Ultimate Quiz Mod
Postby battye » Tue Nov 23, 2004 8:46 am
Hi all, I've released a new stable version: 0.3.1
It will now work: http://forums.cricketmx.com/quiz.php
:D
Postby quicksilver » Tue Nov 23, 2004 5:40 pm
Hmm I got an error Battye , I,ve sent it in a Pm but I had another error then so not sure if you got that : (
I tried using the quiz mod logged in and also not logged in .
Postby battye » Wed Nov 24, 2004 10:07 am
Yeah, I'm trying something new :)
Postby toni3 » Sat Feb 26, 2005 6:24 am
Hi,
If i run ult_install.php i had some errors - can you help please ?
ALTER TABLE `phpbb_users` ADD `user_quiz_wrong` INT( 5 ) NOT NULL default '0'
+++ Error: Duplicate column name 'user_quiz_wrong'
ALTER TABLE `phpbb_users` ADD `user_quiz_right` INT( 5 ) NOT NULL default '0'
+++ Error: Duplicate column name 'user_quiz_right'
INSERT INTO `phpbb_config`( `config_name` , `config_value` ) VALUES ('questions_quiz', '5')
+++ Error: Duplicate entry 'questions_quiz' for key 1
toni3
toni3
Postby battye » Sat Feb 26, 2005 6:57 am
Hi, it appears that those columns already exist, have you ever run the ult_install.php script before?
Postby toni3 » Sat Feb 26, 2005 7:02 am
Hi,
No i haven't.
If i delete the tables and rename in the script "user_quiz_wrong" into "wrong" per examplel its ok ?
toni3
Thanks - have found it - had viewed another tabel - had installed another quizz and deletet it but not repaired sql
toni3
Postby battye » Sat Feb 26, 2005 7:25 am
Ok, I'm glad you have it fixed now :)
Just on what you said about renaming in the script "user_quiz_wrong" into "wrong", it wouldn't work because it is used so often in viewquestions.php and to an extent quizzer.php, so it is not a good idea to rename :)
Postby toni3 » Sat Feb 26, 2005 8:17 am
Hi
renamed it for install ult_install.php without errors - not works with quizzer.php - now it's ok with original names.
Toni3
toni3
Postby battye » Sat Feb 26, 2005 3:48 pm
Cool :)
Just an update for anyone wondering, 0.6.x (the next release, not the final however) is going to be big. Categories, SubCategories, Cash Rewards, Bug Fixes, it has the lot. I am not going to give an estimated release date, but I do think it will be in the next few weeks.
Be excited, be very excited :mrgreen:
Postby quicksilver » Sat Feb 26, 2005 5:42 pm
Cash rewards .. :shock: Keep up the good work Battye 8)
Postby toni3 » Mon Feb 28, 2005 4:31 pm
Hi,
It works very good, thanks!
Another little problem: some user play the quiz and if make a wrong answer until submit it is a blank page ? not all user ... ?
toni3
the austrian ... ehm.. german translation of lang_main.php
// Quiz
$lang['Quiz_number'] = 'Insgesamt %d Quizes sind übermittelt<br><a href="./viewquestions.php?mode=statistics">Klick für mehr Statistik!</a>';
$lang['Quizzie'] = 'Quiz';
$lang['Quizzio'] = 'Autor';
$lang['View_quizzes'] = 'Frage ansehen';
$lang['Quiz_page'] = 'Quizseite';
$lang['View_quiz_page'] = 'Quiz ansehen';
$lang['Question'] = 'Frage';
$lang['Answer'] = 'Antwort';
$lang['Play_other'] = 'Gratulation ! 100% richtig !<br>Klick <a href="/quiz.php">da</a> für einen weiteren Quiz!';
$lang['Tad_info'] = 'Zur Hilfe für andere User, bitte eindeutig definieren, auch bei den anderen Möglichkeiten, und beschreibe so genau wie nötig!';
$lang['Informing'] = 'Information';
$lang['Q_name'] = 'Quiztitel wählen';
$lang['Quiz_views'] = 'Ansichten';
$lang['Author_of_quiz'] = 'Mitglied';
$lang['Name_of_quiz'] = 'Quiz Name';
$lang['Score_word'] = 'Punkte';
$lang['Quiz_avg'] = 'Quizanzahl gesamt';
$lang['Stats_Views_Quiz'] = 'Öftest gesehene Quzz';
$lang['Stats_Highscorers_Quiz'] = 'High Scorer Liste';
$lang['Stats_Players_Quiz'] = 'Häufige Quizteilnehmer';
$lang['Stats_Times_Quiz'] = 'Quizes beendet';
$lang['Stats_Uploaded_Quiz'] = 'Quizes hochladen';
$lang['Stats_Top_Up'] = 'Top Quiz Beginner';
$lang['L_quiz'] = 'Quiz';
toni3
Postby battye » Tue Mar 01, 2005 10:51 am
About the blank page thing, I have noticed it but haven't seen a pattern to it. All I know is it should be fixed in 0.6, it has a new system of going to the next page so it shouldn't be an issue :)
Thanks for the translation :D
Postby battye » Sat Mar 05, 2005 6:31 am
0.6.0 released. I will try and add it here in the next few days :)
Postby quicksilver » Sat Mar 05, 2005 1:07 pm
Well done Battye 8)
I sure all the other PHP forums that are going to use it will be very much impressed. :D
Postby pizdec.ent » Thu Mar 10, 2005 5:20 am
I have a PROBLEM : How can i EDIT or DELETE a QUIZE Category , or Subcategories AND A QIUZE ?
I see only how ADD, but i cant see any EDIT or DELETE.
Well..... :(
Please help me ...
pizdec.ent
PreviousNext
Return to Updates
Who is online
Users browsing this forum: No registered users and 0 guests
cron
