What's up with the AVG 7 free update servers being so busy lately.
The last two days it been a pain in the a..,it connect to update then it disconnect a second or 2 after it makes a connection.
I've been to the forum & all they say is there servers for the free version has been overloaded & busy.
I can't even go to the AVG free site today either.
AVG 7 free updates
- Freezmizer
I dunno whats up... it took me quite a few attempts to connect and get an update yesterday. Oh well, what do ya expect for free, its still a decent AV.
- p2p-sharing-rules
- Moderator
Yea , it's a decent AV. I was able to go to the free site finally today.
I still can't get todays update.
- p2p-sharing-rules
- Moderator
I was able to finally get all the updates.It's just bad timing on my part,i seem to connect when there update servers are overloaded & busy.
Creatures such as Javabyte and Open Stream find their way in through updates to you java runtime environment (JRE). You should be able to remove these nasties fairly safely by going to the file identified and simply deleting it (you'll probably find it's a zip file). If you still have problems you'll need to change your java runtimes. (That means, if you have Sun java, you'll need to get the M$ version or vice versa.)moongirl wrote:I am completely up to date no problems, except for Java/Open Stream x2 found yesterday.
I don't know anything about it. Spyware? I've put one in the vault the other is embedded
- p2p-sharing-rules
- Moderator
Moongirl here's alink to a thread on AVG's free forum to help you delete Java/Open Stream from your PC.
- p2p-sharing-rules
- Moderator
YW I hope you can get rid of it.
I thought that MS had stopped offering their version of the jvm
