When I try to run the ult_database or add them manually I get this errors:
INSERT INTO `phpbb_config` VALUES ('questions_quiz', '5'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_one_category', 'Off'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_cash_on', 'Off'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_verify', 'Off'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_cost', '5'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_cash_field', 'user_points'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_cash_wrong', '10'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_cash_correct', '25'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_admin_submit', 'Off'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_play_once', 'Off'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_guest', 'Off'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_time_limit', 'Off'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_time', '10'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_survey', 'Off'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_mod_edit', 'On'): Installer has encountered an error
INSERT INTO `phpbb_config` VALUES ('quiz_minimum_posts', '0'): Installer has encountered an error
So basicly it isnt working for me, any tips???
SQL install error
Do you have Categories Hierachy, looks like a classic CH problem.
I dont use the Categorie hierarchy and haven't got it installed either, I've seen the link in the readme file to that problem to fix so i'm gonna try to see if that worksbattye wrote:Do you have Categories Hierachy, looks like a classic CH problem.
Thanks for your reply!
okay that worked like a charm, but now.....
I have another small problem
Glad you got that working, was probably something else in the phpBB config table causing the problem, so the CH fix would have indeed worked.Carinspixels wrote:okay that worked like a charm, but now.....
What is the other problem?
got that figured out allready, thanks so much!
the members so love it!
Glad you (and your members) like it
