Plex
I learned recently that I don't have a public ip address, so using Plex remotely is tricky. I'm natted. My ISP ran out of ipv4 addresses and isn't doing ipv6 yet.
I'm going to try to find a tech at my ISP to sweet talk, because the sales guy wants me to pay $10 extra per month to get an ip address. I don't need a whole static ip to myself. I could manage with either a dynamic ip or even just a handful of ports forwarded.
nesman wrote: Wed Jun 08, 2022 9:52 pm I learned recently that I don't have a public ip address, so using Plex remotely is tricky. I'm natted. My ISP ran out of ipv4 addresses and isn't doing ipv6 yet.
I had that exact same issue with CG-NAT, fortunately my ISP was able to take me off that without paying for the static IP address. When I called I didn't explicitly say I was having a problem with Plex (although it probably wouldn't have mattered if I did), because plenty of other services (like even Xbox I think) don't perform so well with CG-NAT so they must get the question all the time. It's probably easier for them to just freely help the 20% of users it will impact seeing 80% of casual internet users will never notice the difference.
If your ISP still won't take you off CG-NAT, there is another Plex option in-built which might work for you. By default there's a Plex Relay option which routes your video through their server and on to the remote device. It's limited to 1mpbs if you have a free account (which I used while I had the CG-NAT problem, and it's watchable but probably only about 480p quality), although I read somewhere if you have a Plex Pass then the relay is 2mpbs.
My ISP is a phone co-op for a rural town with a ton of farmers. I'd be surprised if one out of one hundred knew what an ip address is.
I'm hoping to convince them that I just need roughly 1/6,500th of an ip address, and I'll gladly pay that portion monthly. (Rounded down to the nearest penny, of course) Just a range of 10 ports forwarded, and I'll be golden. They can even rotate my public ip daily and I'll be ok.
I just keep laughing at the fact that I haven't run into this in 2 decades of having internet service. I even had a helpdesk job once where my desktop had a public ip address for a few years. It didn't need one, but there were so many to go around that it didn't matter.
Layzie Bone
Mr. Computergeek Salad Guy
Boy am I late replying to this...
I had to fight my ISP to get my public IP back when they changed the equipment.
I have been using plex for about 4-5 years and I run it on a PC with a graphics card. I personally think if you go with a graphics card route, might try AMD cards because nVidia locks you to two concurrent transcodes unless you buy a quadro or some professional card that costs way the ***** more.
Converting h265 into something else is very intensive but boy does it save disk space if you have a lot of stuff. So depending on how large your library is, or how big you want it to be, you might consider better hardware especially if you want to share with family and friends.
There are a few issues I have with plex but I haven't found anything that really comes close. Not sure if plex changed their price, but I only pay $5 for plex pass and for me, that's so I can do the hardware transcoding.
