Clenzowen
Frequent Poster
Frequent Poster
Hello,
always the same mistakes ...
I hope to repair it, because I had just installed the mod quizzes, and members appreciate.
I just made the changes requested and The first error message at the top of the page that appears is :
Warning: Cannot modify header information - headers already sent by (output started at /home/forumsfa/public_html/personnel/gratuits/arcades-et-jeux-35/quiz_installer.php:1) in /home/forumsfa/public_html/personnel/gratuits/arcades-et-jeux-35/includes/functions.php on line 2678
And the second message
Erreur générale
SQL ERROR [ mysql4 ]
Table 'phpbb3_quiz_categories' already exists [1050]
SQL
CREATE TABLE phpbb3_quiz_categories ( quiz_category_id INT(5) NOT NULL AUTO_INCREMENT PRIMARY KEY , quiz_category_name INT(5) NOT NULL )
BACKTRACE
FILE: includes/db/mysql.php
LINE: 175
CALL: dbal->sql_error()
FILE: quiz_installer.php
LINE: 48
CALL: dbal_mysql->sql_query()
What happens if you try to access quiz.php?
That "Erreur générale" is appearing on quiz_installer.php. Once you have run that file (and made the change at http://forums.cricketmx.com/viewtopic.p ... 82#p105682) you can delete quiz_installer.php.
Clenzowen
Frequent Poster
Frequent Poster
when i click on quiz to play I have this error message
Erreur générale
Unknown column 's.quiz_statistic_id' in 'field list' [1054]
SQL
SELECT COUNT(s.quiz_statistic_id) AS quiz_count FROM phpbb3_quiz_statistics s, phpbb3_quiz_questions q WHERE s.quiz_user = 2 AND s.quiz_question_id = q.question_id AND q.question_quiz = 5 LIMIT 1
BACKTRACE
LINE: 175
LINE: 222
FILE: includes/db/dbal.php
LINE: 170
CALL: dbal_mysql->_sql_query_limit()
FILE: includes/quiz/quiz_statistics.php
LINE: 191
CALL: dbal->sql_query_limit()
FILE: quiz.php
LINE: 553
CALL: quiz_statistics->has_user_played_quiz()
when I want to start installing the update by typing in the browser
General Error
SQL ERROR [mysql4]
SQL
CREATE TABLE phpbb3_quiz_categories (quiz_category_id INT (5) NOT NULL PRIMARY KEY AUTO_INCREMENT, quiz_category_name INT (5) NOT NULL)
BackTrace
FILE: includes / db / mysql.php
LINE: 175
CALL: DBAL-> SQL_ERROR ()
LINE: 48
CALL: dbal_mysql-> sql_query ()
I've never seen the "Unknown column 's.quiz_statistic_id' in 'field list' [1054]" error before, I don't even recall seeing it during development.
I think the best thing might be to backup phpbb_quiz and phpbb_quiz_questions and phpbb_quiz_statistics - then drop the 4 quiz tables in phpMyAdmin - run quiz_installer.php and re-insert the backed up data.
I think you have missed a step during the upgrade but I am not sure what.
Clenzowen
Frequent Poster
Frequent Poster
Sorry I double checked everything it still does not ...
And I still have a general error:
SQL
BACKTRACE
LINE: 175
LINE: 222
LINE: 170
LINE: 191
FILE: quiz.php
LINE: 553
In phpMyAdmin can you browse the phpbb3_quiz_statistics table? There should definitely be a quiz_statistic_id (underlined, it is the primary key).
Could you also check the phpbb3_config table and ensure that all of the quiz settings (they all start with qc_ are present). I don't think it relates to this error, but something is going wrong and I can't narrow down what it is yet :?
Are you able to provide a link to your forum with a test account so I can look? Thanks
Clenzowen
Frequent Poster
Frequent Poster
yes, quiz_statistic_id is underlined
i send u a pm for attest count
Thanks Clenzowen, I had a look and fixed it for you.
Creating table phpbb3_quiz...
Creating table phpbb3_quiz_questions...
Creating table phpbb3_quiz_statistics...
Creating table phpbb3_quiz_categories...
Creating table phpbb3_config...
Installation is finished with no errors.
For support, please visit CricketMX.com or phpBB MOD support topic.
I see what the problem is now, I think you had UQM v2.0.0 already installed - so when you overwrote the files it was still looking at the old database tables from v2.0.0 :)
I didn't delete the existing tables as I wasn't sure if you still wanted them, so I renamed them to phpbb3_quiz_OLD, phpbb3_quiz_questions_OLD, phpbb3_quiz_categories_OLD and phpbb3_quiz_statistics_OLD.
I tested the quiz page, it appears with no errors :) So all you need to do now is add a category in the ACP and start adding questions :)
Let me know if it works :)
Abera
battye wrote: Abera, the colour is the same used as in polls.
Thank you sir. I don't know which one it was, but I got it changed. :D
Color bars
Clenzowen
Frequent Poster
Frequent Poster
it's ok thank you
Would you like me to translate files in french please?
Yes, a French translation would be great - thank you :)
Clenzowen
Frequent Poster
Frequent Poster
ok I'll do translations, tomorrow, I would have more time.
plasmino
battye, I was on 2.1.0 ... send me the files for the upgrade? :D
Livirathon
:D hi~battye
Quiz mod can't support Multil language.
if i use english name is work!
else
Ahhh, the foreign characters always get me :(
The fix mainly consists of adding a "true" parameter at the end of the request_var function.
CATEGORIES
--------------OPEN includes/acp/acp_quiz.php--------------------
-----------FIND----------------
					// Now do the actual update, fix up the category name first.
					$category = utf8_normalize_nfc( $db->sql_escape(request_var('category_name', '')) );
-------------REPLACE WITH-------------
					$category = $db->sql_escape( utf8_normalize_nfc(request_var('category_name', '', true)) );
---------------FIND---------------
					if( !check_form_key('uqm_category') )
						trigger_error($user->lang['ACP_UQM_QUIZ_FORM_INVALID'] . adm_back_link(append_sid("{$phpbb_admin_path}index.$phpEx?i=quiz&t=add_category")));
EDIT: here are the fixes for adding/playing quizzes
---OPEN quiz.php---
---FIND---
			$check_correct	= $quiz_configuration->check_correct_checked($current_questions); // see if the user has left any empty
			$quiz_name	= request_var('quiz_name', '');
---REPLACE WITH---
			$quiz_name	= request_var('quiz_name', '', true);
----OPEN includes/quiz/quiz_question.php----
---FIND---
		for($i = 0; $i < request_var('question_number', 0); $i++)
			$question_name	= request_var('question_name_' . $i, '');
			$answers_name	= request_var('answers_' . $i, '');
			$multiples 	= explode("\n", $answers_name);
			$correct	= request_var('answer_' . $i, '');
---REPLACE WITH---
			$question_name	= request_var('question_name_' . $i, '', true);
			$answers_name	= request_var('answers_' . $i, '', true);
			$correct	= request_var('answer_' . $i, '', true);
Then run these SQL queries to convert the database tables to utf8_bin (by default they are collated in latin or something, which is another thing that will be rectified with UMIL...)
----DATABASE----
ALTER DATABASE `phpbb_quiz` DEFAULT CHARACTER SET utf8 COLLATE utf8_bin;
ALTER DATABASE `phpbb_quiz_categories` DEFAULT CHARACTER SET utf8 COLLATE utf8_bin;
ALTER DATABASE `phpbb_quiz_questions` DEFAULT CHARACTER SET utf8 COLLATE utf8_bin;
ALTER DATABASE `phpbb_quiz_statistics` DEFAULT CHARACTER SET utf8 COLLATE utf8_bin;
Edit 2: screenshots of foreign characters working + the quiz play once setting below. I also found a bug whereby if the "show answers" config setting is disabled, then no quiz statistics are stored - that's fixed now :)
Quiz play once config setting (in use)
Foreign characters when submitting a quiz
Foreign characters when playing a quiz
Foreign characters in categories
