved: restore option: add .bc! file extension to unfinished file
GUI Improved: new function in context menu of BT task file list: search ED2K link for selected file
GUI Improved: add real-time sort to task list. enable it from View menu
GUI Improved: new operation in context menu of peer shared torrent list: "add to my share list"
GUI Improved: new status icon for BT task downloading torrent file in task list
GUI Improved: add torrent publish date info to torrent share list
GUI Improved: right click torrent share list header to choose displayed column
GUI Improved: a notifier window will display after add a BC link task
GUI Improved: add file category combo list to torrent share list toolbar
GUI Improved: support multi key words in peer shared torrent list filter, separated by sapce
GUI Improved: torrent file name in torrent share list will be displayed in infotip when mouse hover on it if too long
GUI Improved: specify ED2K link from context menu in file list of BT task, to help ED plugin search ED download resource
GUI Improved: when double click .bc! file, prompt to open the unfinished file using the program associated with the original file without .bc! suffix
GUI Improved: right click toolbar of main window to choose displayed buttons, or using View/Toolbar/Buttons menu
GUI Improved: enable auto adjust column width from View/Tasklist menu
GUI Improved: when HTTP/FTP task connection failed, detail error and retry info will be displayed in connection log
GUI Improved: add HTTP/FTP task error retry interval time option in perferences dialog
GUI Improved: restore allocate disk space before downloading option in perferences dialog
GUI Improved: display upload rate and left time in task list by default
GUI Improved: when available space of save location in BT task properties dialog is not enough, the available space size is displayed in red color
GUI Improved: add copy IP address to context menu of status bar in main window
GUI Improved: display task size, progress and preview button in history task list by default
GUI Bugfix: the order of tasks in queue does not match the order in tasklist when start all task from context menu of floating window
GUI Bugfix: the task number in fav list does not refresh when move task to a new category using context menu of tasklist
GUI Bugfix: the wildcard "(*)" does not work in add HTTP/FTP download group dialog
GUI Bugfix: the HTTP/FTP task in queue failed to stop when double click it in tasklist
GUI Bugfix: the wildcard "(*)" does not work in add HTTP/FTP download group dialog for FTP links
GUI Bugfix: when click cancel button of BT task properties dialog after torrent file downloaded from BC link, the BT task will not be removed
GUI Bugfix: unable to handle non-english character in publisher URL of BT task
Core Improved: support persistent seeding to seed finished torrents in background automatically without starting the task
Core Improved: support uploading rate limit for all persistent seeding, tweak in perferences dialog
Core Improved: support customize file download order for BT task, in BT task properties dialog
Core Improved: support patch TCP half-open limit in Windows Vista
Core Bugfix: program will lose respond for a while to flush disk cache when high-speed downloading HTTP/FTP file from LAN
Core Bugfix: ED plugin will upload invalid data in some situation
Core Bugfix: scheduler failed to resume download after stop tasks for 2 hour or longer
Core Bugfix: unfinished tasks will not auto-start at program startup if BitComet is not closed normally
Download links:
BitComet v0.91 setup.exe
BitComet v0.91.zip
BitComet v0.91 plugin.exe*
Download BitComet v0.91 setup.exe via BitTorrent Network.
* From what I understand the plugin allows you to connect to the eDonkey Network using BitComet.
Battye found this info about it yesterday translated from Chinese? to English using Google.
Plug-in donkey under certain circumstances will slow invalid data
Plug-in order to find the donkey document ED download source
Thanks Battye I wasn't sure what the heck the plugin was for.
BitComet v0.93 Sept. 10, 2007
What's New
v0.93 Core Improved: improve the stability of persistent seeding
v0.92 Aug. 31, 2007
GUI Improved: task list sorting by task name use pronunciation order
GUI Improved: add "toolkit" menu to download softwares correlated with BitComet
GUI Improved: the global max upload rate in preferences dialog must larger than 10kB/s
GUI Improved: the notice window of free disk space insufficiency will not close until user click
GUI Improved: improved torrent file maker dialog layout, supporting dialog resize
GUI Improved: display file type icons in file list of BT task
GUI Improved: display connection time in peer list of BT task
GUI Improved: HTTP/FTP task support hash check (only support certain files)
GUI Bugfix: bug in sorting my shared torrent list by whether shared
GUI Bugfix: torrent file association error in Windows Vista
GUI Bugfix: downloaded file is not selected correctly when view task save folder in Windows Vista
GUI Bugfix: the right and bottom edge of torrent file maker dialog and BT task properties dialog is not displayed correctly in Windows Vista
GUI Bugfix: RealMediaSplitter.ax registration failed in Windows Vista, result in fail to preview rmvb file
GUI Bugfix: available space size in BT task properties dialog displayed in red color mistakenly, not considering task downloaded size
GUI Bugfix: the option of replace wildcard "(*)" to letters does not work in add HTTP download group dialog
GUI Bugfix: fail to set torrent file create date when add it to my shared torrent list from new BT task dialog
Core Improved: add "preview download mode" in BT task context menu, supporting download pieces in sequence
Core Improved: eMule plugin support sending crash report
Core Bugfix: new BT task will stop downloading due to nonexistent disk error in some situation
Core Bugfix: default TCP half open limit in Windows Vista is displayed as 0. it's 10 actually
Download links
BitComet v0.93 setup.exe
BitComet v0.93.zip
BitComet v0.92 setup.exe
BitComet v0.92 plugin.exe
BitComet v0.92.zip
