I followed the instructions to the best of my ability (er...copy paste
![Very Happy :D](./images/smilies/icon_biggrin.gif)
General Error
SQL ERROR [ mysql4 ]
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'AND t.topic_status <> 2 AND t.topic_approved = 1 ORDER BY ' at line 2 [1064]
An SQL error occurred while fetching this page. Please contact the Board Administrator if this problem persists.
Here is the code I used for home.php (copy-paste goodness):
* home.php
* September 29, 2009
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './phpBB3/';
// Start session management
$user->session_begin();
$auth->acl($user->data);
$user->setup('viewforum');
* posts and topics */
global $db, $auth;
switch($type)
case 'forum':
$type = 'forum_id';
break;
case 'topic':
$type = 'topic_id';
break;
default:
// no restrictions
$out_where = '';
if( $size_gen_id > 0 )
if( $type == 'topic_id' )
unset($gen_id);
$gen_id = $topic_id_list;
$j = 0;
$j++;
return $out_where;
$search_limit = 5;
$forum_id = array(2, 5);
$topic_id = array(20, 50);
$posts_ary = array(
'SELECT' => 'p.*, t.*, u.username, u.user_colour',
'FROM' => array(
POSTS_TABLE => 'p',
'LEFT_JOIN' => array(
array(
'FROM' => array(USERS_TABLE => 'u'),
'ON' => 'u.user_id = p.poster_id'
array(
'ON' => 'p.topic_id = t.topic_id'
'WHERE' => str_replace( array('WHERE ', 'topic_id'), array('', 't.topic_id'), $topic_id_where) . '
AND t.topic_approved = 1',
$post_author = get_username_string('full', $posts_row['poster_id'], $posts_row['username'], $posts_row['user_colour']);
$post_date = $user->format_date($posts_row['post_time']);
$post_link = append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . $posts_row['forum_id'] . '&t=' . $posts_row['topic_id'] . '&p=' . $posts_row['post_id']) . '#p' . $posts_row['post_id'];
'POST_AUTHOR' => $post_author,
'POST_DATE' => $post_date,
'POST_LINK' => $post_link,
page_header('External page');
'body' => 'external_body.html'
page_footer();
<!-- BEGIN announcements -->
Title: {announcements.TOPIC_TITLE}<br />
Post author: {announcements.TOPIC_AUTHOR}<br />
Post date: {announcements.POST_DATE}<br />
Last post text: {announcements.POST_TEXT}<br />
Post link: {announcements.POST_LINK}
<!-- END announcements -->
Can anyone show me where I went wrong? I'm still new to this, and would greatly appreciate any help.
![Smile :)](./images/smilies/icon_smile.gif)
Regards,
powerbonger
