Bug fixes and what have you for versions below phpBB 2.0.14. As usual, if you find any errors, report them in this topic.
If you own a forum, and use 2.0.13 or below, follow the instructions below to update to 2.0.14. Remember you will need to download the upgrade package for the update_to_latest.php file. You upload this to your forum root / install directory (eg forums.com/install) and run. Make sure you apply the code changes too, as this script only updates the database.
## MOD Title: phpBB 2.0.13 to phpBB 2.0.14 Code Changes
## MOD Author: Acyd Burn < N/A > (Meik Sievertsen) N/A
## Before Adding This MOD To Your Forum, You Should Back Up All Files Related To This MOD
#-----[ OPEN ]---------------------------------------------
admin/admin_styles.php
#-----[ FIND ]---------------------------------------------
# Line 78
include($phpbb_root_path. "templates/" . $install_to . "/theme_info.cfg");
#-----[ REPLACE WITH ]---------------------------------------------
include($phpbb_root_path. "templates/" . basename($install_to) . "/theme_info.cfg");
# Line 742
$fp = @fopen($phpbb_root_path . 'templates/' . $template_name . '/theme_info.cfg', 'w');
$fp = @fopen($phpbb_root_path . 'templates/' . basename($template_name) . '/theme_info.cfg', 'w');
admin/page_header_admin.php
# Line 38
$useragent = (isset($_SERVER["HTTP_USER_AGENT"]) ) ? $_SERVER["HTTP_USER_AGENT"] : $HTTP_USER_AGENT;
$useragent = (isset($HTTP_SERVER_VARS['HTTP_USER_AGENT'])) ? $HTTP_SERVER_VARS['HTTP_USER_AGENT'] : getenv('HTTP_USER_AGENT');
admin/page_footer_admin.php
# Line 36
'PHPBB_VERSION' => '2' . $board_config['version'],
'PHPBB_VERSION' => ($userdata['user_level'] == ADMIN && $userdata['user_id'] != ANONYMOUS) ? '2' . $board_config['version'] : '',
db/postgres7.php
# Line 125
$query = preg_replace("/LIMIT ([0-9]+),([ 0-9]+)/", "LIMIT \\2 OFFSET \\1", $query);
#-----[ AFTER, ADD ]---------------------------------------------
$query = preg_replace('#(.*WHERE.*)(username|user_email|ban_email) = \'(.*)\'#ise', "\"\\1LOWER(\\2) = '\" . strtolower('\\3') . \"'\"", $query);
includes/page_header.php
# Line 38
# Line 469
if (!empty($_SERVER['SERVER_SOFTWARE']) && strstr($_SERVER['SERVER_SOFTWARE'], 'Apache/2'))
if (!empty($HTTP_SERVER_VARS['SERVER_SOFTWARE']) && strstr($HTTP_SERVER_VARS['SERVER_SOFTWARE'], 'Apache/2'))
includes/sessions.php
# Line 53
$session_id = '';
$page_id = (int) $page_id;
# Line 92
// No match; don't login, set as anonymous user
$login = 0;
$enable_autologin = 0;
$user_id = $userdata['user_id'] = ANONYMOUS;
$sql = 'SELECT * FROM ' . USERS_TABLE . ' WHERE user_id = ' . ANONYMOUS;
$userdata = $db->sql_fetchrow($result);
$db->sql_freeresult($result);
# Line 105
// Autologin is not set. Don't login, set as anonymous user
$login = 0;
# Line 244
// Does a session exist?
#-----[ BEFORE, ADD ]---------------------------------------------
$thispage_id = (int) $thispage_id;
modcp.php
# Line 130
message_die(GENERAL_MESSAGE, 'Topic_post_not_exist');
$topic_row = $db->sql_fetchrow($result);
if (!$topic_row)
# Line 150
message_die(GENERAL_MESSAGE, 'Forum_not_exist');
if (!$topic_row)
privmsg.php
# Line 566
if ( !$board_config['allow_html'] )
if ( $user_sig != '' && $privmsg['privmsgs_enable_sig'] && $userdata['user_allowhtml'] )
if ( !$board_config['allow_html'] || !$userdata['user_allowhtml'])
if ( $user_sig != '')
# Line 1531
if ( !$html_on )
if ( $user_sig != '' || !$userdata['user_allowhtml'] )
if ( !$html_on || !$board_config['allow_html'] || !$userdata['user_allowhtml'] )
if ( $user_sig != '' )
search.php
# Line 200
$search_author = str_replace('*', '%', trim($search_author));
if (preg_match('#^[\*%]+$#', trim($search_author)) || preg_match('#^[^\*]{1,2}$#', str_replace(array('*', '%'), '', trim($search_author))))
$search_author = '';
# Line 269
if (preg_match('#^[\*%]+$#', trim($split_search[$i])) || preg_match('#^[^\*]{1,2}$#', str_replace(array('*', '%'), '', trim($split_search[$i]))))
$split_search[$i] = '';
continue;
# Line 416
// Author name search
if ( $search_author != '' )
viewtopic.php
# Line 1052
if ( $user_sig != '' && $userdata['user_allowhtml'] )
# Line 1122
$user_sig = str_replace('\"', '"', substr(preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "preg_replace(\$orig_word, \$replacement_word, '\\0')", '>' . $user_sig . '<'), 1, -1));
$message = str_replace('\"', '"', substr(preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "preg_replace(\$orig_word, \$replacement_word, '\\0')", '>' . $message . '<'), 1, -1));
$user_sig = str_replace('\"', '"', substr(@preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "@preg_replace(\$orig_word, \$replacement_word, '\\0')", '>' . $user_sig . '<'), 1, -1));
$message = str_replace('\"', '"', substr(@preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "@preg_replace(\$orig_word, \$replacement_word, '\\0')", '>' . $message . '<'), 1, -1));
#-----[ SAVE/CLOSE ALL FILES ]------------------------------------------
# EoM
