phpBB 2.0.16 Semi-Critical Update
The phpBB Group has announced the release of phpBB 2.0.16, one of the updates marked as urgent. As always, CricketMX.com has been updated, and if you find any problems please report them to me.
We strongly suggest upgrading your board to 2.0.16 if you haven't already, to ensure maximum protection against exploits.
phpBB 2.0.15 to phpBB 2.0.16 Code Changes
These are the Changes from phpBB 2.0.15 to phpBB 2.0.16 summed up into a little Mod. This might be very helpful if you want to update your Board and have installed a bunch of Mods. Then it's normally easier to apply the Code Changes than to install all Mods again.
When you find a 'AFTER, ADD'-Statement, the Code have to be added after the last line quoted in the 'FIND'-Statement.
When you find a 'BEFORE, ADD'-Statement, the Code have to be added before the first line quoted in the 'FIND'-Statement.
When you find a 'REPLACE WITH'-Statement, the Code quoted in the 'FIND'-Statement have to be replaced completely with the quoted Code in the 'REPLACE WITH'-Statement.
After you have finished this tutorial, you have to upload the install/update_to_latest.php file, execute it and then delete it from your webspace.
  • admin/admin_ug_auth.php
  1. FIND - Line 809
    	@reset($auth_user);
    REPLACE WITH
    //	@reset($auth_user);
  • admin/pagestart.php
  1. FIND - Line 43
    	redirect(append_sid("login.$phpEx?redirect=admin/", true));
    REPLACE WITH
    	redirect(append_sid("login.$phpEx?redirect=admin/index.$phpEx", true));
  2. FIND - Line 64
    	redirect(append_sid("login.$phpEx?redirect=admin/&admin=1", true));
    REPLACE WITH
    	redirect(append_sid("login.$phpEx?redirect=admin/index.$phpEx&admin=1", true));
  • includes/bbcode.php
  1. FIND - Line 211
    	$patterns[] = "#\[url=([\w]+?://[^ \"\n\r\t<]*?)\]([^?].*?)\[/url\]#i";
    	$replacements[] = $bbcode_tpl['url3'];
    	// [url=www.phpbb.com]phpBB[/url] code.. (no xxxx:// prefix).
    	$patterns[] = "#\[url=((www|ftp)\.[^ \"\n\r\t<]*?)\]([^?].*?)\[/url\]#i";
    REPLACE WITH
    	$patterns[] = "#\[url=([\w]+?://[^ \"\n\r\t<]*?)\]([^?\n\r\t].*?)\[/url\]#is";
    	$patterns[] = "#\[url=((www|ftp)\.[^ \"\n\r\t<]*?)\]([^?\n\r\t].*?)\[/url\]#is";
  • includes/usercp_avatar.php
  1. FIND - Line 202
    	if ( $width <= $board_config['avatar_max_width'] && $height <= $board_config['avatar_max_height'] )
    REPLACE WITH
    	if ( $width > 0 && $height > 0 && $width <= $board_config['avatar_max_width'] && $height <= $board_config['avatar_max_height'] )
  • includes/usercp_register.php
  1. FIND - Line 455
    		$avatar_sql = user_avatar_delete($userdata['user_avatar_type'], $userdata['user_avatar']);
    AFTER, ADD
    	else
  • modcp.php
  1. FIND - Line 466
    			$new_forum_id = intval($HTTP_POST_VARS['new_forum']);
    			$old_forum_id = $forum_id;
    AFTER, ADD
    			$sql = 'SELECT forum_id FROM ' . FORUMS_TABLE . '
    				WHERE forum_id = ' . $new_forum_id;
    			if ( !($result = $db->sql_query($sql)) )
    				message_die(GENERAL_ERROR, 'Could not select from forums table', '', __LINE__, __FILE__, $sql);
    			if (!$db->sql_fetchrow($result))
    				message_die(GENERAL_MESSAGE, 'New forum does not exist');
    			$db->sql_freeresult($result);
  2. FIND - Line 773
    				$new_forum_id = intval($HTTP_POST_VARS['new_forum_id']);
    				$topic_time = time();
    AFTER, ADD
  • viewtopic.php
  1. FIND - Line 1110
    		$message = str_replace('\"', '"', substr(@preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "@preg_replace('#\b(" . str_replace('\\', '\\\\', $highlight_match) . ")\b#i', '<span style=\"color:#" . $theme['fontcolor3'] . "\"><b>\\\\1</b></span>', '\\0')", '>' . $message . '<'), 1, -1));
    REPLACE WITH
    		$message = str_replace('\"', '"', substr(@preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "@preg_replace('#\b(" . str_replace('\\', '\\\\', addslashes($highlight_match)) . ")\b#i', '<span style=\"color:#" . $theme['fontcolor3'] . "\"><b>\\\\1</b></span>', '\\0')", '>' . $message . '<'), 1, -1));
