Vuze 4.4.0.6a
Release date: June 24, 2010
Vuze 4.4.0.6a windows.exe
Vuze 4.4.0.6a macosx.dmg
Azureus / Vuze
- p2p-sharing-rules
- Moderator
Vuze 4.5
Release date: Aug. 5, 2010
Vuze 4.5 Brings Faster Downloads and Android Support
Changelog
FEATURE: Plug | Android Devices support
CHANGE: Core | Try alternative trackers when seeding and zero connected peers
BUGFIX: UI | Layout improvements in torrent Info view
BUGFIX: UI | Fixed occasional crash when twisting twistie on Windows 7
Download links
Vuze 4.5 windows.exe
Vuze 4.5 macosx.dmg
Vuze 4.5 linux.tar.bz2
Vuze 4.5 linux-x86_64.tar.bz2
Vuze 4.5.jar
Vuze 4.5 pluginapi.jar
Vuze 4.5 source.zip
Changelog
Download links
Vuze 4.5 macosx.dmg
Vuze 4.5.jar
Vuze 4.5 source.zip
- p2p-sharing-rules
- Moderator
Vuze 4.5.0.2
Release date: Aug. 6 ,2010
Vuze 4.5.0.2b
Release date: Mac Aug. 10, 2010, Win Aug. 13, 2010
Changelog
CHANGE: Core | Prevent device manager initialisation in classic UI
BUGFIX: UI | Setting files to 'delete' state corrupting internal view of a torrent's files
BUGFIX: UI | Added reworked progress column to library view by default in place of completion date to allow file manipulation from that view
BUGFIX: UI | Consistently show the file-expand twisty
Download links
Vuze 4.5.0.2b windows.exe
Vuze 4.5.0.2b macosx.dmg
Vuze 4.5.0.2 linux.tar.bz2
Vuze 4.5.0.2 linux-x86_64.tar.bz2
Vuze 4.5.0.2 jar
Vuze 4.5.0.2 pluginapi.jar
Vuze 4.5.0.2 source.zip
Vuze 4.5.0.2b
Changelog
Download links
Vuze 4.5.0.2 jar
- p2p-sharing-rules
- Moderator
Vuze 4.5.0.4
Release date: Sept 1, 2010
Changelog
FEATURE: Core | Allow multiple primordial UDP handlers
FEATURE: UI | Ability to auto-send crash logs
FEATURE: UI | Members of the Beta Program now get a Sidebar entry which will one day have useful beta information
CHANGE: UI | Improved languages change detection so more of the text now shows in the new language (unfortunately not all)
CHANGE: UI | (Windows) Bigger click area around the "X" in the Library's filter box
CHANGE: UI | (Windows) Triple click in search box now selects all the text
CHANGE: UI | Replaced "Remove And.." menu tree from Library's content menu with "Remove..." entry that gives you the same options. Two related configs are in Options->Files->"File Deletion"
BUGFIX: Core | (Windows) Fix drive detection/removal when multiple drives get added/removed at once
BUGFIX: Core | (Windows) Fix drive with letters D: H: L: P: T: X: not being detected when plugged in while Vuze was running
BUGFIX: Core | Fixed some hard drives incorrectly being added as a Device and shown in the sidebar
BUGFIX: Core | (OSX) Add additional (new?) crash log directory to crash log generator (debug.zip)
BUGFIX: Core | (OSX) Fixed two cases where main window would not show after clicking the dock icon
BUGFIX: Core | Don't open files with write-access unless required
BUGFIX: Core | Ensure new profiles are picked up when xcode plugin reloads
BUGFIX: Core | Correctly sequence plugin events to ensure that listeners see the correct plugin state
BUGFIX: Core | Delete .vuze files when subscriptions are removed
BUGFIX: UI | (*nix) Fix table cells not getting click events (affected triggering the "New" column's state)
BUGFIX: UI | Fix case where scrolling right in a table view (Library) didn't draw the newly visible columns
BUGFIX: UI | Fixed some cases where column re-ordering was not being remembered
BUGFIX: UI | Fix Help->Check for Updates not notifying user there were no new updates found
BUGFIX: UI | Fixed visual problems with Tracker Status column when "Don't Scrape Stopped" is enabled
BUGFIX: UI | Fixed Queue and Stop not working on Torrent menu and right click of Sidebar's download's details item
BUGFIX: UI | (OSX) Fixed bug where a false double click was registered when Vuze did not have the focus and you single clicked on a row in the Library
BUGFIX: UI | Fixed subscription name and count on Sidebar not redrawing when either changes
Download links
Vuze 4.5.0.4 windows.exe
Vuze 4.5.0.4 macosx.dmg
Vuze 4.5.0.4 linux.tar.bz2
Vuze 4.5.0.4 linux-x86_64.tar.bz2
Vuze 4.5.0.4 jar
Vuze 4.5.0.4 pluginapi.jar
Vuze 4.5.0.4 source.zip
Changelog
Download links
Vuze 4.5.0.4 jar
- p2p-sharing-rules
- Moderator
Vuze 4.5.1.0
Release Date: Oct. 5, 9 & 23 , 2010
Changelog
FEATURE: Core | Monitor available JVM memory and warn user if it is running out and auto increase (Windows only)
FEATURE: UI | Support opening .vuze files from URLs
FEATURE: UI | Allow setting of JVM direct memory max from UI (Windows only)
FEATURE: UI | Added 'protocol' column to peers view
FEATURE: UI | Expanded state of Sidebar entries are now remembered
FEATURE: UI | (Windows) Added Closeable Games sidebar entry
CHANGE: Core | Changed the trigger for upload rate bias when unlimited upload and inactive downloads
CHANGE: Core | Permit export of all search templates
CHANGE: Core | Reduce debug messages for connection-refused type tracker errors
CHANGE: Core | Reduce version-check timeouts to prevent version server errors from adversely affecting Vuze
CHANGE: Core | Be more tolerant of large PEX messages as clients are sending valid exchanges that exceeded our old limits
CHANGE: Core | Improve detection of devices
CHANGE: Core | Report better error messages for failed plugin installs
CHANGE: Core | Add alert details to alert log
CHANGE: Core | Log plugin load-at-start state to diagnostics
CHANGE: UI | Better handling in in-client browser for search engines and (blocking) pop-ups
CHANGE: UI | Device status column now reports when a file is being copied to the device
BUGFIX: Core | Fixes to superseeding mode
BUGFIX: Core | Fixed up disabling of UDP tracker protocol and added option to control UDP probing
BUGFIX: Core | Fixed bug involving switching search template from manual to auto mode
BUGFIX: Core | Immediately drop incoming connections for stopped downloads (they used to persist and timeout later)
BUGFIX: Core | Fixed bug whereby add-for-seeding torrents with reorder-piece file mode and move-to dirs resulted in download being marked as incomplete
BUGFIX: Core | OSX - handle UTF-8 BOM in plist
BUGFIX: UI | Sort column editor available table correctly
BUGFIX: UI | Fix case where sidebar doesn't display properly at startup
BUGFIX: UI | Changing name of Device should now be remembered
BUGFIX: * | Fix various Null Pointer Exceptions
Download links
Vuze 4.5.1.0a windows.exe
Vuze 4.5.1.0b windows.exe
Vuze 4.5.1.0a macosx.dmg
Vuze 4.5.1.0 linux.tar.bz2
Vuze 4.5.1.0 linux-x86_64.tar.bz2
Vuze 4.5.1.0 jar
Vuze 4.5.1.0 pluginapi.jar
Vuze 4.5.1.0 source.zip
Changelog
Download links
Vuze 4.5.1.0 jar
- p2p-sharing-rules
- Moderator
Vuze 4.6
Release Date: Jan. 17, 2011
Next Stop: Instant Gratification
Wtf I am not sure when it happened, but there's a Vuze Plus version that features DVD burning, built-in anti-virus protection from BitDefender, Play Now (play downloads still in progress) and no ads.
http://www.vuze.com/compare.php
Changelog
FEATURE: Core | UDP NAT Test tool
FEATURE: Core | Added device export/import feature
FEATURE: Plug | uTP support
FEATURE: Plug | Streaming playback
FEATURE: Plug | Added simple HTML view and explicit download option to device RSS feed
FEATURE: UI | Add menu link from sidebar entries to plugin options where applicable
FEATURE: UI | Option for what happens when pressing delete key or tb delete in My Torrents/Library
FEATURE: UI | Allow dropping torrent URLs onto sidebar (to add torrent)
CHANGE: Core | Prevent UDP scrape probes and DHT fallback scrape values from overriding more relevant values
CHANGE: Core | Added some more client type peer-id decodes
CHANGE: Core | Ensure piece picker file priorities take precedence over first/last piece
CHANGE: Core | Don't auto-xcode low noise torrents
CHANGE: Core | Propagate cookies across http->https redirects
CHANGE: Core | Various minor startup tweaks to increase startup performance
CHANGE: Plug | Bump up the DHT minimum supported version
CHANGE: Plug | Added option to force delayed restart on install
CHANGE: UI | Rate limit various update operations to improve performance
CHANGE: UI | Make tracker update button scrape torrents that are stopped
CHANGE: UI | Wire up play button to xcoded content
CHANGE: UI | Sidebar redesign
CHANGE: UI | Categories can now be shown in sidebar
CHANGE: UI | Filter text in Config view now gets highlighted
BUGFIX: Core | Fix poor perf with large peer connection count
BUGFIX: Core | Pickup changes in transcode file categories
BUGFIX: Core | Disable outbound UDP data connections if proxy set
BUGFIX: Core | Fix reading some rare .torrent files with only UTF-8 keys
BUGFIX: Core | Fix bug when loading multiple .torrent files at once when they have the same URL filename
BUGFIX: Plug | Fixup names displayed during plugin load/init
BUGFIX: UI | Prevent sources from being added multiple times
Download links:
Vuze 4.6 windows.exe
Vuze 4.6 macosx.dmg
Vuze 4.6 linux.tar.bz2
Vuze 4.6 linux-x86_64.tar.bz2
Vuze 4.6.jar
Vuze 4.6 pluginapi.jar
Vuze 4.6 source.zip
Changelog
Download links:
Vuze 4.6 macosx.dmg
Vuze 4.6.jar
Vuze 4.6 source.zip
Yes, there is, and I don't like it. If you sign up for a trial of this version, you'll get, amongst other things, a free DVD burn. After making a trial disc, the view was ok-ish on my laptop (with a black frame) but, when I put the disc in my dvd player, the tv showed a small picture with a very wide frame that I couldn't get rid of using either the tv or dvd controls.p2p-sharing-rules wrote:Wtf I am not sure when it happened, but there's a Vuze Plus version that features DVD burning, built-in anti-virus protection from BitDefender, Play Now (play downloads still in progress) and no ads.http://www.vuze.com/compare.php
It took a long time to work out how to get rid of the "plus" features from my Vuze when I decided not to pay for the premium version. I had error messages every time I loaded Vuze until I checked forums and found that lots of folks were having the same issues.
Moral: Test first. Pay (or not) later.
PS. The ads in Vuze cost good money to remove but are unobtrusive.... so I ignore them for free.
- p2p-sharing-rules
- Moderator
Vuze 4.6.0.2
Release date: Feb. 1, 2011
Changelog
FEATURE: Core | Relocate MOOV atoms to front of mp4 files for streaming
FEATURE: Core | Allow specification of IP address restriction for device content availability
FEATURE: Core | Grab <torrent> entities from RSS feed if present
FEATURE: Plug | Rate limit download speeds when play-now active to avoid disk contention
FEATURE: UI | Add 'Play Now' column for streaming
CHANGE: UI | Added visual indication to first level menu for auto-device xcode selection
CHANGE: UI | Support drag-n-drop onto classic share view
BUGFIX: Core | Fix rare case where torrent at top of queue doesn't start & one later in the queue continues to download
BUGFIX: Core | Fix case where certain non-ASCII chars were causing metasearch config bloat
BUGFIX: Core | Fix incorrect handling of reload of upnpav plugin resulting in xcodes disappearing until restart
BUGFIX: Plug | Restore AV 'scanning' spinner icon
BUGFIX: UI | Fix missing columns in "New" view
BUGFIX: UI | Fix drag indicator when prioritizing torrents in Library
BUGFIX: UI | Fix case where certain non-ASCII categories were causing azureus.config to bloat
BUGFIX: UI | Fix cases where Web Search wasn't opening results in external browser
BUGFIX: UI | Fix incorrect toolbar selection when in files view
BUGFIX: UI | Fix incorrect handing of devices set to 'never transcode'
Download links
Vuze 4.6.0.2 Windows.exe
Vuze 4.6.0.2 Macosx.dmg
Vuze 4.6.0.2 Linux.tar.bz2
Vuze 4.6.0.2 Linux.x86_64.tar.bz2
Vuze 4.6.0.2 Source.zip
Vuze 4.6.0.2 pluginapi.jar
Changelog
Download links
- p2p-sharing-rules
- Moderator
Vuze 4.6.0.4
Release Date: March 10, 2011
Changelog
CHANGE: UIv3 | Better messaging for Plus users on license expiry
CHANGE: UI | 50% faster table redraw on Windows when cell value changes
BUGFIX: UI | Fixed some dialogs that could open larger than the screen size
Download links
Vuze 4.6.0.4 windows.exe
Vuze 4.6.0.4 macosx.dmg
Vuze 4.6.0.4 linux.tar.bz2
Vuze 4.6.0.4 linux-x86_64.tar.bz2
Vuze 4.6.0.4.jar
Vuze 4.6.0.4 pluginapi.jar
Vuze 4.6.0.4 source.zip
Changelog
Download links
Vuze 4.6.0.4.jar
