hi
I 've installed teh last release of UQM on my board which is: phpBB 2.0.17 + CH2.05.
It seems to work as long as the ACP is set like this: admin validation of quizz set to "off"
If I set it to "on" and I try to validate any quizzan error message is occuring
"Template->make_filename(): Error - file admin_validate_body.tpl does not exist".
I'm perfectly shure to have uploaded this template at the right place (I did three times)
So What should I do right now?. I'm Lost (and not only in translation)
somme troubles in mind with UQM
How many templates do you use? And if possible, can you name them?
Are you still using this release? I thought you are using 1.1.0 now?
Ok, well, it looks like the file admin_validate_body.tpl is missing. In the 1.0.6 download, go to the templates folder, and upload admin_validate_body.tpl to templates/subSilver on your forum
`when I said previously , "yes", I meant "yes I'm right now trying to use use the relaease number 1.10.battye wrote:Ok, well, it looks like the file admin_validate_body.tpl is missing. In the 1.0.6 download, go to the templates folder, and upload admin_validate_body.tpl to templates/subSilver on your forum
Do I still have to upload the file admin_validat_body.tpl?
