RoboMX 2.06
- Fixed a little bug I found while writing the Motherboard Monitor Plugin for RoboMX... Critical ;-(
http://mxcontrol.sourceforge.net/module ... oad&cid=12
Motherboard Monitor
The plugin adds following new variables to RoboMX that you can use in the menu's or
in the command scrollers for example.
Variables MBM Plugin adds:
Generic information:
%MBM-NUM-TOTAL% - Total Number of sensors Motherboard monitor has found
%MBM-NUM-TEMP% - Total Number of temperatur sensors
%MBM-NUM-VOLT% - Total Number of voltage sensors
%MBM-NUM-FAN% - Total Number of fan sensors
%MBM-NUM-MHZ% - Total Number of MHZ sensors
%MBM-NUM-PERCENTAGE% - Total Number of percentage sensors
Sensor values:
%MBM-CURRENT[name]% - Current value of the sensors with the name "name"
The name must be the name you assigned to the sensor
in your Motherboard Monitor 5 settings
%MBM-HIGH[name]% - High value of the sensors with the name "name"
%MBM-LOW[name]% - Low value of the sensors with the name "name"
http://mxcontrol.sourceforge.net/module ... it&lid=177
