NapMX and Windows XP
thecaptain11
Is there a patch or a certain site to download a working version of NapMX from?
I downloaded it from http://speed47.chez-alice.fr/napmx/inde ... e=download
installed it and got the mswinsck.ocx is not correctly registered error. i have WinMX working with the PIE patch.
Also is there a discussion group FAQ?
Any help would be appreciated
Chris
thecaptain11
String
Frequent Poster
Frequent Poster
First, download the NapMX (the .exe only would be better). Make sure to get the latest release.
Then you need to download the MSWINSCK.OCX com server.
Now you have to register it. So put the .ocx file in the \windows\system32
folder and open the system console where you have to issue the following command:
regsvr32 \windows\system32\MSWINSCK.OCX
If everything goes fine there will be a message telling you that the server is registered.
Finally, cross your fingers and start your copy of NapMX.
[/b]
thecaptain11
Thank you it worked.
