Quiz author can't play the quiz
As a quiz author, I always do the quiz once to check spelling and that the correct answer is showing.
I certainly don't have a problem if this doesn't show in the statistics.
Every so often I do find a problem that requires Battye's help.
No, it is included in the statistics, it always shows the percentage I score when I test the quiz.
I could go through edit I suppose, but I like to see it function properly as others will see it.
Battye may be better able to answer the question for you.
You have answered it very well, I have nothing to addmoongirl wrote:Battye may be better able to answer the question for you.
I'll think about it for the next version malykazio
