hello
How I can edit my quiz if I made a fault?
thx
Deleting Quizzes
Hi, log in, and if you haven't already, make yourself a quiz moderator in the ACP -> Users -> Management section (check the Quiz Moderator button).
Now go to the quiz, and find the question you made a fault on, and click the Edit | Delete button. Then make the changes and press Submit. Don't check the Delete Quiz button unless you want it to be deleted (that will delete that whole quiz, not just that question).
Hope that helps
Hope that helps
You are getting the two versions confused
1.1.x will have all of the features that 1.0.6 had in the near future
