Big language BUG in this MOD?!?!?
sputum
Hallo!
When i create a true/false Quiz in english. (lang_english). A user with the Language German cant give a correct answer, cause his answer is "Richtig" instead of "True"!
Also if you change the Word for true in your language file after creating a quiz.
Does anyone have the same Problem?
Yeah, it's because it compares the answer to 'true' and 'false', not the German equivalent :)
sputum
i have no idea in programming, bu is it not possible to take the language variable for this comparision?!?!?
The Language variable is in every lang file the same!
sputum
hallo?
I guess this mod is running in some multiple language forums...
Other Question:
Is it possible to chnage the Statistic in an overall statistic?
All right and wrong answers counted together not seppareted by quizzes...
