Hi all, I've released a new stable version: 0.3.1
It will now work: http://forums.cricketmx.com/quiz.php
Ultimate Quiz Mod
Hmm I got an error Battye , I,ve sent it in a Pm but I had another error then so not sure if you got that : (
I tried using the quiz mod logged in and also not logged in .
Yeah, I'm trying something new
Hi,
If i run ult_install.php i had some errors - can you help please ?
ALTER TABLE `phpbb_users` ADD `user_quiz_wrong` INT( 5 ) NOT NULL default '0'
+++ Error: Duplicate column name 'user_quiz_wrong'
ALTER TABLE `phpbb_users` ADD `user_quiz_right` INT( 5 ) NOT NULL default '0'
+++ Error: Duplicate column name 'user_quiz_right'
INSERT INTO `phpbb_config`( `config_name` , `config_value` ) VALUES ('questions_quiz', '5')
+++ Error: Duplicate entry 'questions_quiz' for key 1
toni3
toni3
Hi, it appears that those columns already exist, have you ever run the ult_install.php script before?
Hi,
No i haven't.
If i delete the tables and rename in the script "user_quiz_wrong" into "wrong" per examplel its ok ?
toni3
Thanks - have found it - had viewed another tabel - had installed another quizz and deletet it but not repaired sql
No i haven't.
toni3
Ok, I'm glad you have it fixed now
Just on what you said about renaming in the script "user_quiz_wrong" into "wrong", it wouldn't work because it is used so often in viewquestions.php and to an extent quizzer.php, so it is not a good idea to rename
Cool
Just an update for anyone wondering, 0.6.x (the next release, not the final however) is going to be big. Categories, SubCategories, Cash Rewards, Bug Fixes, it has the lot. I am not going to give an estimated release date, but I do think it will be in the next few weeks.
Be excited, be very excited
Cash rewards .. Keep up the good work Battye
Hi,
It works very good, thanks!
Another little problem: some user play the quiz and if make a wrong answer until submit it is a blank page ? not all user ... ?
toni3
the austrian ... ehm.. german translation of lang_main.php
toni3
// Quiz
$lang['Quiz_number'] = 'Insgesamt %d Quizes sind übermittelt<br><a href="./viewquestions.php?mode=statistics">Klick für mehr Statistik!</a>';
$lang['Quizzie'] = 'Quiz';
$lang['Quizzio'] = 'Autor';
$lang['View_quizzes'] = 'Frage ansehen';
$lang['Quiz_page'] = 'Quizseite';
$lang['View_quiz_page'] = 'Quiz ansehen';
$lang['Question'] = 'Frage';
$lang['Answer'] = 'Antwort';
$lang['Play_other'] = 'Gratulation ! 100% richtig !<br>Klick <a href="/quiz.php">da</a> für einen weiteren Quiz!';
$lang['Tad_info'] = 'Zur Hilfe für andere User, bitte eindeutig definieren, auch bei den anderen Möglichkeiten, und beschreibe so genau wie nötig!';
$lang['Informing'] = 'Information';
$lang['Q_name'] = 'Quiztitel wählen';
$lang['Quiz_views'] = 'Ansichten';
$lang['Author_of_quiz'] = 'Mitglied';
$lang['Name_of_quiz'] = 'Quiz Name';
$lang['Score_word'] = 'Punkte';
$lang['Quiz_avg'] = 'Quizanzahl gesamt';
$lang['Stats_Views_Quiz'] = 'Öftest gesehene Quzz';
$lang['Stats_Highscorers_Quiz'] = 'High Scorer Liste';
$lang['Stats_Players_Quiz'] = 'Häufige Quizteilnehmer';
$lang['Stats_Times_Quiz'] = 'Quizes beendet';
$lang['Stats_Uploaded_Quiz'] = 'Quizes hochladen';
$lang['Stats_Top_Up'] = 'Top Quiz Beginner';
$lang['L_quiz'] = 'Quiz';
About the blank page thing, I have noticed it but haven't seen a pattern to it. All I know is it should be fixed in 0.6, it has a new system of going to the next page so it shouldn't be an issue
Thanks for the translation
0.6.0 released. I will try and add it here in the next few days
Well done Battye
I sure all the other PHP forums that are going to use it will be very much impressed.
I have a PROBLEM : How can i EDIT or DELETE a QUIZE Category , or Subcategories AND A QIUZE ?
I see only how ADD, but i cant see any EDIT or DELETE.
Well.....
Please help me ...
Well.....
Please help me ...
